Wireless
8789 Discussions
AX210 not operating well under Pop_os linux, crippled, bad distance, slow
joshfg
Had a 9260 card in my Yoga c930. It worked fine with G/N/AC.  I have put in the ax210. WiFi 6E Wireless Card Intel AX210 NGW Bluetooth 5.3 Tri-Band 5400Mbps Network Adapter for Laptop Support Windows 10/11 (64bit) M.2/NGFF
This card barely connects to 2.4ghz and can't connect to 5ghz,  I have not tried 6 or 6e.
See attached files.
I had to rename all the updated ucode files because they didn't work at all.
I have not tested bluetooth at all.
ll iwlwifi-ty-a0-gf-a0*
-rw-r--r-- 1 root root 1413868 Oct 3 20:02 iwlwifi-ty-a0-gf-a0-59.ucode
-rw-r--r-- 1 root root 1455104 Jun 7 15:20 iwlwifi-ty-a0-gf-a0-62.ucode.bak
-rw-r--r-- 1 root root 1460012 Jun 7 15:20 iwlwifi-ty-a0-gf-a0-63.ucode.bak
-rw-r--r-- 1 root root 1481960 Jun 7 15:20 iwlwifi-ty-a0-gf-a0-66.ucode.bak
-rw-r--r-- 1 root root 1482872 Jun 7 15:20 iwlwifi-ty-a0-gf-a0-67.ucode.bak
-rw-r--r-- 1 root root 1494304 Jun 7 15:20 iwlwifi-ty-a0-gf-a0-68.ucode.bak
-rw-r--r-- 1 root root 1494024 Jun 7 15:20 iwlwifi-ty-a0-gf-a0-71.ucode.bak
-rw-r--r-- 1 root root 41588 Jun 7 15:20 iwlwifi-ty-a0-gf-a0.pnvm.bak
EDIT: I've upgraded to kernel 6.0.0-060000-generic and I have found that only iwlwifi-ty-a0-gf-a0-59.ucode works, 62-71 do not.  The problems persist.  I can connect  to 5ghz, can't connect to 2.4ghz.  Distance is terrible, speed is ehhhhh.  I have no tested bluetooth yet.
@linux
@pop_os
@Maria_R_Intel
