Wireless
8846 Discussions
7260 and wrt54gl cannot get dhcp ip address
ASzez
I have win 7, fully updated. Network adapter: 7260-N. On wrt54gl I cannot obtain ip adress with dhcp. Windows sometimes connects but only with "Limited access".
What is going on?
Jose_H_Intel1
Try updating the router's firmware and disable uAPSD in the wireless adapter properties.
http://www.intel.com/support/wireless/wlan/sb/CS-034875.htm Intel® Wi-Fi Products — TechNote: Access Point Interoperability Issue with uAPSD
What type of security encryption is being used?
Can you connect to other DHCP networks with the Intel® wireless adapter?
Are other systems connecting properly to this wireless adapter?
ASzez
Both, laptop and router is fully updated.
I changed uAPSD and I will be testing.
Security encryption does not matter, because I also tried with open network.
I cannot connect neither at home, work, my iphone hotspot or mobile modem/router.
My old Lenovo x220 and every other system connect my WIFI without any problems.
Only new x240 with 7260 has problems. Works only with static IP.
Jose_H_Intel1
Try resetting the tcp/ip stack. Otherwise, I would think something is interfering with the connection, like security software. You may also try in safe mode with networking.
http://support.microsoft.com/kb/299357 How to reset TCP/IP by using the NetShell utility
