Wireless
8664 Discussions
Driver 22.200.2 deleted the reference device names
ACh_Skull
Hello!
Microsoft started sending your new driver version 22.190.0 and 22.200.0 using Windows Update. If you look at the structure of the driver, you will see that the names of the reference device names have shifted from their proper place to the very bottom of the configuration file. Also, the string "Strings" is shifted from its correct location. View attachment.
You upload the drivers to the Microsoft repository and the responsibility lies on your shoulders, that is, Intel!
Please fix this bug. This bug is present only in the driver and it is not visible in the system, i.e. it is not critical.
22.190.0.4: Intel Download Center / Microsoft Update Catalog (Identical files byte by byte)
Jean_Intel
Hello ACh_Skull,
We will proceed to check the issue internally and post back soon with more details.
Jean O.
Jean_Intel
Hello ACh_Skull,
We appreciate your patience.
We first would like to thank you for the information you shared; we appreciate your feedback. We would like to let you know that the INF file is for drivers, and Intel wireless drivers have been certified by Microsoft, indicating that the driver structure meets the requirements and standards.
Jean O.
ACh_Skull
Hello!
If you had looked at the driver structure, you would not have provided such an incompetent answer.
Look at the structure of the driver "Netwtw08.INF" carefully and look at my modified file "Netwtw08.INF.Fix.txt " and what is the correct driver structure there.
If you look at the structure of the "Netwtw6e.INF" driver, then it is perfect here.
Jean_Intel
Hello ACh_Skull,
Thank you for the heads up.
We will resume our research regarding this matter, and we will post as soon as we have further details.
Jean O.
Jean_Intel
Hello ACh_Skull,
We appreciate the recommendations and feedback you have provided. We will pass the information you provided to the team in charge for them to consider and decide if we should implement your feedback. We will now close this thread. If you need additional information, please submit a new question, as this thread will no longer be monitored.
Jean O.
