Wireless
9008 Discussions
AX210 certifications under Linux with ARM
SLabe
Partner
Hello, looking for SW support to set following functions for certification and compliance testing.
Thank you,
In Wifi
Function to select the channel
Function to select the power output in dBm
Function to change Antenna mode
Function to change Transmission rates in Mbps
Selection of bandwidth (For example 20MHz, 40MHz)
In Bluetooth
Selection of TX or RX tests
Selection of frequency in MHz
Selection of TX or RX testsSelection of modulation mode (GFSK, DQPSK, BLE etc.)
Selection of test patterns
Selection of power level
AndrewG_Intel
Hello @SLabe
In regards to this request, we will send you an email with some details in order to point you to the proper channel of support.
We will send you the email to the emails address associated with your community account.
Andrew G.
nicolas_colombain
Hi Andew,
We have the same request for Intel AX200 used in a ARM Linux Gateway for an industrial indoor application.
Do you have documents and firmware to set up the module in TX continuous mode ?
Thanks in advance
Best regards
Nicolas
AndrewG_Intel
Hello SLabe
We hope that the information provided through email was helpful. We will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
TIKYAN
Hi Andrew,
We also have a issue regarding setting AX210 to a continuous TX mode for certification purpose, do you have any application note or firmware that may help.
TikYan
boomat
Hello Andrew, hello Intel Certifiaction Team,
I am also looking for SW support on ARM (LS1021a) to set special testing modes for certification and compliance testing. There is already DRTU Tooling which obviously does the right thing, but only for x86 plattforms. And in addition regarding 637351_DRTU_Integration_Guide_for_Linux_v1.2.pdf AX210 is not supported at all?!?
Could you clarify this.
Thank you.
Best regards
Mathias
