Wireless
8787 Discussions
Dual band 7260 but can't connect to 5ghz?
jms
I just got a new router that is 5ghz compatible but im unable to connect to it from my laptop.I have connected with my phone to it,but not my laptop. When i went to the intel driver utility, it says that my wireless card is a 'Intel® Dual Band Wireless-AC 7260' and from reading thought it was 5ghz compatible. Have the most current driver and everything.
Driver : Intel(R) Wireless-N 7260
Vendor : Intel Corporation
Provider : Intel
Date : 7/21/2014
Version : 17.1.0.19
INF file : C:\Windows\INF\oem42.inf
Files : 3 total
C:\Windows\system32\DRIVERS\Netwbw02.sys
C:\Windows\system32\DRIVERS\Netwfw02.dat
C:\Windows\system32\drivers\vwifibus.sys
Type : Native Wi-Fi Driver
Radio types supported : 802.11b 802.11g 802.11n
FIPS 140-2 mode supported : Yes
802.11w Management Frame Protection supported : Yes
Hosted network supported : Yes
Authentication and cipher supported in infrastructure mode:
Open None
Open WEP-40bit
Open WEP-104bit
Open WEP
WPA-Enterprise TKIP
WPA-Enterprise CCMP
WPA-Personal TKIP
WPA-Personal CCMP
WPA2-Enterprise TKIP
WPA2-Enterprise CCMP
WPA2-Personal TKIP
WPA2-Personal CCMP
Open Vendor defined
Authentication and cipher supported in ad-hoc mode:
Open None
Open WEP-40bit
Open WEP-104bit
Open WEP
WPA2-Personal CCMP
Am i wrong that this isn't a 5ghz compatible card?
tvete
Valued Contributor II
Nothing's wrong. Your laptop is just equipped with single band "Intel Wireless-N 7260" instead of "Intel Dual Band Wireless-N 7260"
Intel updated utility is still messed up and can't determine which version of 7260 so it always say you have Intel 7260AC regardless. Windows gathers information from the actual inf driver files and the Hardware ID and it detected that you're running the Single Band N 7260
tvete
jms
Thanks for clearing that up. I was really hoping it was capable of 5ghz but maybe ill get the upgraded card eventually and swap it.
