Wireless
8665 Discussions
DRTU error connecting to DUT
Pete2
We are trying the DRTU software with Windows 10 21H2. The software starts successfully but connection fails with errors "Unable to load library with path WifiSwStack.dll ...". However I have installed the USC, selecting "Install" on the Inf results in "Operation completed successfully". Similar error regarding BT. DRTU is started as administrator.
So how can I confirm the library path is correct? DRTU is installed in default location at Program Files. Wifi driver is installed also.
Versions:
- DRTU / Tools / Driver: PHWFW05139_22.100.0.3
David_G_Intel
Hello Pete2
Thank you for posting on the Intel️® communities. Let me investigate this and I will get back to you with updates.
David G
David_G_Intel
Hello Pete2
After further investigation, this support cannot guide you on how to do wireless regulatory-related testings or how to put Intel Wireless Adapters into testing mode. If you received the test tool (DRTU) from an Intel representative, please contact the same Intel rep for assistance.
David G
