Wireless
8871 Discussions
BE200NGW Certification Mexico
Mark_Bee
Can you confirm the BE200NGW is not certified for use in Mexico?
Are there any plans to certify the BE200NGW in Mexico.
Best regards
JaveA_Intel
Hi Mark_Bee
We will further check this with our team regarding the Certification of the adapter in Mexico. We will get back to you as soon as possible.
Jave Vincent A.
Ernesto_C_Intel1
Hi Mark_Bee
Please check under Intel® Wi-Fi 7 BE200 for all regions should apply:
https://www.intel.com/content/www/us/en/support/articles/000098088/wireless.html
Ernesto C.
JaveA_Intel
Hi Mark_Bee
This is only a quick follow-up; I just wanted to check in with you, as I haven't received any feedback from you.
Jave Vincent A.
Mark_Bee
Hi JavA_Intel,
thanks for the follow up. I checked the Intel® Wi-Fi 7 BE200 Regulatory Documentation (PDF), it doesn't contain any information about Mexico certification for the BE200NGW.
The Intel® WiFi Adapter Information Guide (PDF) contains information about a warning statement applicable to Mexico but does not say if the BE200NGW is certified for use in Mexico.
So it seems the BE200NGW is not certified for use in Mexico, can you confirm this?
Do you know if it is possible to get Modular certification for the BE200NGW in Mexico?
JaveA_Intel
Hi Mark_Bee
We will further clarify this with our team regarding the Certification of the adapter in Mexico. We will get back to you as soon as possible.
Jave Vincent A.
JaveA_Intel
Hi Mark_Bee,
We've send a private message on your email regarding the details on how to get the certification. Kindly check you inbox.
Jave Vincent A.
Mark_Bee
JaveA_Intel,
I've received the email, private message. It doesn't answer my question it tells me to ask someone else (external to Intel)
If this is the only advice you have I guess that closes this issue.
