Wireless
9027 Discussions
AX1690i Double Connect problem
Neboron
I have a problem creating mobile hotspots at 5GHz. I have successfully used the AX1690i for Double Connect (Wireless virtual reality mode in Killer Intelligence Center) to connect my VR headsets to a PC with minimal latency, but this feature just stopped working a day ago. On windows mobile hotspot I see a message "The selected network band isn't available". Before that sometimes it was needed to restart windows if such a problem appeared, but now I tried almost all without success...
Neboron
May be caused by some Windows update. But I'm not sure, maybe someone had the same problem?
Steven_Intel
Hello Neboron,
I am sorry you are having issues with your Intel® Killer™ Wi-Fi 6E AX1690, I will be glad to help.
Please make sure you have the latest wireless driver version installed. Also, since the mobile hotspot feature settings depends on the operating system, I would make sure that your AP/ router is set to the correct channel and also try getting support from Microsoft, specially if this issue occurred after a recent Windows update.
Steven G.
Steven_Intel
As for now, we will proceed to close this thread. Please keep in mind that this thread will no longer be monitored by Intel.
Steven G.
