Wireless
8607 Diskussionen
8265 verry slow on copy files on LAN, especially on upload
Mitarbeiter
4.120Aufrufe
recently purchased a lenovo T580, with 8265 wifi card
i received the laptop, and updated the preinstalled windows to 10 to build 1803, i already noticed that i had slow copy speeds on my wifi network at home or at work, tried several routers/locations
on 2.4 i am connected at around 144Mbs , so i should have stable internal copy speeds at about 10MB/sec, while i only get 2-5 MB from laptop to synology
on 5ghz, connected at aroud 600Mbs , i get around 1 MB/sec only from laptop to synology
but this is only on the upload site, when i copy a file from the synology to my laptop, on 2.4 i get 10MB/sec, on 5ghz, i get 30MB/sec
tested on my girlfiends laptop, its a HP elite book, also with 8265 card, i get the speed that i want, like 40-50 MB/sec on 5 GHZ and 11 MB/sec on 2.4 on both directions, the laptop is just next to me
i have googled tried a lots of stuff
clean installed windows 10 today directly to 1803 build, when it was clean installed, with drivers from windows itself, same issue
then tried downloading latest proset intel driver , same issue, uninstalled and installed the intel driver from lenovo site, same thing
in advanced settings, i have configured roaming aggresivenes to lowest, same issue
tried 20-40 band, other channels, i always have the same issue on my lenovo, while the HP is in every way working as expected
any help please? i am out of ideas
ssu reports here
2.4 ghz = https://www.dropbox.com/s/iey2h0u6tao2g4t/2.4.txt?dl=0 Dropbox - 2.4.txt
5.0 ghz = https://www.dropbox.com/s/f8c76jb3f5drwmi/5.0.txt?dl=0 Dropbox - 5.0.txt
1 Lösung
Mitarbeiter
2.977Aufrufe
finally fixed in Bios 1.14 for Lenovo Thinkpad T580 / P52
CHANGES IN THIS RELEASE
Version 1.14
[Problem fixes]
- Fix an issue where WLAN network might not be an expected speed.
- Fix an issue where the system may sleep suddenly and randomly.
- Fix an issue where the system may not unlock by TPM pin code.
Lösung in ursprünglichem Beitrag anzeigen
9 Antworten
Mitarbeiter
2.977Aufrufe
Hello pergola.fabio,
Thanks for posting. We understand that you're experiencing slow uploads to your local Synology* server over Wi-Fi.
Have you confirmed if you get similar results uploading files outside the Synology* configuration? As for troubleshooting, please change the adapter advanced setting "Channel Width for 2.4GHz" from Auto to 20 MHz only, that might help while connected to the 2.4Ghz band.
On Synology Router Manger*, please try the recommendations found on their KB site:
- https://www.synology.com/en-us/knowledgebase/SRM/tutorial/Network/Why_is_the_upload_download_traffic_slow Why is the upload/download traffic slow?
Eugenio F.
Mitarbeiter
2.977Aufrufe
H, thnx, changing to 20 doesnt help either
but its not only when i copy to a synology, its also when i copy files to windows servers , on our office
when i am attached to cable, i get full 100 MB/sec speed
Mitarbeiter
2.977Aufrufe
Thanks for your reply.
You've already tried all the recommended troubleshooting, including reinstalling the operating system. At this point, we recommend to https://www.intel.com/content/www/us/en/support/topics/oems.html contact your system manufacturer in order to check its hardware.
Eugenio F.
Mitarbeiter
2.977Aufrufe
Mitarbeiter
2.977Aufrufe
update, today a lenovo techician came around, replaced wifi card, antennas, motherboard, still the same issue, even replaced other models wifi cards , like 8260 and 33xx
to exclude windows, he booted up ubuntu , still same issue
the wifi speed 5.0 or 2.4 ghz, is way to low, when connected to 300 mbit, when we copy files FROM laptop TO network , the max speed is like 10 MB / sec
when we do the same test FROM network TO laptop, the speed is more like 20-25 MB, still not the expected speed, but better
did the test with other Lenovo models, no issue, on that same network
so a bug in the T580 series? intel - lenovo ?
Mitarbeiter
2.977Aufrufe
Thanks for your update on this scenario, since as of now, we haven't had any reports recently of issues with upload with this wireless adapter, the issue may be related more to the Lenovo* laptop model especially since hardware has been replaced on it and the issue persists. At this point we would recommend checking further support with Lenovo* to see if this is a known situation with this model of notebook. Additionally as a reminder, make sure you have power and advanced adapter settings similar to the articles below:
- https://www.intel.com/content/www/us/en/support/articles/000024678/network-and-i-o/wireless-networking.html Recommended Settings for 802.11ac Connectivity
- https://www.intel.com/content/www/us/en/support/articles/000005879/network-and-i-o/wireless-networking.html Setting Power Management for Intel® Wireless Adapters
Leonardo L.
Mitarbeiter
2.977Aufrufe
thnx, checkec all those settings, they are the same
Mitarbeiter
2.977Aufrufe
Thanks for the information, in this case since you've already applied all possible fixes, we would recommend to confirm with Lenovo* for further support on this particular scenario.
Leonardo L
Mitarbeiter
2.978Aufrufe
Version 1.14
[Problem fixes]
Antworten
