Wireless
9046 Discussions
AX210 Firmware Load Error on Raspberry PI running Ubuntu.
artroup
I am trying to run an AX210 on a Raspberry PI 5 with Ubuntu 23.10 and/or 24.04. I have successfully be able to get the AX210 to provide an interface with the stock Ubuntu OS images when booting from an SD card. However when I boot from an SSD one a board with a PCI switch so I can run both the SSD and AX210, the firmware is unable to load and I dont not receive a WiFi interface from the AX210.
  1. uname -srm
    Linux 6.5.0-1017-raspi aarch64
  2. lspci
    0000:00:00.0 PCI bridge: Broadcom Inc. and subsidiaries Device 2712 (rev 21)
    0000:01:00.0 PCI bridge: ASMedia Technology Inc. ASM1182e 2-Port PCIe x1 Gen2 Packet Switch
    0000:02:03.0 PCI bridge: ASMedia Technology Inc. ASM1182e 2-Port PCIe x1 Gen2 Packet Switch
    0000:02:07.0 PCI bridge: ASMedia Technology Inc. ASM1182e 2-Port PCIe x1 Gen2 Packet Switch
    0000:03:00.0 Network controller: Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz (rev 1a)
    0000:04:00.0 Non-Volatile memory controller: Phison Electronics Corporation PS5021-E21 PCIe4 NVMe Controller (DRAM-less) (rev 01)
    0001:00:00.0 PCI bridge: Broadcom Inc. and subsidiaries Device 2712 (rev 21)
    0001:01:00.0 Ethernet controller: Device 1de4:0001
  3. sudo lshw -C network
      *-network
           description: Network controller
           product: Wi-Fi 6 AX210/AX211/AX411 160MHz
           vendor: Intel Corporation
           physical id: 0
           bus info: pci@0000:03:00.0
           version: 1a
           width: 64 bits
           clock: 33MHz
           capabilities: pm msi pciexpress msix bus_master cap_list
           configuration: driver=iwlwifi latency=0
           resources: irq:173 memory:1b00000000-1b00003fff
      *-network
           description: Ethernet controller
           physical id: 0
           bus info: pci@0001:01:00.0
           version: 00
           width: 32 bits
           clock: 33MHz
           capabilities: pm pciexpress msix bus_master cap_list
           configuration: driver=rp1 latency=0
           resources: irq:46 memory:1f00410000-1f00413fff memory:1f00000000-1f003fffff memory:1f00400000-1f0040ffff
      *-interface:0 DISABLED
           description: Wireless interface
           product: 4345
           vendor: Broadcom
           physical id: 1
           bus info: mmc@1:0001:1
           logical name: mmc1:0001:1
           logical name: wlan0
           serial: d8:3a:dd:e7:8d:35
           capabilities: ethernet physical wireless
           configuration: broadcast=yes driver=brcmfmac driverversion=7.45.241 firmware=01-703fd60 multicast=yes wireless=IEEE 802.11
      *-network
           description: Ethernet interface
           physical id: 9
           logical name: eth0
           serial: d8:3a:dd:e7:8d:34
           capacity: 1Gbit/s
           capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
           configuration: autonegotiation=on broadcast=yes driver=macb driverversion=6.5.0-1017-raspi duplex=full ip=192.168.1.153 link=yes multicast=yes port=twisted pair speed=1Gbit/s
  4. sudo dmesg | grep iwl
    [    6.289191] iwlwifi 0000:03:00.0: enabling device (0000 -> 0002)
    [    6.322564] iwlwifi 0000:03:00.0: Detected crf-id 0x400410, cnv-id 0x400410 wfpm id 0x80000000
    [    6.322580] iwlwifi 0000:03:00.0: PCI dev 2725/0024, rev=0x420, rfid=0x10d000
    [    6.339023] iwlwifi 0000:03:00.0: api flags index 2 larger than supported by driver
    [    6.339064] iwlwifi 0000:03:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.41
    [    6.340349] iwlwifi 0000:03:00.0: loaded firmware version 83.e8f84e98.0 ty-a0-gf-a0-83.ucode op_mode iwlmvm
    [    6.480865] iwlwifi 0000:03:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
    [    6.510137] iwlwifi 0000:03:00.0: WRT: Invalid buffer destination
    [    6.681006] iwlwifi 0000:03:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
    [    6.681036] iwlwifi 0000:03:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
    [    6.681064] iwlwifi 0000:03:00.0: WFPM_AUTH_KEY_0: 0x90
    [    6.681081] iwlwifi 0000:03:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
    [    6.682075] iwlwifi 0000:03:00.0: loaded PNVM version e28bb9d7
    [    6.930924] iwlwifi 0000:03:00.0: Timeout waiting for PNVM load!
    [    6.936997] iwlwifi 0000:03:00.0: Failed to start RT ucode: -110
    [    6.943066] iwlwifi 0000:03:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
    [    6.944466] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
    [    6.950113] iwlwifi 0000:03:00.0: Transport status: 0x00000042, valid: 6
    [    6.958001] iwlwifi 0000:03:00.0: Loaded firmware version: 83.e8f84e98.0 ty-a0-gf-a0-83.ucode
    [    6.967213] iwlwifi 0000:03:00.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
    [    6.974268] iwlwifi 0000:03:00.0: 0x002002F0 | trm_hw_status0
    [    6.980492] iwlwifi 0000:03:00.0: 0x00000000 | trm_hw_status1
    [    6.986315] iwlwifi 0000:03:00.0: 0x004DC410 | branchlink2
    [    6.991848] iwlwifi 0000:03:00.0: 0x004D233E | interruptlink1
    [    6.997637] iwlwifi 0000:03:00.0: 0x004D233E | interruptlink2
    [    7.003420] iwlwifi 0000:03:00.0: 0x0001698A | data1
    [    7.008420] iwlwifi 0000:03:00.0: 0x01000000 | data2
    [    7.013417] iwlwifi 0000:03:00.0: 0x00000000 | data3
    [    7.013420] iwlwifi 0000:03:00.0: 0x00000000 | beacon time
    [    7.013422] iwlwifi 0000:03:00.0: 0x00052FEF | tsf low
    [    7.013424] iwlwifi 0000:03:00.0: 0x00000000 | tsf hi
    [    7.013426] iwlwifi 0000:03:00.0: 0x00000000 | time gp1
    [    7.039385] iwlwifi 0000:03:00.0: 0x00067A56 | time gp2
    [    7.039388] iwlwifi 0000:03:00.0: 0x00000001 | uCode revision type
    [    7.039390] iwlwifi 0000:03:00.0: 0x00000053 | uCode version major
    [    7.039392] iwlwifi 0000:03:00.0: 0xE8F84E98 | uCode version minor
    [    7.063244] iwlwifi 0000:03:00.0: 0x00000420 | hw version
    [    7.063246] iwlwifi 0000:03:00.0: 0x00C80002 | board version
    [    7.063248] iwlwifi 0000:03:00.0: 0x8004FC12 | hcmd
    [    7.063250] iwlwifi 0000:03:00.0: 0x00020000 | isr0
    [    7.063252] iwlwifi 0000:03:00.0: 0x00000000 | isr1
    [    7.063253] iwlwifi 0000:03:00.0: 0x48F00002 | isr2
    [    7.063255] iwlwifi 0000:03:00.0: 0x00C0001C | isr3
    [    7.063256] iwlwifi 0000:03:00.0: 0x00000000 | isr4
    [    7.063258] iwlwifi 0000:03:00.0: 0x00000000 | last cmd Id
    [    7.109216] iwlwifi 0000:03:00.0: 0x0001698A | wait_event
    [    7.109219] iwlwifi 0000:03:00.0: 0x00000000 | l2p_control
    [    7.109220] iwlwifi 0000:03:00.0: 0x00000000 | l2p_duration
    [    7.109222] iwlwifi 0000:03:00.0: 0x00000000 | l2p_mhvalid
    [    7.109224] iwlwifi 0000:03:00.0: 0x00000000 | l2p_addr_match
    [    7.137025] iwlwifi 0000:03:00.0: 0x00000009 | lmpm_pmg_sel
    [    7.137027] iwlwifi 0000:03:00.0: 0x00000000 | timestamp
    [    7.137028] iwlwifi 0000:03:00.0: 0x00000020 | flow_handler
    [    7.137089] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
    [    7.159144] iwlwifi 0000:03:00.0: Transport status: 0x00000042, valid: 7
    [    7.159148] iwlwifi 0000:03:00.0: 0x20000066 | NMI_INTERRUPT_HOST
    [    7.159150] iwlwifi 0000:03:00.0: 0x00000000 | umac branchlink1
    [    7.177938] iwlwifi 0000:03:00.0: 0x8046DA58 | umac branchlink2
    [    7.177941] iwlwifi 0000:03:00.0: 0x8048DF3E | umac interruptlink1
    [    7.190087] iwlwifi 0000:03:00.0: 0x8048DF3E | umac interruptlink2
    [    7.190089] iwlwifi 0000:03:00.0: 0x01000000 | umac data1
    [    7.190091] iwlwifi 0000:03:00.0: 0x8048DF3E | umac data2
    [    7.207130] iwlwifi 0000:03:00.0: 0x00000000 | umac data3
    [    7.212550] iwlwifi 0000:03:00.0: 0x00000053 | umac major
    [    7.217985] iwlwifi 0000:03:00.0: 0xE8F84E98 | umac minor
    [    7.223414] iwlwifi 0000:03:00.0: 0x00067A54 | frame pointer
    [    7.229099] iwlwifi 0000:03:00.0: 0xC0886258 | stack pointer
    [    7.234781] iwlwifi 0000:03:00.0: 0x00000000 | last host cmd
    [    7.240464] iwlwifi 0000:03:00.0: 0x00000400 | isr status reg
    [    7.246260] iwlwifi 0000:03:00.0: IML/ROM dump:
    [    7.250810] iwlwifi 0000:03:00.0: 0x00000B03 | IML/ROM error/state
    [    7.257044] iwlwifi 0000:03:00.0: 0x00008595 | IML/ROM data1
    [    7.262743] iwlwifi 0000:03:00.0: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
    [    7.269305] iwlwifi 0000:03:00.0: Fseq Registers:
    [    7.274031] iwlwifi 0000:03:00.0: 0x20000000 | FSEQ_ERROR_CODE
    [    7.279890] iwlwifi 0000:03:00.0: 0x80440007 | FSEQ_TOP_INIT_VERSION
    [    7.286274] iwlwifi 0000:03:00.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
    [    7.292832] iwlwifi 0000:03:00.0: 0x0000A652 | FSEQ_OTP_VERSION
    [    7.298778] iwlwifi 0000:03:00.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
    [    7.305422] iwlwifi 0000:03:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
    [    7.311368] iwlwifi 0000:03:00.0: 0x00400410 | FSEQ_CNVI_ID
    [    7.316965] iwlwifi 0000:03:00.0: 0x00400410 | FSEQ_CNVR_ID
    [    7.322561] iwlwifi 0000:03:00.0: 0x00400410 | CNVI_AUX_MISC_CHIP
    [    7.328686] iwlwifi 0000:03:00.0: 0x00400410 | CNVR_AUX_MISC_CHIP
    [    7.334810] iwlwifi 0000:03:00.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
    [    7.342679] iwlwifi 0000:03:00.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
    [    7.350894] iwlwifi 0000:03:00.0: 0x00000000 | FSEQ_PREV_CNVIO_INIT_VERSION
    [    7.357888] iwlwifi 0000:03:00.0: 0x00440007 | FSEQ_WIFI_FSEQ_VERSION
    [    7.364357] iwlwifi 0000:03:00.0: 0x1698BAA6 | FSEQ_BT_FSEQ_VERSION
    [    7.370652] iwlwifi 0000:03:00.0: 0x000000E6 | FSEQ_CLASS_TP_VERSION
    [    7.377053] iwlwifi 0000:03:00.0: UMAC CURRENT PC: 0x8048da0c
    [    7.382829] iwlwifi 0000:03:00.0: LMAC1 CURRENT PC: 0xd0
    [    8.338928] iwlwifi 0000:03:00.0: Failed to run INIT ucode: -110
    [    8.357317] iwlwifi 0000:03:00.0: retry init count 0
    [    8.363225] iwlwifi 0000:03:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
    [    8.373480] iwlwifi 0000:03:00.0: WRT: Invalid buffer destination
    [    8.540300] iwlwifi 0000:03:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
    [    8.540335] iwlwifi 0000:03:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
    [    8.540352] iwlwifi 0000:03:00.0: WFPM_AUTH_KEY_0: 0x90
    [    8.540380] iwlwifi 0000:03:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
    [    8.790901] iwlwifi 0000:03:00.0: Timeout waiting for PNVM load!
    [    8.796941] iwlwifi 0000:03:00.0: Failed to start RT ucode: -110
    [    8.802999] iwlwifi 0000:03:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
    [    8.804165] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
    [    8.809772] iwlwifi 0000:03:00.0: Transport status: 0x00000042, valid: 6
    [    8.816518] iwlwifi 0000:03:00.0: Loaded firmware version: 83.e8f84e98.0 ty-a0-gf-a0-83.ucode
    [    8.825080] iwlwifi 0000:03:00.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
    [    8.832069] iwlwifi 0000:03:00.0: 0x002002F0 | trm_hw_status0
    [    8.837841] iwlwifi 0000:03:00.0: 0x00000000 | trm_hw_status1
    [    8.843609] iwlwifi 0000:03:00.0: 0x004DC410 | branchlink2
    [    8.849126] iwlwifi 0000:03:00.0: 0x004D233E | interruptlink1
    [    8.854895] iwlwifi 0000:03:00.0: 0x004D233E | interruptlink2
    [    8.860667] iwlwifi 0000:03:00.0: 0x0001698A | data1
    [    8.865649] iwlwifi 0000:03:00.0: 0x01000000 | data2
    [    8.870631] iwlwifi 0000:03:00.0: 0x00000000 | data3
    [    8.875613] iwlwifi 0000:03:00.0: 0x00000000 | beacon time
    [    8.881122] iwlwifi 0000:03:00.0: 0x00052010 | tsf low
    [    8.886280] iwlwifi 0000:03:00.0: 0x00000000 | tsf hi
    [    8.891352] iwlwifi 0000:03:00.0: 0x00000000 | time gp1
    [    8.896598] iwlwifi 0000:03:00.0: 0x000669BE | time gp2
    [    8.901845] iwlwifi 0000:03:00.0: 0x00000001 | uCode revision type
    [    8.908050] iwlwifi 0000:03:00.0: 0x00000053 | uCode version major
    [    8.914258] iwlwifi 0000:03:00.0: 0xE8F84E98 | uCode version minor
    [    8.920464] iwlwifi 0000:03:00.0: 0x00000420 | hw version
    [    8.925886] iwlwifi 0000:03:00.0: 0x18C80002 | board version
    [    8.931567] iwlwifi 0000:03:00.0: 0x8004FC12 | hcmd
    [    8.936465] iwlwifi 0000:03:00.0: 0x00020000 | isr0
    [    8.941360] iwlwifi 0000:03:00.0: 0x00000000 | isr1
    [    8.946255] iwlwifi 0000:03:00.0: 0x48F00002 | isr2
    [    8.951149] iwlwifi 0000:03:00.0: 0x00C0001C | isr3
    [    8.956043] iwlwifi 0000:03:00.0: 0x00000000 | isr4
    [    8.960941] iwlwifi 0000:03:00.0: 0x00000000 | last cmd Id
    [    8.966447] iwlwifi 0000:03:00.0: 0x0001698A | wait_event
    [    8.971869] iwlwifi 0000:03:00.0: 0x00000000 | l2p_control
    [    8.977376] iwlwifi 0000:03:00.0: 0x00000000 | l2p_duration
    [    8.982968] iwlwifi 0000:03:00.0: 0x00000000 | l2p_mhvalid
    [    8.988474] iwlwifi 0000:03:00.0: 0x00000000 | l2p_addr_match
    [    8.994244] iwlwifi 0000:03:00.0: 0x00000009 | lmpm_pmg_sel
    [    8.999837] iwlwifi 0000:03:00.0: 0x00000000 | timestamp
    [    9.005172] iwlwifi 0000:03:00.0: 0x00000020 | flow_handler
    [    9.010820] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
    [    9.016416] iwlwifi 0000:03:00.0: Transport status: 0x00000042, valid: 7
    [    9.023145] iwlwifi 0000:03:00.0: 0x20000066 | NMI_INTERRUPT_HOST
    [    9.029266] iwlwifi 0000:03:00.0: 0x00000000 | umac branchlink1
    [    9.035210] iwlwifi 0000:03:00.0: 0x8046DA58 | umac branchlink2
    [    9.041156] iwlwifi 0000:03:00.0: 0x8048DF3E | umac interruptlink1
    [    9.047362] iwlwifi 0000:03:00.0: 0x8048DF3E | umac interruptlink2
    [    9.053570] iwlwifi 0000:03:00.0: 0x01000000 | umac data1
    [    9.058990] iwlwifi 0000:03:00.0: 0x8048DF3E | umac data2
    [    9.064412] iwlwifi 0000:03:00.0: 0x00000000 | umac data3
    [    9.069831] iwlwifi 0000:03:00.0: 0x00000053 | umac major
    [    9.075250] iwlwifi 0000:03:00.0: 0xE8F84E98 | umac minor
    [    9.080668] iwlwifi 0000:03:00.0: 0x000669BC | frame pointer
    [    9.086351] iwlwifi 0000:03:00.0: 0xC0886258 | stack pointer
    [    9.092033] iwlwifi 0000:03:00.0: 0x00000000 | last host cmd
    [    9.097717] iwlwifi 0000:03:00.0: 0x00000400 | isr status reg
    [    9.103500] iwlwifi 0000:03:00.0: IML/ROM dump:
    [    9.108050] iwlwifi 0000:03:00.0: 0x00000B03 | IML/ROM error/state
    [    9.114269] iwlwifi 0000:03:00.0: 0x000085C5 | IML/ROM data1
    [    9.119963] iwlwifi 0000:03:00.0: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
    [    9.126524] iwlwifi 0000:03:00.0: Fseq Registers:
    [    9.131247] iwlwifi 0000:03:00.0: 0x60000000 | FSEQ_ERROR_CODE
    [    9.137105] iwlwifi 0000:03:00.0: 0x80440007 | FSEQ_TOP_INIT_VERSION
    [    9.143487] iwlwifi 0000:03:00.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
    [    9.150044] iwlwifi 0000:03:00.0: 0x0000A652 | FSEQ_OTP_VERSION
    [    9.155991] iwlwifi 0000:03:00.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
    [    9.162635] iwlwifi 0000:03:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
    [    9.168580] iwlwifi 0000:03:00.0: 0x00400410 | FSEQ_CNVI_ID
    [    9.174177] iwlwifi 0000:03:00.0: 0x00400410 | FSEQ_CNVR_ID
    [    9.179774] iwlwifi 0000:03:00.0: 0x00400410 | CNVI_AUX_MISC_CHIP
    [    9.185896] iwlwifi 0000:03:00.0: 0x00400410 | CNVR_AUX_MISC_CHIP
    [    9.192018] iwlwifi 0000:03:00.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
    [    9.199887] iwlwifi 0000:03:00.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
    [    9.208102] iwlwifi 0000:03:00.0: 0x00080009 | FSEQ_PREV_CNVIO_INIT_VERSION
    [    9.215095] iwlwifi 0000:03:00.0: 0x00440007 | FSEQ_WIFI_FSEQ_VERSION
    [    9.221565] iwlwifi 0000:03:00.0: 0x1698BAA6 | FSEQ_BT_FSEQ_VERSION
    [    9.227860] iwlwifi 0000:03:00.0: 0x000000E6 | FSEQ_CLASS_TP_VERSION
    [    9.234265] iwlwifi 0000:03:00.0: UMAC CURRENT PC: 0x8048da0c
    [    9.240043] iwlwifi 0000:03:00.0: LMAC1 CURRENT PC: 0xd0
    [   10.194046] iwlwifi 0000:03:00.0: Failed to run INIT ucode: -110
    [   10.212523] iwlwifi 0000:03:00.0: retry init count 1
    [   10.218330] iwlwifi 0000:03:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
    [   10.241120] iwlwifi 0000:03:00.0: WRT: Invalid buffer destination
    [   10.406856] iwlwifi 0000:03:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
    [   10.406891] iwlwifi 0000:03:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
    [   10.406907] iwlwifi 0000:03:00.0: WFPM_AUTH_KEY_0: 0x90
    [   10.406936] iwlwifi 0000:03:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
    [   10.658913] iwlwifi 0000:03:00.0: Timeout waiting for PNVM load!
    [   10.664966] iwlwifi 0000:03:00.0: Failed to start RT ucode: -110
    [   10.671011] iwlwifi 0000:03:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
    [   10.672175] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
    [   10.677772] iwlwifi 0000:03:00.0: Transport status: 0x00000042, valid: 6
    [   10.684500] iwlwifi 0000:03:00.0: Loaded firmware version: 83.e8f84e98.0 ty-a0-gf-a0-83.ucode
    [   10.693065] iwlwifi 0000:03:00.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
    [   10.700057] iwlwifi 0000:03:00.0: 0x002002F0 | trm_hw_status0
    [   10.705829] iwlwifi 0000:03:00.0: 0x00000000 | trm_hw_status1
    [   10.711597] iwlwifi 0000:03:00.0: 0x004DC410 | branchlink2
    [   10.717107] iwlwifi 0000:03:00.0: 0x004D233E | interruptlink1
    [   10.722875] iwlwifi 0000:03:00.0: 0x004D233E | interruptlink2
    [   10.728647] iwlwifi 0000:03:00.0: 0x0001698A | data1
    [   10.733630] iwlwifi 0000:03:00.0: 0x01000000 | data2
    [   10.738612] iwlwifi 0000:03:00.0: 0x00000000 | data3
    [   10.743594] iwlwifi 0000:03:00.0: 0x00000000 | beacon time
    [   10.749103] iwlwifi 0000:03:00.0: 0x000525AA | tsf low
    [   10.754260] iwlwifi 0000:03:00.0: 0x00000000 | tsf hi
    [   10.759333] iwlwifi 0000:03:00.0: 0x00000000 | time gp1
    [   10.764578] iwlwifi 0000:03:00.0: 0x00066F5D | time gp2
    [   10.769834] iwlwifi 0000:03:00.0: 0x00000001 | uCode revision type
    [   10.776040] iwlwifi 0000:03:00.0: 0x00000053 | uCode version major
    [   10.782248] iwlwifi 0000:03:00.0: 0xE8F84E98 | uCode version minor
    [   10.788455] iwlwifi 0000:03:00.0: 0x00000420 | hw version
    [   10.793878] iwlwifi 0000:03:00.0: 0x18C80002 | board version
    [   10.799566] iwlwifi 0000:03:00.0: 0x8004FC12 | hcmd
    [   10.804466] iwlwifi 0000:03:00.0: 0x00020000 | isr0
    [   10.809361] iwlwifi 0000:03:00.0: 0x00000000 | isr1
    [   10.814256] iwlwifi 0000:03:00.0: 0x48F00002 | isr2
    [   10.819151] iwlwifi 0000:03:00.0: 0x00C0001C | isr3
    [   10.824045] iwlwifi 0000:03:00.0: 0x00000000 | isr4
    [   10.828944] iwlwifi 0000:03:00.0: 0x00000000 | last cmd Id
    [   10.834450] iwlwifi 0000:03:00.0: 0x0001698A | wait_event
    [   10.839872] iwlwifi 0000:03:00.0: 0x00000000 | l2p_control
    [   10.845379] iwlwifi 0000:03:00.0: 0x00000000 | l2p_duration
    [   10.850972] iwlwifi 0000:03:00.0: 0x00000000 | l2p_mhvalid
    [   10.856478] iwlwifi 0000:03:00.0: 0x00000000 | l2p_addr_match
    [   10.862248] iwlwifi 0000:03:00.0: 0x00000009 | lmpm_pmg_sel
    [   10.867843] iwlwifi 0000:03:00.0: 0x00000000 | timestamp
    [   10.873178] iwlwifi 0000:03:00.0: 0x00000020 | flow_handler
    [   10.878825] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
    [   10.884422] iwlwifi 0000:03:00.0: Transport status: 0x00000042, valid: 7
    [   10.891151] iwlwifi 0000:03:00.0: 0x20000066 | NMI_INTERRUPT_HOST
    [   10.897273] iwlwifi 0000:03:00.0: 0x00000000 | umac branchlink1
    [   10.903217] iwlwifi 0000:03:00.0: 0x8046DA58 | umac branchlink2
    [   10.909160] iwlwifi 0000:03:00.0: 0x8048DF3E | umac interruptlink1
    [   10.915366] iwlwifi 0000:03:00.0: 0x8048DF3E | umac interruptlink2
    [   10.921570] iwlwifi 0000:03:00.0: 0x01000000 | umac data1
    [   10.926993] iwlwifi 0000:03:00.0: 0x8048DF3E | umac data2
    [   10.932417] iwlwifi 0000:03:00.0: 0x00000000 | umac data3
    [   10.937836] iwlwifi 0000:03:00.0: 0x00000053 | umac major
    [   10.943258] iwlwifi 0000:03:00.0: 0xE8F84E98 | umac minor
    [   10.948678] iwlwifi 0000:03:00.0: 0x00066F5B | frame pointer
    [   10.954361] iwlwifi 0000:03:00.0: 0xC0886258 | stack pointer
    [   10.960043] iwlwifi 0000:03:00.0: 0x00000000 | last host cmd
    [   10.965728] iwlwifi 0000:03:00.0: 0x00000400 | isr status reg
    [   10.971511] iwlwifi 0000:03:00.0: IML/ROM dump:
    [   10.976061] iwlwifi 0000:03:00.0: 0x00000B03 | IML/ROM error/state
    [   10.982279] iwlwifi 0000:03:00.0: 0x000085C7 | IML/ROM data1
    [   10.987974] iwlwifi 0000:03:00.0: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
    [   10.994534] iwlwifi 0000:03:00.0: Fseq Registers:
    [   10.999258] iwlwifi 0000:03:00.0: 0x60000000 | FSEQ_ERROR_CODE
    [   11.005117] iwlwifi 0000:03:00.0: 0x80440007 | FSEQ_TOP_INIT_VERSION
    [   11.011499] iwlwifi 0000:03:00.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
    [   11.018056] iwlwifi 0000:03:00.0: 0x0000A652 | FSEQ_OTP_VERSION
    [   11.024002] iwlwifi 0000:03:00.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
    [   11.030647] iwlwifi 0000:03:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
    [   11.036592] iwlwifi 0000:03:00.0: 0x00400410 | FSEQ_CNVI_ID
    [   11.042189] iwlwifi 0000:03:00.0: 0x00400410 | FSEQ_CNVR_ID
    [   11.047786] iwlwifi 0000:03:00.0: 0x00400410 | CNVI_AUX_MISC_CHIP
    [   11.053908] iwlwifi 0000:03:00.0: 0x00400410 | CNVR_AUX_MISC_CHIP
    [   11.060031] iwlwifi 0000:03:00.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
    [   11.067899] iwlwifi 0000:03:00.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
    [   11.076115] iwlwifi 0000:03:00.0: 0x00080009 | FSEQ_PREV_CNVIO_INIT_VERSION
    [   11.083108] iwlwifi 0000:03:00.0: 0x00440007 | FSEQ_WIFI_FSEQ_VERSION
    [   11.089578] iwlwifi 0000:03:00.0: 0x1698BAA6 | FSEQ_BT_FSEQ_VERSION
    [   11.095873] iwlwifi 0000:03:00.0: 0x000000E6 | FSEQ_CLASS_TP_VERSION
    [   11.102278] iwlwifi 0000:03:00.0: UMAC CURRENT PC: 0x8048da0c
    [   11.108056] iwlwifi 0000:03:00.0: LMAC1 CURRENT PC: 0xd0
    [   12.062409] iwlwifi 0000:03:00.0: Failed to run INIT ucode: -110
    [   12.080874] iwlwifi 0000:03:00.0: retry init count 2
  5. iwconfig. *wlan0 is the internal WiFi nic on the Pi board, I should have two WiFi Interafces
    lo        no wireless extensions.
    eth0      no wireless extensions.
    wlan0     IEEE 802.11  ESSID:off/any
              Mode:Managed  Access Point: Not-Associated
              Retry short limit:7   RTS thr:off   Fragment thr:off
              Power Management:on
  6. Please see attached raspberrypi.txt file for the ssu.sh output.
RamyerM_Intel
Hello artroup,
Thank you for posting in the communities and for sharing this details. I will proceed in coordinating this concern with our team and get back to you as soon as possible.
Ramyer M.
RamyerM_Intel
Hello artroup,
Upon coordinating with our team. I want to let you know that the error logs indicate a timeout waiting for the Protected Non-Volatile Memory (PNVM) load and failure to start the runtime (RT) microcode (ucode), with error code -110, which typically signifies a timeout error. In light of this, we want to ask if you have already reached out to  Raspberry Pi for insights on integration, as they might have made modifications to the software or hardware that they supply.
You may also check out this article for more details: Regulatory Information Regarding Wireless Hardware Installation or Upgrade
We also highly recommend to try and update the Linux kernel and firmware as it can improve your system. However, the best course of action would still be consulting with the Raspberry Pi as they are best suited to handled this product.
Ramyer M.
artroup
Thanks. I’m seeing this on Ubuntu 24.04, 23.10 and raspberry pi os bookworm. This issue only happens when I am booting from ssd using a raspberry pi 5 and the ax210 behind a pcie bridge/switch like in the pineboat hatdrive ai board. Works find when I just us the ax210 running directly connect to the pcie lane and booting from and sd card. So I don’t feel like it’s a kernel or firmware version issue
RamyerM_Intel
Hello artroup
Thank you for sharing this additional detail. It would still be best to reach out to your Original Equipment Manufacturer for a more thorough investigation as this is an Original Equipment Manufacturer Device and you are required to follow post approval instructions from Raspberry Pi prior to the integration of the wireless card. Have you tried reaching out to them? How did it go?
Ramyer M.
