Wireless
8716 Discussions
ADDBA response (MSDU) of Intel 6300
vt5
Hi, trying to use MSDU aggregation wireless transfer between AP and 6300 adapter, however, when i use sniffer to capture the ADDBA response from 6300 to AP, it shows in the 802.11 management - action section of the captured packet that MSDU not permitted (value is 0)
driver version: 15.2.0.9
when forcing MSDU aggregation transfer between the devices, it shows that 6300 supports MSDU.
I'd like to know why in my sniffer (omnipeek wild packet) output shows it's not permitted but i was able to transfer MSDU aggregated frames between the 2 devices, is it due to Intel(R) driver issue? or omnipeek issue?
Hi Sage99,
Thank you for your post. Please take in to consideration that these adapters are designed to not support Promiscuous mode therefore getting strange results, while doing packet analysis would be expected.
We are sorry for any inconveniences this may cause.
vt5
Thanks Mark, based on your experience, do you also encounter the same strange result?
