Wireless
8851 Discussions
Advanced-n 6200
Hi guys,
I have a small question that i need an answer to.
I had a Centrino advanced-n 6200 installed on my laptop and i replaced it with a Centrino Advanced-n 6235 .
Do you know if they are interchangeable ? As i installed the new card and the laptop is giving me an error (10) could not start device ..
Any help ??
Jose_H_Intel1
Thank you very much for your post,
On regards to your question, please note that the Intel® Centrino® Advanced-N 6235 wireless adapter is meant to be professionally installed by Original Equipment Manufacturer (OEM) technicians on certified systems only.
Please also note that these adapters are not meant to be sold separately, your system must be compliant with the required FCC certifications in compliance with the International Special Committee for Radio Interference standards for radiated and conducted electromagnetic interference.
In this case what we recommend and encourage you to first contact the Original Equipment Manufacturer (OEM) to determine if the product is approved for use in your computer.
For additional information you may refer to:
Intel® WiFi Products - Upgrade or exchange Intel® wireless adapter hardware
http://www.intel.com/support/wireless/wlan/sb/CS-006006 http://www.intel.com/support/wireless/wlan/sb/CS-006006
Intel® WiFi Products - Why doesn't my laptop recognize my new Intel wireless adapter?
http://www.intel.com/support/wireless/wlan/sb/CS-031167.htm http://www.intel.com/support/wireless/wlan/sb/CS-031167.htm
I hope this helps
Joe H.
RKell3
mspagnol,
I have traded the Intel(R) Centrino(R) Advanced-N 6200 AGN and the Intel® Centrino® Advanced-N 6235 adapter. I had to install the drivers from Intel's website, but had no problems.
You can try going to the http://downloadcenter.intel.com/Default.aspx Intel Download Center for the drivers you need.
Rick
I have tried the what you have said , but that is when Error Code 10 came :S
RKell3
Error code 10 is a driver issue.
Did you recently install/reinstall the operating system? If yes, did you install the...
Dell System Software(if applicable for Dell Computers ONLY)
Chipset drivers first? If not, the rest of the drivers will fail to install.
Rick
Jose_H_Intel1
I hope this helps
Joe H.
