Wireless
9045 Discussions
AX211 Microcode SW Error Detected Ubuntu 22
rensb
I'm using a MAG B760M MORTAR WIFI II which uses an AX211 chipset on Ubuntu 22 on the latest driver.  Periodically I get a Microcode SW Error a few times a day on certain machines.  Is there a fix for this somewhere?
For background, this is causing a brief pause in my application while the driver is reload.  I'm running a timing critical application, so any even temporary pause is causing issues for my application.
Thanks!
Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0. Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: Start IWL Error Log Dump: Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: Loaded firmware version: 86.fb5c9aeb.0 so-a0-gf-a0-86.ucode Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x000010BA | ADVANCED_SYSASSERT Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x000002F3 | trm_hw_status0 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x004DB7EC | branchlink2 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x004D1436 | interruptlink1 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x004D1436 | interruptlink2 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x000001F8 | data1 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x000001F8 | data2 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0xDEADBEEF | data3 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x190148E6 | beacon time Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0xAC766721 | tsf low Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x000000AD | tsf hi Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x00000000 | time gp1 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x03217210 | time gp2 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x00000056 | uCode version major Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0xFB5C9AEB | uCode version minor Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x00000430 | hw version Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x00C80002 | board version Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x8094F500 | hcmd Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0xE6F20000 | isr0 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x00400000 | isr1 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x48F80002 | isr2 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x44C3081F | isr3 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x00200000 | isr4 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x0193001C | last cmd Id Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x0000B72A | wait_event Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x00000080 | l2p_control Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x00001C20 | l2p_duration Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x0000003F | l2p_mhvalid Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x00001800 | l2p_addr_match Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x00000000 | timestamp Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x00008868 | flow_handler Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: Start IWL Error Log Dump: Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 7 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x20000070 | NMI_INTERRUPT_LMAC_FATAL Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x80471F66 | umac branchlink2 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x804957BA | umac interruptlink1 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x804957BA | umac interruptlink2 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x00000002 | umac data1 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x804957BA | umac data2 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac data3 Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x00000056 | umac major Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0xFB5C9AEB | umac minor Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x0321723A | frame pointer Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0xC0886258 | stack pointer Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x008D010C | last host cmd Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr status reg Nov 17 12:03:12 cb2034 kernel: iwlwifi 0000:00:14.3: IML/ROM dump:
JedG_Intel
Hello rensb,
Please share the information below for me to have a better approach with this issue.
1. Is this issue present from the start?
2. Did you make any recent changes to the system?
3. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
Please also generate SSU report for me to check your system configuration.
I hope to hear from you soon!
Jed G.
rensb
Hi Jed,
Thanks for the response!  Attached the result of the scan.  This is the different machine that the above log, but it exhibits the same microcode error.
1. The issue presents itself after its been run for a bit, particularly under load, but intermittently maybe once every few hours.
2. No changes when issue was present.  After the issue came up, we experimented with trying the older drivers, but the same issue occurred.   Curren using /lib/firmware/iwlwifi-so-a0-gf-a0-72.ucode instead of the current 86.  We also tried separate config changes, including `disable_11ax=1` and other powersave features.
3. Yes, this is the preinstalled wifi module that comes with the msi motherboard
Thanks!
JedG_Intel
Hi rensb,
Thank you for answering all the questions' I'll be investigating this matter internally and I'll give you an update as soon as possible.
Jed G.
JedG_Intel
Hi rensb,
I'm following up on the investigation. Please share the output of the following as I need them to check this further.
1. $ hostnamectl
2. # lspci​
3. # modinfo iwlwifi​
4. # lsmod | grep iwlwifi
5. # dmesg | grep “no suitable firmware found!”​
I hope to hear from you soon.
Jed G.
JedG_Intel
Hello rensb,
I wanted to follow up with regards to the information that I requested. Please provide this at your earliest convenience so we can further investigate.
Jed G.
JedG_Intel
Hello rensb,
Jed G.
