Wireless
8971 Discussions
Ax211 eap/radius connexion impossible
Stevenrenard
bonjour à tous,
sur un pc lenovo p15 disposant d'une carte intel ax211 il m'est impossible de me connecter sur un wifi avec authentification radius via serveur windows NPS 2019.
il me demande le mot de passe du compte et ne va pas plus loin,
la demande d'authentification n'arrive pas jusqu'au serveur NPS
voici des erreurs régulière dans l'event viewer
DeividA_Intel
Hello Stevenrenard,
Thank you for posting on the Intel® communities. I understand you are having an issue with the authentication under the Windows NPS 2019 server using our Intel® Wi-Fi 6E AX211.
I would like to confirm this information, this will allow me to continue further:
1. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
2. Is the Bluetooth working?
3. Are you using Windows 11 Professionnel or Windows NPS 2019 server? I want to make sure that I got this right.
4. Was this configuration working before?
5. Have you made any changes to the BIOS settings?
6. What is the brand and model name of your router/AP?
7. Is this a personal or a company computer?
Deivid A.
Stevenrenard
bonjour,
oui il s'agit de l'adaptateur d'origine installé sur une lenovo P15
le bluetooth est semble t'il fonctionnel
le pc est installe en windows 11 pro et le serveur radius NPS est un windows 2019
ce pc vient tout juste d'être déballé et c'est le seule modèle similaire dans la société
les acces point sont des unifi long range
c'est un pc d'entreprise
cordialement
DeividA_Intel
Hello Stevenrenard,
I would like to know if you were able to collect the information requested, if you need additional time do not hesitate to let me know.
Deivid A.
DeividA_Intel
Hello Stevenrenard,
Thanks for the confirmation. I noticed from your report that you are running wireless version 22.150.3.1 and the latest one from Intel is 22.250.1.
I recommend you try a clean installation of this driver and you may need to check for any Windows updates pending:
If the issue persists, I will need a new report from the Intel® System Support Utility (Intel® SSU) and please let me know how many unit are affected by this issue.
Deivid A.
DeividA_Intel
Hello Stevenrenard,
I want to know if you were able to install the latest Intel wireless driver (22.250.1). If the issue persists, do not forget to provide the report from the Intel® System Support Utility (Intel® SSU) and how many units are affected by this issue.
Deivid A.
DeividA_Intel
Hello Stevenrenard,
I was checking your thread and noticed that we have not heard back from you. I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
DeividA_Intel
Hello Stevenrenard,
As my last recommendation, try to get in contact with Lenovo for further support on this matter and I would like to let you know that this wireless adapter is not compatible with the Windows server.
Also, bear in mind that the authentication issues are on the operating system/Radius end not the wireless card.
Deivid A.
ITGinja
I have found the "solution" to this and the reason it appears to be happening, but I don't want to post a step by step for anyone who doesn't understand what they are doing.  The root cause to this issue is that the driver/firmware does not have appropriate system access to pull saved credentials from credential guard because its being treated as an external peripheral instead of a system device.  If you disable the credential guard via uefi lock, reboot, open up local policy editor and enabled secure boot without DMA protection and re-enable credential guard, your radius Wi-Fi will work.
