Wireless
8697 Discussions
How can I improve the wireless speed using an ac 7265 driver?
JStee8
Hi I have an HP spectre laptop and an ac 7265 driver. The speed test i did in my ho@me indicates that my wireless signal is about 150Mbps down and 20Mbps up. The best I am seeing on my laptop is 30Mbps down and 18Mbps up. Can someone tell me how I can boost this. I am very aware of the issues regarding the 7265 driver.
Hello Steelelaca,
As we understand, you would like to improve the performance of your Intel® Dual Band Wireless-AC 7265. This type of behavior can be caused by many reasons, here are some initial recommendations that may help in this condition:
- Apply the configuration mentioned in the following advisory: http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005544.html Recommended Settings for 802.11n Connectivity.
- Check the possibilities mentioned in this document and apply the actions recommended: http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005493.html Quick Checks to Improve or Fix Wireless Connection Issues.
If you require additional assistance, please provide the following information:
- http://\https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Download Intel® System Support Utility, run the tool and use it to create a report with all sections, on the next screen, Save the report to a file. Then use the Advanced editor options to add the resulting XML file to your post as an attachment.
- Router model and firmware version.
- Have you checked if you get a better connection in other networks?
Jonathan B.
PNovo1
Does your router/access point support AC mode and is it turned on?
Hello Steelelaca,
We haven't seen any response to previous messages. Please let us know if you require further assistance.
Jonathan B.
