Wireless
8721 Discussions
AX200 update doesnt work since 21.10.2.2
mangokeese
Updated to endless versions in between but the update always fails. Everytime i try to install any update on this chip i get Code 39:
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
{Access Denied}
A process has requested access to an object, but has not been granted those access rights.
I´ve tried many suggestions from the forum on how to install the drivers but it always fails with code 39 or sometimes code 9.
I can still use my wifi with this old version but my bluetooth is updated and i can´t roll back
Thank you for your help.
David_G_Intel
Hello mangokeese
Thank you for posting on the Intel️® communities. Please share with us the following information:
  • Which drivers did you try and which installation method did you use?
  • When did it start to happen?
  • Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
  • Were you able to have you wireless connection in a normal/expected performance before?
  • Have you installed any recent software or hardware in your system?
David G
David_G_Intel
David G.
David_G_Intel
David G.
