Wireless
9034 Discussions
AX210 6E - Linux
Inaki
 I'm trying to use the AX210 WiFi interface under Linux Ubuntu 20.04 (Kernel 5.17 and iwlwifi-ty-a0-gf-a0-68 firmware) with the 6GHz band, but when I list the available channels (iwlist wlan0 channel), I only see the 2.4 and 5 GHz channels.
 In another post I read that it can receive the inbound beacons from APs for knowing the country where it is, and then apply the frequency regulation:
https://community.intel.com/t5/Wireless/6-GHz-Wifi-with-AX210-and-Ubuntu-20-04/m-p/1320277#M38045
 In my case, I am in Spain, where the 6GHz band has been approved recently. Do I need to wait for an update of the firmware?
 In any case, I unplugged the antennas, but the result is the same, I cannot see any available 6GHz band channels.
Any suggestion?
Many thanks
JosueO_Intel
Hello Inaki,
Thank you for posting on the Intel communities. In order to have a better understanding of the issue, please share with us the following information:
  1. Is this a desktop or a laptop?
  2. Is this the original wireless adapter of the system?
  3. Which security protocol are you using?
  4. Screenshot of the issue.
  5. Router model.
Also, please download and install the Intel System Support Utility (Intel SSU):
https://www.intel.com/content/www/us/en/download/18895/intel-system-support-utility-for-the-linux-operating-system.html
Open the application and select "Everything" click on "Scan" to see the system and device information, save the report and attach it to your response.
Josue O.
Inaki
Hi Josue,
 I summarize the asked information:
It is MiniPC from Gygabyte.
  1. Is this the original wireless adapter of the system?
No, it came with another 802.11ac wireless adaptor.
  1. Which security protocol are you using?
We are not in that phase yet.
  1. Screenshot of the issue.
Here it can be seen the available channels, where I only see the 2.4 and 5 GHz bands.
Here it can be seen the iwlwifi driver loading:
  1. Router model.
The router is an Aruba AP-635
I have also uploaded the output log of the SUU.
Many thanks.
JosueO_Intel
Hello Inaki,
Josue O.
JosueO_Intel
Hello Inaki,
Please type the following commands and provide the output via the command to the terminal:
  1. $ hostnamectl.
  2. #lspci​
  3. # modinfo iwlwifi
  4. # lsmod | grep iwlwifi​
  5. # dmesg | grep iwlwifi​
  6. # dmesg | grep “no suitable firmware found!”​
Also, please type: # dmesg | grep ASSERT​
If the output is empty, please follow this wiki: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/debugging ​to extract dmesg and trace-cmd.
If the output has value, please collect it from the wiki FW dump too.
Josue O.
Inaki
Hi Josue,
 Here is the output of each command:
  • # hostnamectl
 Static hostname: wtsnsta
       Icon name: computer-desktop
         Chassis: desktop
      Machine ID: 2e5bc8f0114f4c02b38f163fb6be14a4
         Boot ID: 720aabd78ecb46c68ee4ec14dae50703
Operating System: Ubuntu Jammy Jellyfish (development branch)
          Kernel: Linux 5.17.0-051700rc2-generic
    Architecture: x86-64
 Hardware Vendor: GIGABYTE
  Hardware Model: GB-BRi7_H_-8550
  • # lspci​
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 08)
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 620 (rev 07)
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #1 (rev f1)
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point LPC Controller/eSPI Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection I219-V (rev 21)
01:00.0 USB controller: ASMedia Technology Inc. ASM2142 USB 3.1 Host Controller
02:00.0 Network controller: Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz (rev 1a)
  • # modinfo iwlwifi
filename:       /lib/modules/5.17.0-051700rc2-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license:        GPL
description:    Intel(R) Wireless WiFi driver for Linux
firmware:       iwlwifi-100-5.ucode
firmware:       iwlwifi-1000-5.ucode
firmware:       iwlwifi-135-6.ucode
firmware:       iwlwifi-105-6.ucode
firmware:       iwlwifi-2030-6.ucode
firmware:       iwlwifi-2000-6.ucode
firmware:       iwlwifi-5150-2.ucode
firmware:       iwlwifi-5000-5.ucode
firmware:       iwlwifi-6000g2b-6.ucode
firmware:       iwlwifi-6000g2a-6.ucode
firmware:       iwlwifi-6050-5.ucode
firmware:       iwlwifi-6000-6.ucode
firmware:       iwlwifi-7265D-29.ucode
firmware:       iwlwifi-7265-17.ucode
firmware:       iwlwifi-3168-29.ucode
firmware:       iwlwifi-3160-17.ucode
firmware:       iwlwifi-7260-17.ucode
firmware:       iwlwifi-8265-36.ucode
firmware:       iwlwifi-8000C-36.ucode
firmware:       iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware:       iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware:       iwlwifi-BzBnj-a0-hr-b0-69.ucode
firmware:       iwlwifi-BzBnj-a0-gf4-a0-69.ucode
firmware:       iwlwifi-BzBnj-a0-gf-a0-69.ucode
firmware:       iwlwifi-BzBnj-a0-fm4-a0-69.ucode
firmware:       iwlwifi-BzBnj-a0-fm-a0-69.ucode
firmware:       iwlwifi-gl-a0-fm-a0-69.ucode
firmware:       iwlwifi-bz-a0-fm-a0-69.ucode
firmware:       iwlwifi-bz-a0-mr-a0-69.ucode
firmware:       iwlwifi-bz-a0-gf4-a0-69.ucode
firmware:       iwlwifi-bz-a0-gf-a0-69.ucode
firmware:       iwlwifi-bz-a0-hr-b0-69.ucode
firmware:       iwlwifi-SoSnj-a0-mr-a0-69.ucode
firmware:       iwlwifi-ma-a0-fm-a0-69.ucode
firmware:       iwlwifi-ma-a0-mr-a0-69.ucode
firmware:       iwlwifi-ma-a0-gf4-a0-69.ucode
firmware:       iwlwifi-ma-a0-gf-a0-69.ucode
firmware:       iwlwifi-ma-a0-hr-b0-69.ucode
firmware:       iwlwifi-SoSnj-a0-jf-b0-69.ucode
firmware:       iwlwifi-SoSnj-a0-hr-b0-69.ucode
firmware:       iwlwifi-SoSnj-a0-gf-a0-69.ucode
firmware:       iwlwifi-SoSnj-a0-gf4-a0-69.ucode
firmware:       iwlwifi-ty-a0-gf-a0-69.ucode
firmware:       iwlwifi-so-a0-gf-a0-69.ucode
firmware:       iwlwifi-so-a0-hr-b0-69.ucode
firmware:       iwlwifi-so-a0-jf-b0-69.ucode
firmware:       iwlwifi-cc-a0-69.ucode
firmware:       iwlwifi-QuQnj-b0-jf-b0-69.ucode
firmware:       iwlwifi-QuZ-a0-jf-b0-69.ucode
firmware:       iwlwifi-QuZ-a0-hr-b0-69.ucode
firmware:       iwlwifi-Qu-b0-jf-b0-69.ucode
firmware:       iwlwifi-Qu-c0-hr-b0-69.ucode
firmware:       iwlwifi-QuQnj-b0-hr-b0-69.ucode
firmware:       iwlwifi-Qu-b0-hr-b0-69.ucode
srcversion:     31C9FEA3CEE3B19FB384525
alias:          pci:v00008086d00002727sv*sd*bc*sc*i*
alias:          pci:v00008086d00007F70sv*sd*bc*sc*i*
alias:          pci:v00008086d00007E40sv*sd*bc*sc*i*
alias:          pci:v00008086d00002729sv*sd*bc*sc*i*
alias:          pci:v00008086d000054F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000051F0sv*sd*bc*sc*i*
alias:          pci:v00008086d00007AF0sv*sd*bc*sc*i*
alias:          pci:v00008086d00007A70sv*sd*bc*sc*i*
alias:          pci:v00008086d00002726sv*sd*bc*sc*i*
alias:          pci:v00008086d00002725sv*sd*bc*sc*i*
alias:          pci:v00008086d00002723sv*sd*bc*sc*i*
alias:          pci:v00008086d00002720sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd*bc*sc*i*
alias:          pci:v00008086d00004DF0sv*sd*bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd*bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd*bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd*bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd*bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd*bc*sc*i*
alias:          pci:v00008086d0000271Csv*sd*bc*sc*i*
alias:          pci:v00008086d0000271Bsv*sd*bc*sc*i*
alias:          pci:v00008086d00002526sv*sd*bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009074bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000014bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000012bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001012bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00003E01bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00003E02bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001014bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000850bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000950bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000930bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000910bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000810bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008050bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000150bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000050bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd000010D0bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00004010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000000bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000930bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000950bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000850bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000910bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000810bc*sc*i*
alias:          pci:v00008086d000024F6sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000024F5sv*sd00000010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000044bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000004bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008130bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd0000D030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd0000C030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00009030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00008030bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000B0B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D0B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C010bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00001030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000250bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001012bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000012bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd000001F0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd000010B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000010bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009E10bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009400bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009000bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd0000520Abc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005212bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005F10bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005490bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005290bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005590bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005190bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005090bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005420bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000502Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005020bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009410bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009310bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009510bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009200bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009210bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009112bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009110bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000900Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009012bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009010bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005202bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005102bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005002bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005200bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000500Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005000bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00001010bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005400bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005510bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005410bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005412bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005012bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005C10bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005210bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005302bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005310bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005100bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005110bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005010bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00000000bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002150bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002050bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002110bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002010bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00008110bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00008010bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004210bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004310bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004110bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004510bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004410bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004212bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004012bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004010bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00001170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00001070bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008570bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008470bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008272bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008370bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008270bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008062bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008060bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008172bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008072bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008070bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000370bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000472bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000470bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000272bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000270bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000062bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000060bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000172bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000072bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000070bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C420bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C220bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C02Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C020bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C360bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C370bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C560bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C570bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C462bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C460bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C472bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C470bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C262bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C26Abc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C260bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C272bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000CC60bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000CC70bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C270bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C760bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C770bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C162bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C062bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C160bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C06Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C060bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C070bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004420bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004220bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000402Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004020bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005770bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005070bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004360bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004370bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004560bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004570bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A6Cbc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A6Ebc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A70bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000486Ebc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004870bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004462bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000446Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004460bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004472bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004470bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004262bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000426Abc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004260bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004272bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004270bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004162bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004062bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004160bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000406Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004060bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004C70bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004C60bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004070bc*sc*i*
alias:          pci:v00008086d00000892sv*sd00000462bc*sc*i*
alias:          pci:v00008086d00000893sv*sd00000262bc*sc*i*
alias:          pci:v00008086d00000892sv*sd00000062bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000822bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000422bc*sc*i*
alias:          pci:v00008086d00000895sv*sd00000222bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000022bc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd00005260bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004860bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd0000446Abc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004460bc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd0000426Abc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd00004260bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd0000406Abc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004060bc*sc*i*
alias:          pci:v00008086d00000887sv*sd00004462bc*sc*i*
alias:          pci:v00008086d00000888sv*sd00004262bc*sc*i*
alias:          pci:v00008086d00000887sv*sd00004062bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004822bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004422bc*sc*i*
alias:          pci:v00008086d00000891sv*sd00004222bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004022bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005027bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005025bc*sc*i*
alias:          pci:v00008086d00000897sv*sd00005017bc*sc*i*
alias:          pci:v00008086d00000897sv*sd00005015bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005007bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005005bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001027bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001025bc*sc*i*
alias:          pci:v00008086d000008AFsv*sd00001017bc*sc*i*
alias:          pci:v00008086d000008AFsv*sd00001015bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001007bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001005bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001216bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001226bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001206bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001215bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001225bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001205bc*sc*i*
alias:          pci:v00008086d00000886sv*sd00001317bc*sc*i*
alias:          pci:v00008086d00000886sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001327bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001307bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000089sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000089sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005226bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005225bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005221bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005207bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005206bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005205bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005201bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005216bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005215bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005211bc*sc*i*
alias:          pci:v00008086d0000008Bsv*sd00005317bc*sc*i*
alias:          pci:v00008086d0000008Bsv*sd00005315bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005327bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005325bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005307bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005305bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001304bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00004820bc*sc*i*
alias:          pci:v00008086d00000085sv*sd0000C228bc*sc*i*
alias:          pci:v00008086d00000085sv*sd0000C220bc*sc*i*
alias:          pci:v00008086d00000082sv*sd0000C020bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001318bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001328bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001308bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001307bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00004239sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00004239sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00004238sv*sd00001118bc*sc*i*
alias:          pci:v00008086d00004238sv*sd00001111bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001326bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001321bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001307bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001306bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001301bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001128bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001121bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001108bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001101bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001316bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001216bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001311bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001211bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001326bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001321bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001221bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001306bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001206bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001301bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001201bc*sc*i*
alias:          pci:v00008086d0000423Bsv*sd00001011bc*sc*i*
alias:          pci:v00008086d0000423Asv*sd00001021bc*sc*i*
alias:          pci:v00008086d0000423Asv*sd00001001bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001114bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001014bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001111bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001011bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001104bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001004bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001101bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001001bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001124bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001024bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001121bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001021bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001216bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001215bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001314bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001214bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001211bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001226bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001225bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001324bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001224bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001221bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001206bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001205bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001304bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001204bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001201bc*sc*i*
depends:        cfg80211,iwlmei
retpoline:      Y
intree:         Y
vermagic:       5.17.0-051700rc2-generic SMP preempt mod_unload modversions
sig_id:         PKCS#7
signer:         Build time autogenerated kernel key
sig_key:        4E:EC:C9:83:C9:F1:C8:F9:4B:FF:1C:DA:3B:EA:B5:38:8D:FE:31:BF
sig_hashalgo:   sha512
signature:      65:49:7B:37:9F:65:F0:03:F1:30:BF:CD:B5:14:87:31:4E:C0:34:E4:
                C4:35:0D:5A:7E:3A:85:D8:F4:D2:AB:99:CE:88:B5:98:3B:8C:AF:1E:
                E7:D2:AE:AF:5C:DB:11:4A:51:1B:E8:89:29:EF:51:57:4B:2D:7A:20:
                3B:95:3A:62:EB:87:94:65:8F:10:D8:98:67:ED:C7:18:2A:70:E5:8B:
                68:71:38:70:9E:6E:FA:23:4B:38:E2:F0:43:15:93:54:70:B6:A0:25:
                CD:03:E8:B5:16:B4:BD:87:A0:CE:22:8A:8A:C0:FF:B5:EA:72:6F:18:
                98:03:E0:DF:82:87:AD:66:50:BA:15:92:B5:20:81:55:2B:1B:EE:43:
                BB:D3:50:44:72:3C:1D:56:72:D7:58:A4:51:C6:66:9A:30:10:EA:0E:
                16:D9:F5:54:A2:5D:9C:51:29:67:58:39:6C:AB:FD:15:F6:38:5D:B7:
                66:DA:57:C2:6B:94:CE:0D:C7:3E:06:B6:7B:D4:DC:D6:6E:A6:74:89:
                91:4B:03:A3:3A:80:8A:8B:2D:55:43:95:07:8F:05:91:F5:C7:68:DF:
                F2:5E:60:45:CC:94:0E:C4:58:AD:F3:56:70:CA:5B:1C:FA:8A:52:17:
                A5:DD:ED:AE:04:76:41:02:44:2E:FF:72:90:80:3D:7F:80:88:4F:95:
                E7:DD:76:7D:CC:6D:3E:59:75:F2:7B:29:66:D0:1D:8E:65:0E:65:86:
                CB:6A:8C:69:21:ED:17:37:C6:4F:A3:09:4B:E1:D5:63:C2:68:A7:E8:
                D6:C7:F3:9E:6F:18:26:00:90:F9:80:37:57:17:37:A9:CC:6D:6B:07:
                AD:C7:29:11:4F:E7:1A:7A:E3:0A:EA:B2:7B:62:D1:D0:D7:C3:07:86:
                5D:D9:22:62:C9:7C:59:41:75:E6:F1:D3:F5:60:AB:D1:F9:53:41:6A:
                BB:05:90:22:7C:0D:A8:31:DC:F9:23:A0:F0:33:2D:3C:E1:D9:F2:0C:
                EF:ED:B1:04:74:12:A2:8A:82:BA:7D:52:75:AA:2F:03:37:18:6A:1B:
                66:DB:CA:00:37:A6:83:A0:BB:AF:C1:7E:FE:1E:48:72:AC:FC:9F:FA:
                30:11:2F:57:30:7B:A0:22:6E:6A:03:D1:C2:DB:2D:C3:B6:6E:69:1C:
                0D:E3:9E:DD:66:7E:04:EA:48:59:0F:67:1D:35:26:D3:81:4D:6B:BA:
                9D:1C:32:CD:F2:4F:1D:A1:CE:25:7C:D0:96:64:00:19:87:C1:02:75:
                14:20:92:1F:9C:92:35:AC:9B:0D:41:93:B0:09:53:C7:27:36:A4:9B:
                FF:5D:36:33:98:2B:E9:49:DD:54:75:91
parm:           swcrypto:using crypto in software (default 0 [hardware]) (int)
parm:           11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm:           amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K (16K buffers) 4: 2K (default 0) (int)
parm:           fw_restart:restart firmware in case of error (default true) (bool)
parm:           nvm_file:NVM file name (charp)
parm:           uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm:           enable_ini:Enable debug INI TLV FW debug infrastructure (default: true (bool)
parm:           bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm:           led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm:           power_save:enable WiFi power management (default: disable) (bool)
parm:           power_level:default power save level (range from 1 - 5, default: 1) (int)
parm:           disable_11ac:Disable VHT capabilities (default: false) (bool)
parm:           remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm:           disable_11ax:Disable HE capabilities (default: false) (bool)
  • # lsmod | grep iwlwifi​
iwlwifi               421888  1 iwlmvm
iwlmei                 40960  2 iwlmvm,iwlwifi
cfg80211              929792  4 iwlmvm,iwlmei,iwlwifi,mac80211
  • # dmesg | grep iwlwifi​
[    4.426088] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
[    4.440408] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-ty-a0-gf-a0-69.ucode failed with error -2
[    4.468094] iwlwifi 0000:02:00.0: api flags index 2 larger than supported by driver
[    4.468111] iwlwifi 0000:02:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
[    4.468345] iwlwifi 0000:02:00.0: loaded firmware version 68.01d30b0c.0 ty-a0-gf-a0-68.ucode op_mode iwlmvm
[    4.656929] iwlwifi 0000:02:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[    4.663385] iwlwifi 0000:02:00.0: WRT: Failed to set DRAM buffer for alloc id 1, ret=-1
[    4.663389] iwlwifi 0000:02:00.0: WRT: Failed to set DRAM buffer for alloc id 2, ret=-1
[    4.663390] iwlwifi 0000:02:00.0: WRT: Failed to set DRAM buffer for alloc id 3, ret=-1
[    4.826997] iwlwifi 0000:02:00.0: loaded PNVM version dda57f4f
[    4.842152] iwlwifi 0000:02:00.0: Detected RF GF, rfid=0x10d000
[    4.911067] iwlwifi 0000:02:00.0: base HW address: 80:45:dd:00:2c:2e
[    6.182085] iwlwifi 0000:02:00.0: WRT: Failed to set DRAM buffer for alloc id 1, ret=-1
[    6.182089] iwlwifi 0000:02:00.0: WRT: Failed to set DRAM buffer for alloc id 2, ret=-1
[    6.182090] iwlwifi 0000:02:00.0: WRT: Failed to set DRAM buffer for alloc id 3, ret=-1
  • # dmesg | grep “no suitable firmware found!”​
No output.
  • # dmesg | grep ASSERT​
No output.
Concerning the wiki, I have attached the dmesg, trace and fw dump files.
Many thanks.
Inaki
Hi Josue,
 Here you can find the output of the different commands:
  1. # hostnamectl
         Chassis: desktop
         Boot ID: 0c921553aa0447e6814369ad62f67051
  1. # lspci​
  1. # modinfo iwlwifi
license:        GPL
retpoline:      Y
intree:         Y
sig_id:         PKCS#7
parm:           amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K (16K buffers ) 4: 2K (default 0) (int)
  1. # lsmod | grep iwlwifi​
  1. # dmesg | grep iwlwifi​
[    3.438941] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
[    3.448728] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-ty-a0-gf-a0-69.ucode failed with error -2
[    3.489377] iwlwifi 0000:02:00.0: api flags index 2 larger than supported by driver
[    3.489397] iwlwifi 0000:02:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
[    3.489703] iwlwifi 0000:02:00.0: loaded firmware version 68.01d30b0c.0 ty-a0-gf-a0-68.ucode op_mode iwlmvm
[    3.713069] iwlwifi 0000:02:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[    3.719368] iwlwifi 0000:02:00.0: WRT: Failed to set DRAM buffer for alloc id 1, ret=-1
[    3.719370] iwlwifi 0000:02:00.0: WRT: Failed to set DRAM buffer for alloc id 2, ret=-1
[    3.719371] iwlwifi 0000:02:00.0: WRT: Failed to set DRAM buffer for alloc id 3, ret=-1
[    3.883271] iwlwifi 0000:02:00.0: loaded PNVM version dda57f4f
[    3.898421] iwlwifi 0000:02:00.0: Detected RF GF, rfid=0x10d000
[    3.967180] iwlwifi 0000:02:00.0: base HW address: 80:45:dd:00:2c:2e
[    5.094033] iwlwifi 0000:02:00.0: WRT: Failed to set DRAM buffer for alloc id 1, ret=-1
[    5.094036] iwlwifi 0000:02:00.0: WRT: Failed to set DRAM buffer for alloc id 2, ret=-1
[    5.094038] iwlwifi 0000:02:00.0: WRT: Failed to set DRAM buffer for alloc id 3, ret=-1
[ 1070.857366] iwlwifi 0000:02:00.0: WRT: Collecting data: ini trigger 9 fired (delay=0ms).
  1. # dmesg | grep “no suitable firmware found!”​
No output
  1. # dmesg | grep ASSERT​
No output
I have attached the output of dmesg, trace and fw dump files.
Many thanks.
Madams500
I am having similar issues, if i do a fresh install of ubuntu 20.10 the 2G and 5G work but the 6G doesn't. Then if i upgrade to kernel 5.17 it doesn't recognize the card.
I am located in the UK but have access shielded rooms so could test with a US CC router.(AXE11000, RAX AX11000).
Samsung just rolled out firmware to enable 6G on the S21 so hopefully the AX210 should work now too.
no output
  • no output
  • no output
 Static hostname: Mini-PC
         Chassis: desktop
      Machine ID: 7833a840b58c4f8c832fc007e9dca68b
         Boot ID: 0be157533f0c4624af5a54c97de15b2c
Operating System: Ubuntu 21.10
          Kernel: Linux 5.17.0-051700-generic
 Hardware Vendor: System manufacturer
  Hardware Model: System Product Name
test@Mini-PC:~$ lspci
00:00.0 Host bridge: Intel Corporation 8th Gen Core 4-core Desktop Processor Host Bridge/DRAM Registers [Coffee Lake S] (rev 08)
00:02.0 VGA compatible controller: Intel Corporation CoffeeLake-S GT2 [UHD Graphics 630]
00:14.0 USB controller: Intel Corporation 200 Series/Z370 Chipset Family USB 3.0 xHCI Controller
00:16.0 Communication controller: Intel Corporation 200 Series PCH CSME HECI #1
00:17.0 SATA controller: Intel Corporation 200 Series PCH SATA controller [AHCI mode]
00:1c.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #5 (rev f0)
00:1d.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #11 (rev f0)
00:1d.3 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #12 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Device a2ca
00:1f.2 Memory controller: Intel Corporation 200 Series/Z370 Chipset Family Power Management Controller
00:1f.3 Audio device: Intel Corporation 200 Series PCH HD Audio
00:1f.4 SMBus: Intel Corporation 200 Series/Z370 Chipset Family SMBus Controller
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
03:00.0 Network controller: Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz (rev 1a)
test@Mini-PC:~$
test@Mini-PC:~$ modinfo iwlwifi
filename:       /lib/modules/5.17.0-051700-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license:        GPL
srcversion:     90AD006C0D02DE6626B0F30
retpoline:      Y
intree:         Y
vermagic:       5.17.0-051700-generic SMP preempt mod_unload modversions
sig_id:         PKCS#7
sig_key:        4D:52:57:D9:97:90:FC:E6:54:B7:6D:19:47:7C:65:F8:2C:0F:18:70
signature:      1D:FF:D6:7F:21:A4:C0:74:DD:77:BE:43:FE:8F:D7:54:BD:E7:3A:8F:
		4D:4B:A9:94:92:21:53:F7:97:74:25:9A:2B:83:24:6C:AF:63:60:DB:
		E8:5E:A0:34:84:CE:4D:DE:7E:91:84:DA:F8:93:7B:E7:B4:66:87:22:
		33:53:EF:83:93:05:90:E4:C8:A6:CF:E6:26:3A:4C:EE:E0:58:68:54:
		19:D4:C2:D7:2A:98:0D:89:BE:CB:76:7E:B1:AC:16:F4:5F:99:B9:CE:
		64:47:73:DF:7E:1C:58:C2:B7:54:2B:D3:65:74:35:1C:02:15:AE:EB:
		97:12:C7:73:0F:B9:07:D9:AD:4F:36:9F:FD:BE:A2:BF:12:16:1F:4F:
		CA:43:C4:74:78:E2:35:2D:DA:89:2B:CA:4D:53:DF:10:DB:3F:57:99:
		C4:37:77:50:0C:80:51:80:89:53:0E:5C:5C:87:CC:9E:2F:4E:D7:A7:
		3F:14:71:17:22:5E:E9:62:D8:4F:C8:C6:A4:C9:1F:71:46:B9:8F:7A:
		1E:8F:82:BB:29:04:24:01:96:1C:35:97:13:05:AF:6C:D1:53:2C:D8:
		FD:CE:3E:6E:88:FE:B5:26:F8:4F:FE:09:90:BC:E7:EE:B4:3F:98:A0:
		24:DF:ED:CB:30:5C:80:48:6B:AA:34:7D:3D:18:E4:B5:E1:6F:20:03:
		91:D3:9B:BB:3A:BF:B9:E1:79:FB:A9:78:3A:07:32:1B:A7:83:87:08:
		26:B6:82:C4:CC:16:5B:EA:95:A0:D6:2E:26:BB:C2:52:56:54:7F:DC:
		0C:29:46:DB:16:9A:31:5F:C1:21:EA:89:3B:E1:7C:7C:10:75:EC:EF:
		41:02:7F:6C:77:9B:A3:5A:92:10:50:EC:1B:0F:A7:16:72:13:C1:6C:
		7F:56:2F:9D:0F:E8:63:09:DB:5B:0C:87:16:8B:BD:64:1D:BE:02:39:
		5F:7E:D5:4B:BA:EB:6B:6F:A5:A4:07:C6:A5:3E:8F:61:C2:11:34:B3:
		03:ED:12:CA:75:6D:F2:DD:B3:DD:35:25:E8:9A:FB:6D:34:12:07:A9:
		79:F0:E3:ED:80:E8:5B:AA:02:E0:65:83:B0:83:3C:3B:BD:26:FD:CD:
		BC:DA:4C:7F:6D:ED:07:C4:48:93:0D:44:75:C1:57:FD:08:9D:FD:8F:
		5C:0E:A2:72:6F:02:46:6E:07:8E:1B:65:D2:AD:A8:7F:82:B7:30:92:
		10:4B:E6:89:A5:DB:29:F7:80:44:B2:3D:A2:35:40:2D:76:6D:11:AF:
		68:F5:08:C1:E1:2E:8F:A1:68:0F:0C:D4:BA:10:BD:0F:1A:84:83:43:
		7B:84:B5:22:F7:9C:42:38:FA:F1:23:C8
test@Mini-PC:~$
Inaki
Edit: remove repeated message.
Inaki
Inaki
 I have executed "iw phy0 info" (attached output), and it can be seen that 6GHz channels are disabled:
Frequencies:
* 5955 MHz [1] (disabled)
* 5975 MHz [5] (disabled)
* 5995 MHz [9] (disabled)
* 6015 MHz [13] (disabled)
* 6035 MHz [17] (disabled)
* 6055 MHz [21] (disabled)
* 6075 MHz [25] (disabled)
* 6095 MHz [29] (disabled)
* 6115 MHz [33] (disabled)
* 6135 MHz [37] (disabled)
* 6155 MHz [41] (disabled)
* 6175 MHz [45] (disabled)
* 6195 MHz [49] (disabled)
* 6215 MHz [53] (disabled)
* 6235 MHz [57] (disabled)
* 6255 MHz [61] (disabled)
* 6275 MHz [65] (disabled)
* 6295 MHz [69] (disabled)
* 6315 MHz [73] (disabled)
* 6335 MHz [77] (disabled)
* 6355 MHz [81] (disabled)
* 6375 MHz [85] (disabled)
* 6395 MHz [89] (disabled)
* 6415 MHz [93] (disabled)
* 6435 MHz [97] (disabled)
* 6455 MHz [101] (disabled)
* 6475 MHz [105] (disabled)
* 6495 MHz [109] (disabled)
* 6515 MHz [113] (disabled)
* 6535 MHz [117] (disabled)
* 6555 MHz [121] (disabled)
* 6575 MHz [125] (disabled)
* 6595 MHz [129] (disabled)
* 6615 MHz [133] (disabled)
* 6635 MHz [137] (disabled)
* 6655 MHz [141] (disabled)
* 6675 MHz [145] (disabled)
* 6695 MHz [149] (disabled)
* 6715 MHz [153] (disabled)
* 6735 MHz [157] (disabled)
* 6755 MHz [161] (disabled)
* 6775 MHz [165] (disabled)
* 6795 MHz [169] (disabled)
* 6815 MHz [173] (disabled)
* 6835 MHz [177] (disabled)
* 6855 MHz [181] (disabled)
* 6875 MHz [185] (disabled)
* 6895 MHz [189] (disabled)
* 6915 MHz [193] (disabled)
* 6935 MHz [197] (disabled)
* 6955 MHz [201] (disabled)
* 6975 MHz [205] (disabled)
* 6995 MHz [209] (disabled)
* 7015 MHz [213] (disabled)
* 7035 MHz [217] (disabled)
* 7055 MHz [221] (disabled)
* 7075 MHz [225] (disabled)
* 7095 MHz [229] (disabled)
* 7115 MHz [233] (disabled)
Many thanks.
JosueO_Intel
Hello Inaki,
Thank you for the information provided,
We will continue investigating the issue and post back soon with more details.
Josue O.
JosueO_Intel
Hello Inaki,
Hope you are doing great and staying safe, we are sorry for our delayed response.
In this case, please share with us the following information:
According to Aruba AP manual https://manuals.plus/aruba/630-series-campus-access-points-manual:
'Operations in the 6GHz band are blocked by firmware for some countries'
Q1: Has the 'Aruba AP-635' been updated to the latest firmware and the 6GHz band is unlocked?
Q2: And when the AX210 scans the air, it actually can't detect the Aruba AP SSID in 6GHz, right?
Q3: Are there other WLANs scan and connect to the SSID in 6GHz successfully?
Q4: On the Gigabyte machine, please provide the output of # iw reg get
Josue O.
JosueO_Intel
Hello Inaki,
Josue O.
Inaki
Hi Josue,
 Thank you for your response. Indeed I updated the Aruba's firmware, and after doing a scan, I see that the 6GHz channel become unlocked. So now I manage for getting a 6GHz connection.
Many thanks.
JosueO_Intel
Hello Inaki,
I am glad to hear that the issue is now solved and everything is working fine.
Josue O.
