Wireless
9021 Discussions
802.11AX issued solved
3Fees
SSID: NETGEAR28-5G
Protocol: Wi-Fi 6 (802.11ax)
Security type: WPA3-Personal
Manufacturer: Intel Corporation
Description: Intel(R) Wi-Fi 6 AX201 160MHz
Driver version: 22.170.0.3
Network band: 5 GHz
Network channel: 153
Link speed (Receive/Transmit): 1201/1201 (Mbps)
I was checking out my wireless connection and it seemed it was on 802.11ac not 802.11ax for some time, I upgraded the WiFi 6 router to latest firmware and have AX checked marked to run and got an update from Intel on the WiFi and Bluetooth adapters today after going thru device manager I set the adapter to AX mode several times and Windows popup came up saying Windows 11 supports Wifi 6 and here is how to check it, now windows task manager and WiFi properties show  802.11ax is the protocol, Getting network band to run at 6 GHz requires a 6E WIFI router and an Intel Wifi AX211 card, card is inexpensive the 6E router is not mainstream yet and so expensive.
Cheers
3Fees
Jean_Intel
Hello 3Fees,
Since it is not clear to me, I would like to know if you require support regarding the connectivity with the 6 GHz band or another issue. Are you only reporting that a previous problem is now solved?
Jean O.
3Fees
Hi:
Previously problem solved. The 6 Ghz question was resolved earlier, Thanks for the reply.
Cheers
3Fees
Jean_Intel
Hello 3Fees,
I am glad to hear that your previous issue is now solved. Thanks for letting me know.
Since there is no other Troubleshooting question, I will close this thread now. Please keep in mind that this thread will no longer be monitored by Intel. Thank you for your understanding.
Jean O.
3Fees
Hallo:
Update on my Intel(R) Wi-Fi 6 AX201 160MHz
I went into the WiFi 6 router manager on line and moved up the band width here are the results, I was running 1.2Gbps now 2.4Gbps.
from windows 11 WiFi properties.
SSID:      NETGEAR28-5G
Network band:   5 GHz
Network channel:            36
Link speed (Receive/Transmit):    2402/2402 (Mbps)
The AX201 is fully capable to run wifi 6 at maximum speed , Intel cnvio2 socket.
Cheers
3Fees
