Wireless
9047 Discussions
AX101 Linux driver
Dezhen
Dear Sirs,
My laptop uses Intel ® Wi-Fi 6 AX101, and unable to use wifi and Bluetooth functions under ubuntu system.
This is my device information. And my system is Ubuntu 22.04 and have updated to the latest Linux kernel 6.2.5 and 6.3.0rc2.
Dezhen
Lucas10
WiFi is working fine under Kernel 6.4-rc7. Upgrade it.
VETRIVEL
Updated 23 Build also not working can you share more details
K1YPP
Has there been any movement on fixing the WiFi/Bluetooth issues with Linux and the BeeLink U59 processor and other products? I've been able to do as suggested previously to make changes to the WiFi so that it works, but the Bluetooth still fails. I currently have a BT dongle in a USB port and it is something of a workaround. It isn't perfect but "sorta" works. I now have a new set of Beribes WH202A headphones and the audio output works, via BT, but I cannot get the microphone to show up in the BT GUI.
Here is my current system settings:
U59 system info:
System:
Kernel: 6.6.3-060603-generic x86_64 bits: 64 compiler: N/A Desktop: Cinnamon 5.8.4
tk: GTK 3.24.33 wm: muffin dm: LightDM Distro: Linux Mint 21.2 Victoria base: Ubuntu 22.04 jammy
Machine:
Type: Desktop System: AZW product: U59 v: N/A serial: <superuser required>
Mobo: AZW model: U59 serial: <superuser required> UEFI: American Megatrends LLC. v: JTKT001
date: 02/17/2023
Battery:
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M215 2nd Gen serial: <filter>
charge: 100% (should be ignored) status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K330 serial: <filter>
charge: 50% (should be ignored) status: N/A
CPU:
Info: quad core model: Intel Celeron N5105 bits: 64 type: MCP arch: Tremont rev: 0 cache:
L1: 256 KiB L2: 1.5 MiB L3: 4 MiB
Speed (MHz): avg: 1751 high: 2800 min/max: 800/2900 cores: 1: 1289 2: 1429 3: 2800 4: 1488
bogomips: 15974
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
Device-1: Intel JasperLake [UHD Graphics] driver: i915 v: kernel ports:
active: HDMI-A-1,HDMI-A-3 empty: DP-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:4e61
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: modesetting unloaded: fbdev,vesa
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96
Monitor-1: HDMI-1 mapped: HDMI-A-1 pos: primary,left model: Sceptre F24 res: 1920x1080 dpi: 93
diag: 604mm (23.8")
Monitor-2: HDMI-3 mapped: HDMI-A-3 pos: right model: Sceptre F24 res: 1920x1080 dpi: 93
diag: 604mm (23.8")
OpenGL: renderer: Mesa Intel UHD Graphics (JSL) v: 4.6 Mesa 23.0.4-0ubuntu1~22.04.1
direct render: Yes
Audio:
Device-1: Intel driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:4dc8
Device-2: KTMicro KT USB Audio type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-6:3 chip-ID: 31b2:0010
Sound Server-1: ALSA v: k6.6.3-060603-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
Device-1: Intel Wi-Fi 6 AX201 160MHz driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:4df0
IF: wlo1 state: up mac: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel pcie:
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168
IF: enp1s0 state: down mac: <filter>
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel pcie:
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168
IF: enp2s0 state: down mac: <filter>
IF-ID-1: pan1 state: down mac: <filter>
Bluetooth:
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-1:5
chip-ID: 0bda:8771
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 3.0 lmp-v: 5.1
sub-v: d922
Device-2: Intel AX201 Bluetooth type: USB driver: N/A bus-ID: 1-8:4 chip-ID: 8087:0026
Drives:
Local Storage: total: 953.88 GiB used: 287.47 GiB (30.1%)
ID-1: /dev/sda model: 512GB SSD size: 476.94 GiB speed: 6.0 Gb/s serial: <filter>
ID-2: /dev/sdb model: SATA SSD size: 476.94 GiB speed: 6.0 Gb/s serial: <filter>
Partition:
ID-1: / size: 468.38 GiB used: 236.9 GiB (50.6%) fs: ext4 dev: /dev/sdb1
ID-2: /boot/efi size: 96 MiB used: 32.5 MiB (33.9%) fs: vfat dev: /dev/sda1
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
Sensors:
System Temperatures: cpu: 67.0 C mobo: N/A
Fan Speeds (RPM): N/A
Repos:
Packages: apt: 3239
No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/cappelikan-ppa-jammy.list
1: deb [signed-by=/etc/apt/keyrings/cappelikan-ppa-jammy.gpg] https: //ppa.launchpadcontent.net/cappelikan/ppa/ubuntu jammy main
Active apt repos in: /etc/apt/sources.list.d/chrome-remote-desktop.list
1: deb [arch=amd64] http: //dl.google.com/linux/chrome-remote-desktop/deb/ stable main
Active apt repos in: /etc/apt/sources.list.d/fossfreedom-rhythmbox-plugins-jammy.list
1: deb [signed-by=/etc/apt/keyrings/fossfreedom-rhythmbox-plugins-jammy.gpg] https: //ppa.launchpadcontent.net/fossfreedom/rhythmbox-plugins/ubuntu jammy main
Active apt repos in: /etc/apt/sources.list.d/google-chrome.list
1: deb [arch=amd64] https: //dl.google.com/linux/chrome/deb/ stable main
Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
1: deb http: //packages.linuxmint.com victoria main upstream import backport
2: deb http: //archive.ubuntu.com/ubuntu jammy main restricted universe multiverse
3: deb http: //archive.ubuntu.com/ubuntu jammy-updates main restricted universe multiverse
4: deb http: //archive.ubuntu.com/ubuntu jammy-backports main restricted universe multiverse
5: deb http: //security.ubuntu.com/ubuntu/ jammy-security main restricted universe multiverse
Active apt repos in: /etc/apt/sources.list.d/opera-stable.list
1: deb https: //deb.opera.com/opera-stable/ stable non-free
Active apt repos in: /etc/apt/sources.list.d/winehq-jammy.sources
1: deb [arch=amd64 i386] https: //dl.winehq.org/wine-builds/ubuntu jammy main
Info:
Processes: 293 Uptime: 58m Memory: 15.37 GiB used: 3.51 GiB (22.8%) Init: systemd v: 249
runlevel: 5 Compilers: gcc: 11.4.0 alt: 11/12 Client: Cinnamon v: 5.8.4 inxi: 3.3.13
K1YPP
