Wireless
8695 Discussions
英特尔 AC-9462 连接问题
Boy_Z
我的 AC-9462 无线网卡有时会在设备管理器中丢失。如果打开网络选项,您会发现飞行模式下只有一个选项,WLAN 选项将消失。这个问题困扰了我很长时间了。我希望有人能帮助我。
n_scott_pearson
Install the latest Wireless and Bluetooth driver packages. I suggest you do this via clean install. Here is the process:
    1. If you haven't already, download - but do not install just yet - the latest Bluetooth and WiFi drivers for your adapter. Here are links to these drivers:
  1. Disable Internet access. Unplug Ethernet cable and/or disable wireless. Keep disabled until told to re-enable.
  2. From Apps & Features app, uninstall any instances of the Intel PROSet/Wireless Software and Intel Wireless Bluetooth. When prompted, choose to "Discard Settings".
  3. Manually shutdown and reboot your computer.
  4. In Device Manager > Network Adapters, check for entry for Intel Dual Band Wireless-AC 9560. If none, go to Step 8.
  5. Right click on the entry for your Intel Dual Band Wireless-AC 9560 and uninstall it., choosing to "Delete the driver software for this device".
  6. Go to Step 4.
  7. (Optional but recommended) Clean out all temporary files using the Windows Clean Disk tool. I recommend that you checkmark all categories offered, even if no files currently (so it leaves it set up for next invocation).
  8. (Optional but recommended) Clear each of your browsers' cache.
  9. Install the Bluetooth driver package.
  10. Install the Wireless driver package.
  11. Manually shutdown and reboot your computer.
  12. Enable Internet access.
  13. Test.
Hope this helps,
