Wireless
8581 Discussions
Follow up on wi-fi connection randomly dropping.
AlexanderCoxson
Hello!
So earlier this year, I posted a question about my issues with my wifi randomly disconnecting from my PC. Since then, I have still been having issues, and I was able to avoid the issue by using a USB adapter. However, the USB adapter was honestly quite cheap and it has now burnt out and is just toast. Below is the previous question I posted and everything I was suggested and I have tried. None of these worked. I have no idea what else to do, as I have even deep cleaned my PC since in case it was somehow a dust issue, but that did nothing.
https://community.intel.com/t5/Wireless/Internet-Randomly-Disconnects-every-few-hours-on-my-Intel-Dual/m-p/1393585/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufEw0Szc3WjIzTjFKV0pFfDEzOTM1ODV8U1VCU0NSSVBUSU9OU3xoSw#M42265
All help is IMMENSELY appreciated, as this is very annoying and often gets in the way of homework and gaming. Thank you!
Jean_Intel
Hello AlexanderCoxson,
Thank you for posting one more time in the Intel️® communities.
Since the issue is still present, I would recommend performing a clean installation of the wireless driver. You should know that there are two different types of drivers, generics provided by Intel and Equipment Manufacturer drivers, that are customized to work with each system. Installing this Intel generic graphics driver will overwrite any customized driver from your Computer Manufacturer (OEM). OEM drivers are handpicked, customized, and validated to resolve platform-specific issues, enable features and enhancements, and improve system stability. Intel’s generic graphics drivers are intended for testing. If you want to try them, follow the steps listed below:
• Download and save the driver https://www.intel.com/content/www/us/en/download/19351/windows-10-and-windows-11-wi-fi-drivers-for-intel-wireless-adapters.html
• Disconnect the unit to the internet.
• Uninstall the Wi-Fi driver.
1. Go to Device Manager.
2. Expand the Network Adapters category.
3. Right-click your Intel Wireless Adapter and choose to uninstall it.
4. Make sure the option to Delete the driver software for this device is selected.
5. Repeat steps 1 through 4 until the option to Delete the driver software for this device is greyed out.
• Restart your computer.
• Install the driver downloaded before
Locate the driver you downloaded. Right-click the file you downloaded, and select the option to Run as administrator.
Jean O.
AlexanderCoxson
Hello Jean_Intel,
I did all the steps and the issue still persists unfortunately.
Sincerely,
Alexander Coxson
Jean_Intel
Thanks for your response.
Check your Settings for 802.11n Connectivity for your wireless adapters and confirm if they meet our recommended settings. Our recommended configuration and more information on how to change them are listed in this article: https://www.intel.sg/content/www/xa/en/support/articles/000005544/wireless.html
Also, please provide me with a report using the Intel System Support Utility (Intel SSU). It will list your system's information, such as the Operating system, BIOS, and Driver versions, and will help us troubleshoot your issue.
• Download the Intel SSU (https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-windows.html)
• Open the application and click on "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View."
• To save your scan: click on "Next"; then "Save."
Jean O.
AlexanderCoxson
Hello Jean_Intel,
I checked my properties and they were all the exact same at the recommended properties listed.
I believe I already gave an SSU report on my previous thread, but I will provide an updated one JUST in case.
Sincerely,
Alexander Coxson
Jean_Intel
I appreciated your response.
Looking at the SSU report, I noticed that the wireless driver reported being installed on your system is the 19.51.40.1 version. Which indicates that the driver is not up to date. Our latest version is 22.160.0. Please, try one more time our steps to perform a clean installation installing our latest wireless driver:
  • Download and save the driver https://www.intel.com/content/www/us/en/download/19351/windows-10-and-windows-11-wi-fi-drivers-for-i...
    • 1. Go to Device Manager.
    • 2. Expand the Network Adapters category.
    • 3. Right-click your Intel Wireless Adapter and choose to uninstall it.
    • 4. Make sure the option to Delete the driver software for this device is selected.
    • 5. Repeat steps 1 through 4 until the option to Delete the driver software for this device is greyed out.
  • Locate the driver you downloaded. Right-click the file you downloaded, and select the option to Run as administrator.
Jean O.
Jean_Intel
Jean O.
Jean_Intel
I hope you are doing fine.
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
