Wireless
9036 Discussions
Bluetooth SIG Component QDID for declarations
WChen160
Are updates for the SIG component Host QDIDs : 97584 to satisfy the requirement to use TCRL 2019-1?
The SIG shows the older QDIDs :
About the QDID information : https://launchstudio.bluetooth.com/ListingDetails/RedirectFromQdid/97584
As our investigation we found out there are 5 test case update from TCRL-2016-2 to TCRL-2019-1 :
  1. AVDTP/SRC/ACP/SIG/SMG/BI-02-C
  2. GAP/MOD/NSYN/BV-01-C
  3. GATT/SR/GAW/BV-11-C
  4. SM/SLA/KDU/BI-01-C
  5. SM/MAS/KDU/BI-01-C
Wanner_G_Intel
Hello WChen160,
Thank you for your input.
To address your request, we recommend that you check the Regulatory Documents for Intel® Wireless Products.
Additionally, we have sent you an email to the email address associated with your profile that contains detailed information to obtain test reports documentation.
Wanner G.
A Contingent Worker at Intel
Wanner_G_Intel
Hello WChen160,
Thank you for submitting your question on this Intel® Community.
We will do further research about this issue and update this thread as soon as possible.
Wanner G.
WChen160
Hi WannerG,
Thank you for your quick reply, hope we can get any good news soon :)
WChen160
Hi WannerG,
We have confirmed with our BQC and check out that we only need help on these two test cases :
  1. SM/SLA/KDU/BI-01-C
  2. SM/MAS/KDU/BI-01-C
Could we able to get the test report about two test cases or Intel will update the QDID ?
Or Intel have any advice about how to enable the LE connection function?
Wanner_G_Intel
Hello WChen160,
Thank you for the update.
To make sure we provide you with accurate information, please confirm the following:
1. Are you looking for the test reports documentation?
2. Are you trying to confirm whether BLE is supported because you are designing a devices which should have the BLE functionality?
3. Do you need these declarations because you are having a technical issue with the BLE device connection to your system(s). Please let us know more information about the system(s) you are using.
Wanner G.
WChen160
Hi Wanner G.,
Thank you for the reply
--Yes, that's what we are looking for ! We can refer the reports documentation for our BQB certification.
--The BLE function work good for us .
--No, we only need the test reports:
Thanks for your reply again !
Best regard
W. Chen
WChen160
Hi Wanner G.,
We want add one more question,
  1. Do Intel have any Profile Subsystem for this core host component:97584 to use ?
Wanner_G_Intel
Hello WChen160,
Wanner G.
WChen160
Hi Wanner G,
I have followed your advice and found the Lab to help us.
Thank you for your help on this !
Best regard
W. Chen
