Wireless
8606 Discussions
Connector 1 and Connector 2 on Intel 8260NGW.
SSyno
So from another thread here:
it was mentioned that on the AC 8265, connector 1 is for wifi + BT and connector 2 is just for wifi. Is this the same for the 8260NGW?
Hello Synomenon,
Correction, actually for the 8260 the connector assignment is the opposite as the one on the 7265 and 8265:
We hope this doesn't cause much of an inconvenience.
Carlos A.
Hello Synomenon,
You're correct. This is accurate for all of our current adapters.
Antenna 1 (AUX): Wi-Fi + BT
Antenna 2 (Main): Wi-Fi
Carlos A.
Hello Synomenon,
Carlos A.
SSyno
Thank you! Easy fix, just need to pop the side of my computer open to swap the connectors.
Hello ynomenon,
I'm glad you the notification and were able to make the switch.
If there's anything else we can help you with, feel free to contact us again.
Carlos A.
