Wireless
9030 Discussions
Driver Support Assistant - expedited installation
Boesman
The DSA driver installation process is unnecessarily onerous and can be streamlined.
E.g. to install the updated Bluetooth driver required about 8 clicks just to select an update using the Typical profile.
AFAIK the MSI platform allows for command line parameters to bypass prompts and run using all the default options.
Can Intel please make this available as a DSA option to allow drivers to be installed using streamlined defaults? Perhaps this could only be for driver UPDATES i.e. new app installs should still be interactive.
Andres_Intel
Hello Boesman,
Thank you for posting on the Intel communities.
We appreciate your feedback and comments related to the Intel® Driver & Support Assistant (Intel® DSA). I have submitted your recommendation and we will evaluate it and make the changes if it is approved.
Let us know if you need further assistance.
Andres P.
Andres_Intel
Hello Boesman,
Andres P.
Andres_Intel
Hello Boesman,
Andres P.
Boesman
Thank you, that's the best I could hope for.
I look forward to more efficient driver updates in the future.
Andres_Intel
Hello Boesman,
Happy to hear that I have help you with your request, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
