Wireless
9025 Discussions
Help with wifi
Roseb
So I had to change my house wifi and can't find out how to switch my cameras to the new wifi pls help
AlHill
So, you changed your router,s and now your cameras do not connect?
Explain how this is an intel issue and what intel wireless hardware they use.
You probably should be speaking to the camera manufacturer, or the router manufacturer.
Also, did you change your router ssid?  do your wireless laptops or desktops connect?
[AI is the same as snake-oil]
