Wireless
8615 Discussions
AX200 cannot be used, an exclamation mark appears in the driver
mingfh
The main board adopts WIN10 system, PCIEX8 converts 10 groups of PCIEX1 signals through PCIE router (ASM2824). When using the AX200 network card, the driver has an exclamation mark and cannot be used. The same set of signals can be used normally in 8265. the motherboard is a desktop computer. It is an INTEL original M2 wireless network card. It can be used normally when placed on the motherboard's native PCIEX1. The device manager-network adapter reports error code 10 and the device cannot be started. Many times today, I tried to uninstall the network card, occasionally Once the installation is successful, the WIFI can be found, and the next attempt still fails to start, and an exclamation mark appears in the driver!
JosueO_Intel
Hello mingfh,
Thank you for posting on the Intel communities.
We found that you already have an open thread in regards to this issue. Assistance will continue via the first thread, you can find it in the following link:
https://community.intel.com/t5/forums/forumtopicpage/board-id/wireless/message-id/39027#M39027
Please keep in mind that this thread will no longer be monitored by Intel.
Josue O.
