Wireless
9023 Discussions
AX201 KC certificate request
shrenhost
Hello
I need a KC certificate for AX201 GW (number: R-C-INT-AX201NGW).
Please send me the full certificate.
I'm a server technology engineer.
To be certified in Korea, you need a certificate for AX201NGW products.
RandyT_Intel
Hi @shrenhost,
Thank you for posting here in community. To better assist you, I need some clarification on your specific needs.
  • Could you clarify the purpose of this certificate? Is it needed for compliance documentation, a specific project, testing , or internal reference?
  • I'd also like to understand whether this is a requirement from a client, regulatory body, or customs authority, or if it's needed for internal reference purposes.
Knowing the context of how you'll be using this certificate will help me direct you to the appropriate source or provide more targeted assistance you need.
Randy T.
shrenhost
Hi Randy,
Thanks for your reply.
These documents are required by our KC certification testing laboratory in Korea.
For the KC compliance process of our final product, we need the following for the Intel AX201 module:
- KC certification (if available)
- EMC test report
- RF wireless test report
These documents will be used as reference data for the KC evaluation.
If possible, we would appreciate it if you could provide them at your earliest convenience.
Thank you.
RandyT_Intel
Hi @shrenhost,
Please check your email for the information and instructions I’ve sent directly. You may follow the recommendations provided.
Please note that this thread will no longer be monitored, and I will continue assisting you through the email channel.
If you need further assistance or clarification regarding your request, feel free to reach out via email.
Randy T.
