Wireless
8657 Discussions
BE200 Not working on Fedora 42
Izzami
Hi, I have just bought a new Intel BE200 and I've installed it in my Asus laptop (A555L). I've had several problems to make it work on Windows, but in the end downgrading the drivers did the trick.
However I'm not able to make it work even on Linux.
Right now I'm on Fedora 42 with kernel 6.16.7. The WiFi and Bluetooth don't show up.
output of lspci:
03:00.0 Network controller: Intel Corporation Wi-Fi 7(802.11be) AX1775*/AX1790*/BE20*/BE401/BE1750* 2x2 (rev 1a)
output of dmesg | grep iwlwifi:
[    5.537989] iwlwifi 0000:03:00.0: Detected crf-id 0x1001910, cnv-id 0x1001910 wfpm id 0x80000000
[    5.538072] iwlwifi 0000:03:00.0: PCI dev 272b/00f0, rev=0x471, rfid=0x112100
[    5.538077] iwlwifi 0000:03:00.0: Detected Intel(R) Wi-Fi 7 BE200 320MHz
[    5.557991] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-gl-b0-fm-b0-96.ucode failed with error -
2
[    5.558054] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-gl-b0-fm-b0-95.ucode failed with error -
2
[    5.558105] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-gl-b0-fm-b0-94.ucode failed with error -
2
[    5.558155] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-gl-b0-fm-b0-93.ucode failed with error -
2
[    5.558208] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-gl-b0-fm-b0-92.ucode failed with error -
2
[    5.558212] iwlwifi 0000:03:00.0: no suitable firmware found!
[    5.558214] iwlwifi 0000:03:00.0: minimum version required: iwlwifi-gl-b0-fm-b0-92
[    5.558217] iwlwifi 0000:03:00.0: maximum version supported: iwlwifi-gl-b0-fm-b0-96
[    5.558219] iwlwifi 0000:03:00.0: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
output of modinfo iwlwifi
https://jpst.it/4B6td (i couldn't put the whole output 'cause it triggered the anti-spam filter)
output of lsmod | grep iwlwifi
iwlwifi               585728  0
cfg80211             1511424  1 iwlwifi
Mike_Intel
Hello Izzami,
  1. Did you manually install the BE200 on this Asus laptop?
  2. May I know why did you replace the wireless controller?
  3. May I also ask for the link of the driver that you use?
Michael L.
Izzami
Hi, thanks for reaching back.
Here's the answers:
  1. Yes I've manually installed the new card into the laptop
  2. I've decided to replace it 'cause I need my laptop for University and my old wifi card only supported 2.4Ghz networks, so I've decided to upgrade it
  3. On my windows installation I've made it work thanks to these drivers: https://drivers.softpedia.com/get/NETWORK-CARD/INTEL/Intel-Wi-Fi-7-BE200-WLAN-Driver-23-0-5-7-for-Windows-11.shtml for wifi and https://drivers.softpedia.com/get/BLUETOOTH/Intel/Intel-Wi-Fi-7-BE200-Bluetooth-Driver-23-0-0-10-for-Windows-11.shtml for bluetooth. They are the only drivers that work for this wifi card, as newer drivers keep showing error 10. Still this is not a perfect experience, since every time windows update finds that there's a new driver version it updates them and both bluetooth and wifi stop working. Regarding Linux drivers I don't have any link, as i can't find the drivers the card is asking for.
Mike_Intel
Hello Izzami,
Thank you for the update.
Before we proceed let e share this link: Regulatory Information Regarding Wireless Hardware Installation or...
Let me ask, have you tried contacting Asus before manually installing Intel BE200 for proper installation and configuration and to check the compatibility? Based on the link, it is best to check it first just to make sure that the system supports the card.
Michael L.
Mike_Intel
Hello Izzami,
Michael L.
Mike_Intel
Hello Izzami,
I am sending another follow up on the information that I requested.
Michael L.
