Wireless
8651 Discussions
How can I change the advanced settings for the wireless adapter for many users?
PSada
The adapter in question is the Intel dual band wireless ac-8260. Does Intel support changing one or more of these advanced settings to deploy them on many machines?
Hello piyush2017,
As we understand, you want to know if is possible to modify the advanced Intel® Wireless Adapter driver settings and deploy these changes to multiple machines.
Please keep in mind that if the driver is already installed, the users can change the http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005585.html Advanced Intel® Wireless Adapter Settings from Windows* Device Manager.
If you are an IT admin and need to use specific settings, you can use the Intel® PROSet/Wireless Software Administrator Tool to configure user settings and to create custom install packages to export to other systems. This is mentioned in the document: http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000006222.html Frequently Asked Questions for Enterprise and IT Administrators.
The features and options available with this tool vary depending on the version of the Operating System, if this is what you need, we encourage you to try the admin tool and check the options it provides. You can check the details about this in this advisory: http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000007149.html Feature Comparison for Intel® PROSet/Wireless Software Enterprise.
The links to download the different IT admin packages are found in the following location: http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000017246.html IT Administrator Links for Intel® PROSet/Wireless Software.
The custom packages can be installed normally, or you can use "silent install" to deploy system drivers and software for the corresponding Intel® Wireless Adapters without user intervention. This is explained in the following document: http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005730.html Silent Installation of Intel® WiFi Driver and Intel® PROSet/Wireless Software Version 15.6 or Later.
Jonathan.
Hello piyush2017,
Jonathan.
PSada
Thank you Jonathan.
This is what I was looking for. I am working on this.
Hello piyush2017,
We are glad to know that this is the information you required. Feel free to contact us if you have any other questions.
Jonathan.
PSada
Hello Jonathan,
I was able to create a package and execute it. But there was one adapter setting that was missing - HT Mode. Do you know if this setting is available with the PROSet tool for IT admin?
Piyush
Hello Piyush,
Remember that when you create a custom package, you can select the options that will be available for the user as well as the preset values, so this would be the first thing to check.
Also, some settings are not available depending on the model of the Wireless adapters; the "HT mode" option is not available for legacy adapters (older than the 7260/3160), the same way that "802.11n mode" is not seen with current series and specially for 802.11ac capable adapters.
Jonathan.
PSada
The adapter in question is the latest dual band AC 8260. The HT mode is not available with the PROSet admin tool. Do you know of any workaround on how to add this setting into the package?
Hello Piyush,
Try adding the "802.11ac Mode" and let us know if this helps.
Jonathan.
Hello Piyush,
Please let us know in case you require further assistance.
Jonathan.
PSada
I have not tried adding the "802.11ac" Mode. I just do not want it to cause any other issues with the connection. The driver will be installed on Windows 7 Enterprise and the HT mode is missing. I will test with the 802.11ac Mode and let you know. It might take a bit longer - mostly next week t confirm the results. Thank you for your help.
Hello Piyush,
We appreciate the update. Feel free to let us know if you have any additional questions.
Jonathan.
PSada
Hi Jonathan,
Enabling "802.11ac" mode in the package did not help. HT mode still remains unchanged. The default value for this setting is VHT Mode. I'd like to change it to HT mode, using the package.
Priyesh
Hello Piyush,
We'll have to look further into this. In fact, the administrator tool does not have the option to manage the HT mode option.
Jonathan.
PSada
Thank you Jonathan.
On one of the Windows websites I read "HT mode allows to High Throughput(802.11n)". So, I enabled 802.11n in the PROSet package. In the comments I see it allows High-throughput mode. I haven't tested it yet but, am I right in saying this is the HT mode?
Hello Piyush,
Please try the 802.11n as you mentioned and let us know if it has an effect on the 8260 settings. The 802.11n mode (used with Legacy adapters) and HT mode (seen in current 802.11ac capable adapters) are different http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005585.html Advanced Intel® Wireless Adapter Settings.
802.11n mode: Is used to add multiple-input multiple-output (MIMO). This setting allows you to enable or disable high throughput mode support (MIMO - 802.11n). The options available are:
- Enabled (Default)
- Disabled
HT Mode: Lets you select HT Mode (High Throughput mode), select VHT Mode (Very High Throughput Mode), or disable both modes. Possible options:
- Disabled
- HT mode (supports 802.11n compatibility)
- VHT mode (supports 802.11ac compatibility)
Please let us know if the change had the desired effect, if not, you will need to modify the registry in order to set HT mode on the systems using the Intel® Dual Band Wireless-AC 8260; we can provide the details about this if needed.
Jonathan B.
PSada
Hi Jonathan,
The 802.11n changes the HT mode and it works. The only other question I have is users have standard rights on a computer, will changing these settings also activate them? Because the "advanced properties can only be accessed with admin rights on a computer.
Hello Piyush,
It is good to know you were able to configure the HT mode. To answer your question, if you use the Admin tools to create the package including the advanced settings, then the configuration will reflect on the client systems once you install it.
You can always test it to confirm before doing a major deployment.
Jonathan B.
PSada
Thank you for all you help.
Hello Piyush,
It's a pleasure to help you. Feel free to contact us if you have any additional questions.
Jonathan B.
