Wireless
8782 Discussions
How can I use 5Ghz FTM AP mode Wi-Fi Location on Intel 8260 based on 802.11mc
swkim
Hello !
I have been working and testing FTM function using Iwlwifi on intel 8260.
Now, I used below
* iwlwifi driver - core30 backporting, intel firmware version 31.
and iw 4.9 version (already i patched patch -p1 < bef149ad0c1b8c8f.txt)
I have tested AP mode on 2.4GHz (on devices driven by iwlmvm), it is OK.
But, I cannot use 5Ghz band as FTM Respondor.
How can I use 5Ghz band with AP mode?
-Basic information
* 0S : Debian GNU/Linux 9
* Kernel : Linux version 4.4.194
Enable 802.11mc FTM on Intel 8260
iwlwifi :   switch to release/LinuxCore30
intel fw : iwlwifi-8000C-31.ucode
wget https://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/linux-firmware.git/tree/iwlwifi-8000C-31.ucode
 (refer to https://github.com/HappyZ/iw_intel8260_localization/wiki/Enable-802.11mc-FTM-on-Intel-8260)
additional info.
I proceeded by referring to the following information.
refer to https://www.winlab.rutgers.edu/~gruteser/projects/ftm/Setups.htm
Jocelyn_Intel
Hello, @swkim
Thank you for posting on the Intel® communities.
We found another thread describing the same issue and the same hardware/software environment as this one. To avoid duplication of threads and keep order, we will close this thread.
Best regards,
Jocelyn M.
Intel Customer Support Technician.
