Wireless
8782 Discussions
AX210 NIC cannot be used as an AP in hostapd configuration channel=0
lrj
Hello, ubuntu system kernel 5.15
When I use AX210 to use hostapd as AP, I encountered a problem with the channel configuration about hostapd.conf, using channel=0 is configured as ACS, but he can't get the best channel through ACS, and it shows that the boot failed, and also do the modification with hostap, channel=1-13, you can start the AP, I want to know if the firmware supports ACS,And tried the 5.10+ firmware of the Intel official website, and the effect is the same as above, If it is also supported, please ask whether it is caused by hostapd, the dfconfig file of hostapd says: Supported ACS drivers *ath9k *ath5k *ath10k, which does not clearly indicate whether the AX210 firmware is supported. Includes hostapd 2.10 and development versions provided by the hostapd community. If the AX210 firmware supports ACS, please also help provide other AP tools that I can try.
I want to mention IPS, but I don't know how to select "Select Product".
lrj
我已提交IPS,并且得到了回复,谢谢
