Wireless
8657 Discussions
AX210 slow since Linux kernel 6.5/6.6
Alawami
I'm experiencing a performance issue with the AX210 network adapter on kernel versions 6.6 (or 6.5?) and later. Download speeds, which easily exceeded 600 Mbps on kernel 6.4, now start at 300 Mbps and slow down to 30-200 Mbps. This issue is reproducible across multiple Linux distributions with kernel 6.6 or higher, but not on latest Debian which  uses much older kernel
here's iwlwifi dmesg log:
[    7.642883] iwlwifi 0000:21:00.0: enabling device (0000 -> 0002)
[    7.644529] iwlwifi 0000:21:00.0: Detected crf-id 0x400410, cnv-id 0x400410 wfpm id 0x80000000
[    7.644537] iwlwifi 0000:21:00.0: PCI dev 2725/0024, rev=0x420, rfid=0x10d000
[    7.716219] iwlwifi 0000:21:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.42
[    7.716580] iwlwifi 0000:21:00.0: loaded firmware version 89.202a2f7b.0 ty-a0-gf-a0-89.ucode op_mode iwlmvm
[    7.884984] iwlwifi 0000:21:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[    7.894479] iwlwifi 0000:21:00.0: WRT: Invalid buffer destination
[    8.048550] iwlwifi 0000:21:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
[    8.048575] iwlwifi 0000:21:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[    8.048591] iwlwifi 0000:21:00.0: WFPM_AUTH_KEY_0: 0x90
[    8.048610] iwlwifi 0000:21:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
[    8.051837] iwlwifi 0000:21:00.0: loaded PNVM version 35148b80
[    8.066851] iwlwifi 0000:21:00.0: Detected RF GF, rfid=0x10d000
[    8.135416] iwlwifi 0000:21:00.0: base HW address: fc:b3:bc:44:10:74
[    8.155911] iwlwifi 0000:21:00.0 wlo1: renamed from wlan0
[    9.898676] iwlwifi 0000:21:00.0: WRT: Invalid buffer destination
[   10.052705] iwlwifi 0000:21:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
[   10.052728] iwlwifi 0000:21:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[   10.052743] iwlwifi 0000:21:00.0: WFPM_AUTH_KEY_0: 0x90
[   10.052764] iwlwifi 0000:21:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
[   10.140514] iwlwifi 0000:21:00.0: Registered PHC clock: iwlwifi-PTP, with index: 0
[   10.184394] iwlwifi 0000:21:00.0: WRT: Invalid buffer destination
[   10.338549] iwlwifi 0000:21:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
[   10.338566] iwlwifi 0000:21:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[   10.338584] iwlwifi 0000:21:00.0: WFPM_AUTH_KEY_0: 0x90
[   10.338600] iwlwifi 0000:21:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
Alawami
update: running "sudo iw dev wlo1 set power_save off" is fixes the issue temporarily.
Alawami
Any update?
JedG_Intel
Hello Alawami,
Thank you for posting at Intel Community Forum
For me to properly address this concern, please share the following details:
  1. Have tried a roll back to a previous driver version for testing?
  2. Is this a laptop or desktop system?
  3. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
Additionally, to have a better understanding of your system configuration and components please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
I hope to hear from you soon!
Jed G.
Alawami
1. Rolling back to kernel 6.4 fixes the problem, anything above 6.6 have the issue
2. Desktop custom built.
3. wifi adapter installed personally 2 years ago.
Note: running "sudo iw dev wlo1 set power_save off" is fixes the issue temporarily
SSU file output is attached
thanks
JedG_Intel
Hello Alawami,
I've checked the logs that you attached and to help with your concern, I suggest that you download the latest wireless firmware for the Intel AX210 here - Linux* Support for Intel® Wireless Adapters
Jed G.
Alawami
Updating the firmware to the latest git makes no change. The problem still exists
JedG_Intel
Hi Alawami,
I wanted to follow up to see if you had a chance to look over the information I posted. Your feedback at your earliest convenience would be greatly appreciated so we can move forward with resolving this matter.
Jed G.
JedG_Intel
Hi Alawami,
Thank you for the update.
Since the issue persists, we would like to know if you have other devices that is having the same issue?
Additionally, we would like to share some recommendations.
1. Please try using a different network to see if the same issue will occur.
2. Consider to disable PCIe ASPM on AX210. You may check out this link
3. Try to access BIOS and disable settings related to PCIe power save or PCIe ASPM (Active State Power Management)
Furthermore, based on the MSI B450-A-PRO specification, it seems that this hardware can only support Windows® 10 64-bit OS, please check with your board manufacturer if this hardware can support Linux OS.
If the above recommendations doesn't work, let me know so we can conduct extensive investigation.
I hope the information helps.
Jed G.
JedG_Intel
Hi Alawami,
I'm just checking in to see if you have managed to try the additional recommendations that I provided. Please let me know if you need further assistance so I can continue with the investigation.
Jed G.
JedG_Intel
Hello Alawami,
Jed G.
