Wireless
8632 Discussions
Can the Intel AX210 support the TWT function?
Pranav14
Dear Intel Support,
I would like to know if the Intel AX 210 Supports Target Wake Time (TWT). Additionall could you provide step by step instruction on how to configure TWT for my wavlink 6E triband NIC card (WL-WN675X3) using iw commands.
Thanking in anticipation !
Pranav Ghabade.
JeanetteC_Intel
Hello Pranav14,
I'm currently checking on this internally and will post an update once it's available.
JeanetteC.
Pranav14
Ohkay JeanetteC. Thank you so much for your reply.  Waiting for your next reply.
Pranav Ghabade.
Pranav14
Hello JeanetteC,
Any update on the TWT configurations settings.
JeanetteC_Intel
Hello Pranav14,
Good day.
I am still further checking on this query you have. Please help share the following details below:
1) Could you please check the wavlink 6E triband NIC card (WL-WN675X3) using Linux command, is it detected Intel AX210 card with Linux?
2) IS this network card self-integrated or pre-installed?
3) Please share the OS, kernel and firmware version.
4) Is the AP model and firmware supported TWT?
5) What project are you working on (via TWT function)?
6) And how many systems (self-integration or pre-installed unit) you plan with AX210 as STA(Station).
I will wait for your reply.
JeanetteC.
Pranav14
Hello JeanetteC,
1. Yes the wavlink 6E triband NIC card (WL-WN675X3) is using the linux command. and it is detecting when i search for it in terminal in my desktop.
2. This is an externally purchased which i have integrated it in the PCIe Slot of my desktop.
3.  OS: Ubuntu 22.04.5 LTS;  Kernel - 6.8.0.52-generic;  Firmware Version: 77.2df8986f.0;
4.  my desktop is connected to the wifi router which is TP-Link archer BE400 which is wifi 7 and it supports TWT. there is an option to enable TWT in GUI of wifi router.
5. I am working on a research project where we are tring to make wifi deterministic for wireless time sensitive network.
6.  so currently there are two desktop as STAs.
hope i am able to share the information you asked. do let me know anything specific way i can share.
Pranav Ghabade.
JeanetteC_Intel
Hello Pranav14,
Thank you for sharing. I will proceed with checking on this issue internally and will post an update once available.
JeanetteC.
Pranav14
Ohkay. Thank you.
JeanetteC_Intel
Hello Pranav14,
Please check your email inbox (including your spam and junk folder), for the answer to your query.
JeanetteC.
Pranav14
Hello JeanetteC.
I checked my mail. I will try the solution provided and let you know.
Thank you so much.
Pranav Ghabade
JeanetteC_Intel
Hello Pranav14,
Sure, let me know how it goes. I hope to hear from you soon.
JeanetteC.
Pranav14
Hello JeanetteC,
Can you share all the necessary commands to enable TWT settings for Linux. i have updated the linux kernel and firmware.
Pranav Ghabade.
JeanetteC_Intel
Hello Pranav14,
I will be sending details internally for this request. Kindly check your email (inbox, spam or junk folders).
JeanetteC.
Intel Customer Support
