Wireless
8653 Discussions
AX200/201 BLE data length extension not expected behavior (incorrect time)
KostasS
I am using 2 laptops one with an AX200 and the other with an AX201 adapter. The laptop is used as a master and a custom board (BLE 5.0) as a slave in BLE connection.
I am facing the following problem:
As observed using a BLE sniffer on wireshark, when the board is connected to a laptop using the AX200/201 the custom board initiates a LL_LENGTH_REQ with the following parameters:
Max RX octets: 140
Max RX time: 2000 microseconds
Max TX octets: 140
Max TX time: 2000 microseconds
And gets an LL_LENGTH_RSP from the master with the following
Max RX octets: 251
Max RX time: 328 microseconds
Max TX octets: 251
Max TX time: 9101 microseconds
Even if the request is for 251 octets/2120usec, the response still has the Max RX time fixed to 328 microseconds, which is not adequate for sending 251 bytes. As a result the packets are then split in 27/67 bytes long fragments (for 1mbps/2mbps PHY respectively) which affects both the connection speed and stability.
I have done the same tests using a BLE dongle or my mobile phone as master and the result is the expected
Max RX octets: 251
Max RX time: 2120 microseconds
Max TX octets: 251
Max TX time: 2120 microseconds
This looks a lot like this issue on the AX 9260 adapter
AC 9260 BLE data length extension problem
Having the AX200 perform as expected is very important, since it is the one shipped with the laptops we are using for testing our hardware.
The above results were the same when tested with the latest 22.150.0 driver.
On AX200 I randomly get the correct connection parameters but this happens every 1 in 10 or more attempts. On the AX201 I never get the correct RX time.
Could you please let me know why this is happening?
Thanks!
PS: Some additional info,
- Results were the same on Windows 10 and Windows 11
- The above measurements are done using wireshark on an NRF Dongle
- The custom board is based on nrf52840, running the s140 softdevice stack
- The laptops used for testing were Microsoft Surface Go 2/3 (AX200) and HP Probooks 450 G8 on i5 and i7 CPUs (AX201) with same result.
DeividA_Intel
Hello KostasS,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
DeividA_Intel
Hello KostasS,
Thanks for all the information provided. I would like to inform you that you will receive the NDA via email.
Please let me know as soon as you sign it.
Deivid A.
DeividA_Intel
Hello KostasS,
After checking your thread, I would like to know if you have signed the NDA.
If so, please let me know.
Deivid A.
