Wireless
9042 Discussions
Force uninstall Intel Wireless Driver
wbadry
I have Dell XPS13 9320 with Intel AX211 driver.
The issue started when I decided to use Intel Support and Assist to install the latest driver.
After the driver pack was downloaded and started to install Intel Pro/Wireless software, it shows an error encountered and suddenly even if I tried to reinstall the driver from Dell, it is installed but Windows encounter an issue whenever it tries to install it.
And this is the log :
[61AC:69B0][2024-05-16T01:45:54]i001: Burn v3.11.1.2318, Windows v10.0 (Build 22631: Service Pack 0), path: C:\WINDOWS\Temp\{CF97B671-2291-48E2-9424-9EC7C30FFFAB}\.cr\WirelessSetup.exe
[61AC:69B0][2024-05-16T01:45:54]i000: Initializing numeric variable 'ModifyScreenEnabled' to value '0'
[61AC:69B0][2024-05-16T01:45:54]i000: Initializing numeric variable 'GUIUninstallEnabled' to value '0'
[61AC:69B0][2024-05-16T01:45:54]i000: Initializing numeric variable 'GUIComponentMultiSelectionEnabled' to value '0'
[61AC:69B0][2024-05-16T01:45:54]i000: Initializing numeric variable 'GUIShowSummaryPopup' to value '0'
[61AC:69B0][2024-05-16T01:45:54]i000: Initializing numeric variable 'GUIShowFinalSummary' to value '0'
[61AC:69B0][2024-05-16T01:45:54]i000: Initializing numeric variable 'DowngradeEnabled' to value '0'
[61AC:69B0][2024-05-16T01:45:54]i000: Initializing numeric variable 'ElevationRequired' to value '0'
[61AC:69B0][2024-05-16T01:45:54]i009: Command Line: '-burn.clean.room=C:\WINDOWS\Temp\{A4647176-4B6F-4C37-8B64-B228C4FE7A5D}\WirelessSetup.exe -burn.filehandle.attached=596 -burn.filehandle.self=592'
[61AC:69B0][2024-05-16T01:45:54]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\WINDOWS\Temp\{A4647176-4B6F-4C37-8B64-B228C4FE7A5D}\WirelessSetup.exe'
[61AC:69B0][2024-05-16T01:45:54]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\WINDOWS\Temp\{A4647176-4B6F-4C37-8B64-B228C4FE7A5D}\'
[61AC:69B0][2024-05-16T01:45:54]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\wbadry\AppData\Local\Temp\Intel®_Software_Installer_20240516014554.log'
[61AC:69B0][2024-05-16T01:45:54]i052: Condition 'VersionNT >= v10.0' evaluates to true.
[61AC:69B0][2024-05-16T01:45:54]i000: Setting string variable 'WixBundleManufacturer' to value 'Intel Corporation'
[61AC:69B0][2024-05-16T01:45:54]i000: Loading managed bootstrapper application.
[61AC:69B0][2024-05-16T01:45:54]i000: Creating BA thread to run asynchronously.
[61AC:4204][2024-05-16T01:45:54]i000: Entry point of WiX - Run method
[61AC:4204][2024-05-16T01:45:54]i000: Changing InstallAction from Unknown to Install
[61AC:4204][2024-05-16T01:45:54]i000: InstallAction = Install
[61AC:4204][2024-05-16T01:45:54]i000: Current locale: en-US
[61AC:4204][2024-05-16T01:45:54]i000: Setting numeric variable 'WixBundleUpgradeAction' to value 0
[61AC:4204][2024-05-16T01:45:54]i000: Setting numeric variable 'WixBundleRelationType' to value 0
[61AC:4204][2024-05-16T01:45:54]i000: Setting string variable 'Documentation_DisplayName' to value 'Documentation'
[61AC:4204][2024-05-16T01:45:54]i000: Setting string variable 'MinSupportedOsVersion' to value '10.0.17763.0'
[61AC:4204][2024-05-16T01:45:54]i000: Setting string variable 'ProductName' to value 'Intel® PROSet/Wireless Wi-Fi Software'
[61AC:4204][2024-05-16T01:45:54]i000: RebootRequired: Setting to False.
[61AC:69B0][2024-05-16T01:45:55]i100: Detect begin, 4 packages
[61AC:69B0][2024-05-16T01:45:55]i000: OnDetectBegin: Installed=True, PackageCount=4, Result=None
[61AC:69B0][2024-05-16T01:45:55]i000: Changing InstallAction from Install to Repair
[61AC:69B0][2024-05-16T01:45:55]i000: Setting string variable 'NETFRAMEWORK45' to value '533320'
[61AC:69B0][2024-05-16T01:45:55]i000: OnDetectPackageBegin: PackageId=NetFx462Web, Result=None
[61AC:69B0][2024-05-16T01:45:55]i000: Setting numeric variable 'NetFx462Web_Installed' to value 0
[61AC:69B0][2024-05-16T01:45:55]i000: Setting numeric variable 'NetFx462Web_Install' to value 0
[61AC:69B0][2024-05-16T01:45:55]i052: Condition 'NETFRAMEWORK45 >= 394802' evaluates to true.
[61AC:69B0][2024-05-16T01:45:55]i000: OnDetectPackageComplete: PackageId=NetFx462Web, State=Present, Status=0
[61AC:69B0][2024-05-16T01:45:55]i000: OnDetectPackageBegin: PackageId=Pre_Install, Result=None
[61AC:69B0][2024-05-16T01:45:55]i000: Setting numeric variable 'Pre_Install_Installed' to value 0
[61AC:69B0][2024-05-16T01:45:55]i000: Setting numeric variable 'Pre_Install_Install' to value 0
[61AC:69B0][2024-05-16T01:45:55]i052: Condition '0' evaluates to false.
[61AC:69B0][2024-05-16T01:45:55]i000: OnDetectPackageComplete: PackageId=Pre_Install, State=Absent, Status=0
[61AC:69B0][2024-05-16T01:45:55]i000: OnDetectPackageBegin: PackageId=WIFI_Driver, Result=None
[61AC:69B0][2024-05-16T01:45:55]i000: Setting numeric variable 'WIFI_Driver_Installed' to value 0
[61AC:69B0][2024-05-16T01:45:55]i000: Setting numeric variable 'WIFI_Driver_Install' to value 0
[61AC:69B0][2024-05-16T01:45:55]i000: Setting numeric variable 'WIFI_Driver_Install' to value 1
[61AC:69B0][2024-05-16T01:45:55]i052: Condition 'WixBundleInstalled AND WIFI_Driver_Installed' evaluates to false.
[61AC:69B0][2024-05-16T01:45:55]i000: OnDetectPackageComplete: PackageId=WIFI_Driver, State=Absent, Status=0
[61AC:69B0][2024-05-16T01:45:55]i000: OnDetectPackageBegin: PackageId=DocsManager, Result=None
[61AC:69B0][2024-05-16T01:45:55]i000: Setting numeric variable 'DocsManager_Installed' to value 1
[61AC:69B0][2024-05-16T01:45:55]i000: Setting numeric variable 'DocsManager_Install' to value 0
[61AC:69B0][2024-05-16T01:45:55]i000: Setting numeric variable 'DocsManager_Install' to value 1
[61AC:69B0][2024-05-16T01:45:55]i000: OnDetectPackageComplete: PackageId=DocsManager, State=Present, Status=0
[61AC:69B0][2024-05-16T01:45:55]i101: Detected package: NetFx462Web, state: Present, cached: None
[61AC:69B0][2024-05-16T01:45:55]i101: Detected package: Pre_Install, state: Absent, cached: None
[61AC:69B0][2024-05-16T01:45:55]i101: Detected package: WIFI_Driver, state: Absent, cached: None
[61AC:69B0][2024-05-16T01:45:55]i101: Detected package: DocsManager, state: Present, cached: Complete
[61AC:69B0][2024-05-16T01:45:55]i000: OnDetectComplete: Status=0
[61AC:69B0][2024-05-16T01:45:55]i199: Detect complete, result: 0x0
[61AC:4204][2024-05-16T01:46:00]i000: Apply - PlanAction=Repair
[61AC:69B0][2024-05-16T01:46:00]i200: Plan begin, 4 packages, action: Repair
[61AC:69B0][2024-05-16T01:46:00]i000: OnPlanBegin: PackageCount=4, Result=None
[61AC:69B0][2024-05-16T01:46:00]i000: OnPlanPackageBegin: PackageId=NetFx462Web, Result=None, State=Repair
[61AC:69B0][2024-05-16T01:46:00]w321: Skipping dependency registration on package with no dependency providers: NetFx462Web
[61AC:69B0][2024-05-16T01:46:00]i000: OnPlanPackageComplete: Execute=None, PackageId=NetFx462Web, Requested=None, Rollback=None, State=Present, Status=0
[61AC:69B0][2024-05-16T01:46:00]i000: OnPlanPackageBegin: PackageId=Pre_Install, Result=None, State=Repair
[61AC:69B0][2024-05-16T01:46:00]i000: PlanPackage(Pre_Install, Repair)
[61AC:69B0][2024-05-16T01:46:00]w321: Skipping dependency registration on package with no dependency providers: Pre_Install
[61AC:69B0][2024-05-16T01:46:00]i000: OnPlanPackageComplete: Execute=None, PackageId=Pre_Install, Requested=None, Rollback=None, State=Absent, Status=0
[61AC:69B0][2024-05-16T01:46:00]i052: Condition 'WIFI_Driver_Install' evaluates to true.
[61AC:69B0][2024-05-16T01:46:00]i000: OnPlanPackageBegin: PackageId=WIFI_Driver, Result=None, State=Repair
[61AC:69B0][2024-05-16T01:46:00]i000: PlanPackage(WIFI_Driver, Repair)
[61AC:69B0][2024-05-16T01:46:00]i000: Setting string variable 'WIFI_Driver_InstallCommand' to value '-i -l "[WixBundleLog_WIFI_Driver]" -pc "C:\ProgramData\Package Cache\{778be45a-dd41-4bf6-8f9d-409a995d76b2}\InstalledPackages.xml" -pi "WIFI_Driver" -f "'Components\WiFiDriver\Netwtw6e.INF','Components\WiFiDriver\Netwtw08.INF','Components\WiFiDriver\Netwtw04.INF'"'
[61AC:69B0][2024-05-16T01:46:00]i000: Setting string variable 'WIFI_Driver_RepairCommand' to value '-r -l "[WixBundleLog_WIFI_Driver]" -pc "C:\ProgramData\Package Cache\{778be45a-dd41-4bf6-8f9d-409a995d76b2}\InstalledPackages.xml" -pi "WIFI_Driver" -f "'Components\WiFiDriver\Netwtw6e.INF','Components\WiFiDriver\Netwtw08.INF','Components\WiFiDriver\Netwtw04.INF'"'
[61AC:69B0][2024-05-16T01:46:00]i000: Setting string variable 'WIFI_Driver_UninstallCommand' to value '-u -l "[WixBundleLog_WIFI_Driver]" -pc "C:\ProgramData\Package Cache\{778be45a-dd41-4bf6-8f9d-409a995d76b2}\InstalledPackages.xml" -pi "WIFI_Driver" -f "'Components\WiFiDriver\Netwtw6e.INF','Components\WiFiDriver\Netwtw08.INF','Components\WiFiDriver\Netwtw04.INF'"'
[61AC:69B0][2024-05-16T01:46:00]w321: Skipping dependency registration on package with no dependency providers: WIFI_Driver
[61AC:69B0][2024-05-16T01:46:00]i000: Setting string variable 'WixBundleLog_WIFI_Driver' to value 'C:\Users\wbadry\AppData\Local\Temp\Intel®_Software_Installer_20240516014554_000_WIFI_Driver.log'
[61AC:69B0][2024-05-16T01:46:00]i000: Setting string variable 'WixBundleRollbackLog_WIFI_Driver' to value 'C:\Users\wbadry\AppData\Local\Temp\Intel®_Software_Installer_20240516014554_000_WIFI_Driver_rollback.log'
[61AC:69B0][2024-05-16T01:46:00]i000: OnPlanPackageComplete: Execute=Install, PackageId=WIFI_Driver, Requested=Repair, Rollback=Uninstall, State=Absent, Status=0
[61AC:69B0][2024-05-16T01:46:00]i000: OnPlanPackageBegin: PackageId=DocsManager, Result=None, State=Repair
[61AC:69B0][2024-05-16T01:46:00]i000: PlanPackage(DocsManager, Repair)
[61AC:69B0][2024-05-16T01:46:00]i000: Setting string variable 'WixBundleLog_DocsManager' to value 'C:\Users\wbadry\AppData\Local\Temp\Intel®_Software_Installer_20240516014554_001_DocsManager.log'
[61AC:69B0][2024-05-16T01:46:00]i000: OnPlanPackageComplete: Execute=Repair, PackageId=DocsManager, Requested=Repair, Rollback=None, State=Present, Status=0
[61AC:69B0][2024-05-16T01:46:00]i201: Planned package: NetFx462Web, state: Present, default requested: Repair, ba requested: None, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[61AC:69B0][2024-05-16T01:46:00]i201: Planned package: Pre_Install, state: Absent, default requested: Repair, ba requested: None, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[61AC:69B0][2024-05-16T01:46:00]i201: Planned package: WIFI_Driver, state: Absent, default requested: Repair, ba requested: Repair, execute: Install, rollback: Uninstall, cache: Yes, uncache: Yes, dependency: None
[61AC:69B0][2024-05-16T01:46:00]i201: Planned package: DocsManager, state: Present, default requested: Repair, ba requested: Repair, execute: Repair, rollback: None, cache: No, uncache: No, dependency: Register
[61AC:69B0][2024-05-16T01:46:00]i000: OnPlanComplete: Status=0
[61AC:69B0][2024-05-16T01:46:00]i299: Plan complete, result: 0x0
[61AC:69B0][2024-05-16T01:46:00]i300: Apply begin
[61AC:69B0][2024-05-16T01:46:00]i000: OnApplyBegin: Result=None
[61AC:69B0][2024-05-16T01:46:00]i000: OnElevate
[61AC:69B0][2024-05-16T01:46:00]i010: Launching elevated engine process.
[61AC:69B0][2024-05-16T01:46:00]i011: Launched elevated engine process.
[61AC:69B0][2024-05-16T01:46:00]i012: Connected to elevated engine.
[4698:6624][2024-05-16T01:46:00]i358: Pausing automatic updates.
[4698:6624][2024-05-16T01:46:00]i359: Paused automatic updates.
[4698:6624][2024-05-16T01:46:00]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{778be45a-dd41-4bf6-8f9d-409a995d76b2}, resume: Active, restart initiated: No, disable resume: No
[61AC:3894][2024-05-16T01:46:00]i000: OnCacheBegin: Result=None
[61AC:3894][2024-05-16T01:46:00]i000: OnCachePackageBegin: CachePayloads=22, PackageCacheSize=97683185, PackageId=WIFI_Driver, Result=None
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=WIFI_Driver, Result=None
[4698:3A90][2024-05-16T01:46:01]i305: Verified acquired payload: WIFI_Driver at path: C:\ProgramData\Package Cache\.unverified\WIFI_Driver, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\PnPInstaller.exe.
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=WIFI_Driver, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=WIFI_Driver_CommonUtils, Result=None
[4698:3A90][2024-05-16T01:46:01]i305: Verified acquired payload: WIFI_Driver_CommonUtils at path: C:\ProgramData\Package Cache\.unverified\WIFI_Driver_CommonUtils, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\CommonUtils.dll.
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=WIFI_Driver_CommonUtils, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=WIFI_Driver_UWDBootstrapper_Common, Result=None
[4698:3A90][2024-05-16T01:46:01]i305: Verified acquired payload: WIFI_Driver_UWDBootstrapper_Common at path: C:\ProgramData\Package Cache\.unverified\WIFI_Driver_UWDBootstrapper_Common, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\UWDBootstrapper_Common.dll.
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=WIFI_Driver_UWDBootstrapper_Common, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay0EA87ECD29D114EDB95CA5FAE4122239, Result=None
[4698:3A90][2024-05-16T01:46:01]i305: Verified acquired payload: pay0EA87ECD29D114EDB95CA5FAE4122239 at path: C:\ProgramData\Package Cache\.unverified\pay0EA87ECD29D114EDB95CA5FAE4122239, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\Components\WiFiDriver\IntelIhvRouter10.dll.
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay0EA87ECD29D114EDB95CA5FAE4122239, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay17D08E74AF6CE894509F636F94E2352A, Result=None
[4698:3A90][2024-05-16T01:46:01]i305: Verified acquired payload: pay17D08E74AF6CE894509F636F94E2352A at path: C:\ProgramData\Package Cache\.unverified\pay17D08E74AF6CE894509F636F94E2352A, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\Components\WiFiDriver\Netwfw08.dat.
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay17D08E74AF6CE894509F636F94E2352A, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay1DB6BD20E27459DD61E91A2BD66A328A, Result=None
[4698:3A90][2024-05-16T01:46:01]i305: Verified acquired payload: pay1DB6BD20E27459DD61E91A2BD66A328A at path: C:\ProgramData\Package Cache\.unverified\pay1DB6BD20E27459DD61E91A2BD66A328A, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\Components\WiFiDriver\NETwaw14.sys.
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay1DB6BD20E27459DD61E91A2BD66A328A, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay41619E72062164B3CBD4AEE2EE6F0F75, Result=None
[4698:3A90][2024-05-16T01:46:01]i305: Verified acquired payload: pay41619E72062164B3CBD4AEE2EE6F0F75 at path: C:\ProgramData\Package Cache\.unverified\pay41619E72062164B3CBD4AEE2EE6F0F75, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\Components\WiFiDriver\IntelIhvRouter08.dll.
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay41619E72062164B3CBD4AEE2EE6F0F75, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay54A1D89D4A58E1E4BE588C52055DBA4B, Result=None
[4698:3A90][2024-05-16T01:46:01]i305: Verified acquired payload: pay54A1D89D4A58E1E4BE588C52055DBA4B at path: C:\ProgramData\Package Cache\.unverified\pay54A1D89D4A58E1E4BE588C52055DBA4B, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\Components\WiFiDriver\NETwtw04.sys.
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay54A1D89D4A58E1E4BE588C52055DBA4B, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay59544370D1B716DA88CB2CAC1AF132AD, Result=None
[4698:3A90][2024-05-16T01:46:01]i305: Verified acquired payload: pay59544370D1B716DA88CB2CAC1AF132AD at path: C:\ProgramData\Package Cache\.unverified\pay59544370D1B716DA88CB2CAC1AF132AD, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\Components\WiFiDriver\NETwtw10.sys.
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay59544370D1B716DA88CB2CAC1AF132AD, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay5E5FBD0581A313F8888659EA257295E7, Result=None
[4698:3A90][2024-05-16T01:46:01]i305: Verified acquired payload: pay5E5FBD0581A313F8888659EA257295E7 at path: C:\ProgramData\Package Cache\.unverified\pay5E5FBD0581A313F8888659EA257295E7, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\Components\WiFiDriver\Netwtw6e.INF.
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay5E5FBD0581A313F8888659EA257295E7, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay608C6EBA23198442234A7C1C103AED93, Result=None
[4698:3A90][2024-05-16T01:46:01]i305: Verified acquired payload: pay608C6EBA23198442234A7C1C103AED93 at path: C:\ProgramData\Package Cache\.unverified\pay608C6EBA23198442234A7C1C103AED93, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\Components\WiFiDriver\Netwtw08.INF.
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay608C6EBA23198442234A7C1C103AED93, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay80A2A5392182CB8B0C50A07FF2C3E1C1, Result=None
[4698:3A90][2024-05-16T01:46:01]i305: Verified acquired payload: pay80A2A5392182CB8B0C50A07FF2C3E1C1 at path: C:\ProgramData\Package Cache\.unverified\pay80A2A5392182CB8B0C50A07FF2C3E1C1, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\Components\WiFiDriver\Netwfw04.dat.
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay80A2A5392182CB8B0C50A07FF2C3E1C1, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay86640A5B5868CEABBE69ADBBB3B2B8BF, Result=None
[4698:3A90][2024-05-16T01:46:01]i305: Verified acquired payload: pay86640A5B5868CEABBE69ADBBB3B2B8BF at path: C:\ProgramData\Package Cache\.unverified\pay86640A5B5868CEABBE69ADBBB3B2B8BF, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\Components\WiFiDriver\netwtw6e.cat.
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay86640A5B5868CEABBE69ADBBB3B2B8BF, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:01]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay9063348AC632C6C4F275ECD0272C6057, Result=None
[4698:3A90][2024-05-16T01:46:02]i305: Verified acquired payload: pay9063348AC632C6C4F275ECD0272C6057 at path: C:\ProgramData\Package Cache\.unverified\pay9063348AC632C6C4F275ECD0272C6057, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\Components\WiFiDriver\NETwtw08.sys.
[61AC:3894][2024-05-16T01:46:02]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay9063348AC632C6C4F275ECD0272C6057, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:02]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay9B12D788A98826F1ACF82868F62102D4, Result=None
[4698:3A90][2024-05-16T01:46:02]i305: Verified acquired payload: pay9B12D788A98826F1ACF82868F62102D4 at path: C:\ProgramData\Package Cache\.unverified\pay9B12D788A98826F1ACF82868F62102D4, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\Components\WiFiDriver\IntelIhvRouter04.dll.
[61AC:3894][2024-05-16T01:46:02]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay9B12D788A98826F1ACF82868F62102D4, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:02]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payA0D8D59E2A33AEE685035E2DA0A94D48, Result=None
[4698:3A90][2024-05-16T01:46:02]i305: Verified acquired payload: payA0D8D59E2A33AEE685035E2DA0A94D48 at path: C:\ProgramData\Package Cache\.unverified\payA0D8D59E2A33AEE685035E2DA0A94D48, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\Components\WiFiDriver\Netwfw10.dat.
[61AC:3894][2024-05-16T01:46:02]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payA0D8D59E2A33AEE685035E2DA0A94D48, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:02]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payA37D6F0CD43E95C5AADA30AF99951B1D, Result=None
[4698:3A90][2024-05-16T01:46:02]i305: Verified acquired payload: payA37D6F0CD43E95C5AADA30AF99951B1D at path: C:\ProgramData\Package Cache\.unverified\payA37D6F0CD43E95C5AADA30AF99951B1D, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\Components\WiFiDriver\Netwfw14.dat.
[61AC:3894][2024-05-16T01:46:02]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payA37D6F0CD43E95C5AADA30AF99951B1D, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:02]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payCC0E9CEA166B577F9032DE6978D298FE, Result=None
[4698:3A90][2024-05-16T01:46:02]i305: Verified acquired payload: payCC0E9CEA166B577F9032DE6978D298FE at path: C:\ProgramData\Package Cache\.unverified\payCC0E9CEA166B577F9032DE6978D298FE, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\Components\WiFiDriver\NETwtw14.sys.
[61AC:3894][2024-05-16T01:46:02]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payCC0E9CEA166B577F9032DE6978D298FE, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:02]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payD267FCAAA9CB0162E5A61141F7D32F64, Result=None
[4698:3A90][2024-05-16T01:46:02]i305: Verified acquired payload: payD267FCAAA9CB0162E5A61141F7D32F64 at path: C:\ProgramData\Package Cache\.unverified\payD267FCAAA9CB0162E5A61141F7D32F64, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\Components\WiFiDriver\netwtw04.cat.
[61AC:3894][2024-05-16T01:46:02]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payD267FCAAA9CB0162E5A61141F7D32F64, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:02]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payF0758620E587697468657D465BD1833B, Result=None
[4698:3A90][2024-05-16T01:46:02]i305: Verified acquired payload: payF0758620E587697468657D465BD1833B at path: C:\ProgramData\Package Cache\.unverified\payF0758620E587697468657D465BD1833B, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\Components\WiFiDriver\Netwtw04.INF.
[61AC:3894][2024-05-16T01:46:02]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payF0758620E587697468657D465BD1833B, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:02]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payF253A5F946288B1167E69591C51C9B02, Result=None
[4698:3A90][2024-05-16T01:46:02]i305: Verified acquired payload: payF253A5F946288B1167E69591C51C9B02 at path: C:\ProgramData\Package Cache\.unverified\payF253A5F946288B1167E69591C51C9B02, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\Components\WiFiDriver\netwtw08.cat.
[61AC:3894][2024-05-16T01:46:02]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payF253A5F946288B1167E69591C51C9B02, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:02]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payF9782D783831669C3D0E12F3733E367B, Result=None
[4698:3A90][2024-05-16T01:46:02]i305: Verified acquired payload: payF9782D783831669C3D0E12F3733E367B at path: C:\ProgramData\Package Cache\.unverified\payF9782D783831669C3D0E12F3733E367B, moving to: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\Components\WiFiDriver\IntelIhvRouter14.dll.
[61AC:3894][2024-05-16T01:46:02]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payF9782D783831669C3D0E12F3733E367B, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:02]i000: OnCachePackageComplete: PackageId=WIFI_Driver, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:02]i000: OnCachePackageBegin: CachePayloads=1, PackageCacheSize=3985408, PackageId=DocsManager, Result=None
[61AC:3894][2024-05-16T01:46:02]i000: OnCacheVerifyBegin: PackageId=DocsManager, PayloadId=DocsManager, Result=None
[4698:3A90][2024-05-16T01:46:02]i304: Verified existing payload: DocsManager at path: C:\ProgramData\Package Cache\{51C5ED88-53DF-49F4-9855-0E9949AC7522}v23.40.0.4\DocsManager.msi.
[61AC:3894][2024-05-16T01:46:02]i000: OnCacheVerifyComplete: PackageId=DocsManager, PayloadId=DocsManager, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:02]i000: OnCachePackageComplete: PackageId=DocsManager, Result=None, Status=0
[61AC:3894][2024-05-16T01:46:02]i000: OnCacheComplete: Status=0
[61AC:69B0][2024-05-16T01:46:02]i000: OnExecuteBegin: PackageCount=2, Result=None
[61AC:69B0][2024-05-16T01:46:02]i000: OnExecutePackageBegin: PackageId=WIFI_Driver, Result=None, ShouldExecute=True
[61AC:69B0][2024-05-16T01:46:02]i000: OnExecuteProgress: OverallPercentage=0, PackageId=WIFI_Driver, ProgressPercentage=0, Result=None
[4698:6624][2024-05-16T01:46:02]i301: Applying execute package: WIFI_Driver, action: Install, path: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\PnPInstaller.exe, arguments: '"C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\PnPInstaller.exe" -i -l "C:\Users\wbadry\AppData\Local\Temp\Intel®_Software_Installer_20240516014554_000_WIFI_Driver.log" -pc "C:\ProgramData\Package Cache\{778be45a-dd41-4bf6-8f9d-409a995d76b2}\InstalledPackages.xml" -pi "WIFI_Driver" -f "'Components\WiFiDriver\Netwtw6e.INF','Components\WiFiDriver\Netwtw08.INF','Components\WiFiDriver\Netwtw04.INF'"'
[61AC:69B0][2024-05-16T01:46:02]i000: OnExecuteProgress: OverallPercentage=25, PackageId=WIFI_Driver, ProgressPercentage=50, Result=None
[61AC:69B0][2024-05-16T01:46:03]i000: OnExecuteProgress: OverallPercentage=25, PackageId=WIFI_Driver, ProgressPercentage=50, Result=None
[61AC:69B0][2024-05-16T01:46:04]i000: OnExecuteProgress: OverallPercentage=25, PackageId=WIFI_Driver, ProgressPercentage=50, Result=None
[61AC:69B0][2024-05-16T01:46:05]i000: OnExecuteProgress: OverallPercentage=25, PackageId=WIFI_Driver, ProgressPercentage=50, Result=None
[4698:6624][2024-05-16T01:46:06]e000: Error 0x80070001: Process returned error: 0x1
[4698:6624][2024-05-16T01:46:06]e000: Error 0x80070001: Failed to execute EXE package.
[61AC:69B0][2024-05-16T01:46:06]e000: Error 0x80070001: Failed to configure per-machine EXE package.
[61AC:69B0][2024-05-16T01:46:06]i000: OnExecutePackageComplete: PackageId=WIFI_Driver, Restart=None, Result=None, Status=-2147024895
[61AC:69B0][2024-05-16T01:46:06]i319: Applied execute package: WIFI_Driver, result: 0x80070001, restart: None
[61AC:69B0][2024-05-16T01:46:06]e000: Error 0x80070001: Failed to execute EXE package.
[4698:6624][2024-05-16T01:46:06]i351: Removing cached package: WIFI_Driver, from path: C:\ProgramData\Package Cache\74A39813A8FAA5B73C560121203FA7620ACD2DEC\
[61AC:69B0][2024-05-16T01:46:06]i000: OnExecuteComplete: Status=-2147024895
[4698:6624][2024-05-16T01:46:06]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{778be45a-dd41-4bf6-8f9d-409a995d76b2}, resume: ARP, restart: None, disable resume: No
[4698:6624][2024-05-16T01:46:06]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{778be45a-dd41-4bf6-8f9d-409a995d76b2}, resume: ARP, restart initiated: No, disable resume: No
[61AC:69B0][2024-05-16T01:46:06]i000: OnApplyComplete: Restart=None, Result=None, Status=-2147024895
[61AC:69B0][2024-05-16T01:46:06]i000: Setting ReturnCode to ERROR
[61AC:69B0][2024-05-16T01:46:06]i399: Apply complete, result: 0x80070001, restart: None, ba requested restart:  No
[61AC:4204][2024-05-16T01:48:02]i000: LogFolderLink_RequestNavigate()
The card still working well on Ubuntu which I have on dual boot, so the card itself is working properly. Also there is no way to install an older version or totally uninstall the corrupted Intel installer as it keeps showing if I tried older version that a newer version is already installed.
[4438:3164][2024-05-16T01:51:23]i001: Burn v3.11.1.2318, Windows v10.0 (Build 22631: Service Pack 0), path: C:\WINDOWS\Temp\{03336E53-2350-4153-AF32-7AAF95940676}\.cr\WirelessSetup.exe
[4438:3164][2024-05-16T01:51:23]i000: Initializing numeric variable 'ModifyScreenEnabled' to value '0'
[4438:3164][2024-05-16T01:51:23]i000: Initializing numeric variable 'GUIUninstallEnabled' to value '0'
[4438:3164][2024-05-16T01:51:23]i000: Initializing numeric variable 'GUIComponentMultiSelectionEnabled' to value '0'
[4438:3164][2024-05-16T01:51:23]i000: Initializing numeric variable 'GUIShowSummaryPopup' to value '0'
[4438:3164][2024-05-16T01:51:23]i000: Initializing numeric variable 'GUIShowFinalSummary' to value '0'
[4438:3164][2024-05-16T01:51:23]i000: Initializing numeric variable 'DowngradeEnabled' to value '0'
[4438:3164][2024-05-16T01:51:23]i000: Initializing numeric variable 'ElevationRequired' to value '0'
[4438:3164][2024-05-16T01:51:23]i009: Command Line: '-burn.clean.room=C:\WINDOWS\Temp\{96B69FB2-93AB-467C-B1B0-506CBF70E6B4}\WirelessSetup.exe -burn.filehandle.attached=764 -burn.filehandle.self=596'
[4438:3164][2024-05-16T01:51:23]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\WINDOWS\Temp\{96B69FB2-93AB-467C-B1B0-506CBF70E6B4}\WirelessSetup.exe'
[4438:3164][2024-05-16T01:51:23]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\WINDOWS\Temp\{96B69FB2-93AB-467C-B1B0-506CBF70E6B4}\'
[4438:3164][2024-05-16T01:51:23]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\wbadry\AppData\Local\Temp\Intel®_Software_Installer_20240516015123.log'
[4438:3164][2024-05-16T01:51:23]i052: Condition 'VersionNT >= v10.0' evaluates to true.
[4438:3164][2024-05-16T01:51:23]i000: Setting string variable 'WixBundleName' to value 'Intel® Software Installer'
[4438:3164][2024-05-16T01:51:23]i000: Setting string variable 'WixBundleManufacturer' to value 'Intel Corporation'
[4438:3164][2024-05-16T01:51:23]i000: Loading managed bootstrapper application.
[4438:3164][2024-05-16T01:51:23]i000: Creating BA thread to run asynchronously.
[4438:590C][2024-05-16T01:51:23]i000: Entry point of WiX - Run method
[4438:590C][2024-05-16T01:51:23]i000: Changing InstallAction from Unknown to Install
[4438:590C][2024-05-16T01:51:23]i000: InstallAction = Install
[4438:590C][2024-05-16T01:51:23]i000: Current locale: en-US
[4438:590C][2024-05-16T01:51:23]i000: Setting numeric variable 'WixBundleUpgradeAction' to value 0
[4438:590C][2024-05-16T01:51:23]i000: Setting numeric variable 'WixBundleRelationType' to value 0
[4438:590C][2024-05-16T01:51:23]i000: Setting string variable 'Documentation_DisplayName' to value 'Documentation'
[4438:590C][2024-05-16T01:51:23]i000: Setting string variable 'MinSupportedOsVersion' to value '10.0.17763.0'
[4438:590C][2024-05-16T01:51:23]i000: Setting string variable 'ProductName' to value 'Intel® PROSet/Wireless Wi-Fi Software'
[4438:590C][2024-05-16T01:51:23]i000: RebootRequired: Setting to False.
[4438:3164][2024-05-16T01:51:24]i100: Detect begin, 4 packages
[4438:3164][2024-05-16T01:51:24]i000: OnDetectBegin: Installed=False, PackageCount=4, Result=None
[4438:3164][2024-05-16T01:51:24]i000: Setting string variable 'NETFRAMEWORK45' to value '533320'
[4438:3164][2024-05-16T01:51:24]i102: Detected related bundle: {778be45a-dd41-4bf6-8f9d-409a995d76b2}, type: Upgrade, scope: PerMachine, version: 23.40.0.4, operation: Downgrade
[4438:3164][2024-05-16T01:51:24]i000: OnDetectRelatedBundle: BundleTag=InstallUWD_SFX, Operation=Downgrade, PerMachine=True, ProductCode={778be45a-dd41-4bf6-8f9d-409a995d76b2}, RelationType=Upgrade, Result=None, Version=23.40.0.4
[4438:3164][2024-05-16T01:51:24]i000: Setting ReturnCode to NEWER_PRODUCT_FOUND
[4438:3164][2024-05-16T01:51:24]e000: Forcing ReturnCode to NEWER_PRODUCT_FOUND due to newer product found installed
[4438:3164][2024-05-16T01:51:24]i000: Setting UpgradeAction to Downgrade
[4438:3164][2024-05-16T01:51:24]i000: Setting numeric variable 'WixBundleUpgradeAction' to value 1
[4438:3164][2024-05-16T01:51:24]i000: Setting RelationType to Upgrade
[4438:3164][2024-05-16T01:51:24]i000: Setting numeric variable 'WixBundleRelationType' to value 2
[4438:3164][2024-05-16T01:51:24]i000: OnDetectPackageBegin: PackageId=NetFx462Web, Result=None
[4438:3164][2024-05-16T01:51:24]i000: Setting numeric variable 'NetFx462Web_Installed' to value 0
[4438:3164][2024-05-16T01:51:24]i000: Setting numeric variable 'NetFx462Web_Install' to value 0
[4438:3164][2024-05-16T01:51:24]i052: Condition 'NETFRAMEWORK45 >= 394802' evaluates to true.
[4438:3164][2024-05-16T01:51:24]i000: OnDetectPackageComplete: PackageId=NetFx462Web, State=Present, Status=0
[4438:3164][2024-05-16T01:51:24]i000: OnDetectPackageBegin: PackageId=Pre_Install, Result=None
[4438:3164][2024-05-16T01:51:24]i000: Setting numeric variable 'Pre_Install_Installed' to value 0
[4438:3164][2024-05-16T01:51:24]i000: Setting numeric variable 'Pre_Install_Install' to value 0
[4438:3164][2024-05-16T01:51:24]i000: Setting numeric variable 'Pre_Install_Install' to value 1
[4438:3164][2024-05-16T01:51:24]i052: Condition '0' evaluates to false.
[4438:3164][2024-05-16T01:51:24]i000: OnDetectPackageComplete: PackageId=Pre_Install, State=Absent, Status=0
[4438:3164][2024-05-16T01:51:24]i000: OnDetectPackageBegin: PackageId=WIFI_Driver, Result=None
[4438:3164][2024-05-16T01:51:24]i000: Setting numeric variable 'WIFI_Driver_Installed' to value 0
[4438:3164][2024-05-16T01:51:24]i000: Setting numeric variable 'WIFI_Driver_Install' to value 0
[4438:3164][2024-05-16T01:51:24]i000: Setting numeric variable 'WIFI_Driver_Install' to value 1
[4438:3164][2024-05-16T01:51:24]i052: Condition 'WixBundleInstalled AND WIFI_Driver_Installed' evaluates to false.
[4438:3164][2024-05-16T01:51:24]i000: OnDetectPackageComplete: PackageId=WIFI_Driver, State=Absent, Status=0
[4438:3164][2024-05-16T01:51:24]i000: OnDetectPackageBegin: PackageId=DocsManager, Result=None
[4438:3164][2024-05-16T01:51:24]i000: Setting numeric variable 'DocsManager_Installed' to value 0
[4438:3164][2024-05-16T01:51:24]i000: Setting numeric variable 'DocsManager_Install' to value 0
[4438:3164][2024-05-16T01:51:24]i000: Setting numeric variable 'DocsManager_Install' to value 1
[4438:3164][2024-05-16T01:51:24]i103: Detected related package: {51C5ED88-53DF-49F4-9855-0E9949AC7522}, scope: PerMachine, version: 23.40.0.4, language: 0 operation: MajorUpgrade
[4438:3164][2024-05-16T01:51:24]i000: OnDetectRelatedMsiPackage: Operation=MajorUpgrade, PackageId=DocsManager, PerMachine=True, ProductCode={51C5ED88-53DF-49F4-9855-0E9949AC7522}, Result=None, Version=23.40.0.4
[4438:3164][2024-05-16T01:51:24]i000: OnDetectPackageComplete: PackageId=DocsManager, State=Absent, Status=0
[4438:3164][2024-05-16T01:51:24]i101: Detected package: NetFx462Web, state: Present, cached: None
[4438:3164][2024-05-16T01:51:24]i101: Detected package: Pre_Install, state: Absent, cached: None
[4438:3164][2024-05-16T01:51:24]i101: Detected package: WIFI_Driver, state: Absent, cached: None
[4438:3164][2024-05-16T01:51:24]i101: Detected package: DocsManager, state: Absent, cached: None
[4438:3164][2024-05-16T01:51:24]i000: OnDetectComplete: Status=0
[4438:3164][2024-05-16T01:51:24]e000: Unable to detect bundle packages
[4438:3164][2024-05-16T01:51:24]i199: Detect complete, result: 0x0
[4438:590C][2024-05-16T01:51:30]i000: LogFolderLink_RequestNavigate()
I have no clue what the issue would be and how to totally clean the Intel Wireless drivers so when I install an older version (sanity check) it accepts the installation.
Now even Windows cannot install the driver.
Of course, I tried t uninstall anything related to the driver and restart the PC several times, Same issue. I even tried the administrator package for the drivers, but unfortunately had the had the same issue.
All help is appreciated.
LeonWaksman
Follow instructions how to remove phantom adapters.
Leon
