Hello, I would like to bring up a similar issue regarding Intel AX200 having outdated regulatory information for Indonesia that has been reported by other members such as @yjwong before on this post https://community.intel.com/t5/Wireless/Regulatory-update-for-Indonesia-channels-36-40/td-p/1585811.
I have a TP-Link Archer TX3000E wireless card with an Intel AX200 chipset inside, running on the latest firmware (23.130.1.1) and I have been struggling trying to get it connected to my 5GHz Wi-Fi 6 access point set on channel 36. The router/AP I'm using is a TP-Link Archer AX10 revision 2.0 (US) running on the latest firmware (1.3.11 Build 20250325 Rel. 24737(5553)), and that has support for channels 36-48 and 149-161 set on the router.
The Ministry of Communications and Informatics (Kominfo/Komdigi) have revised their regulations on Directorate General of SDPPI Regulation No. 2 2019 on Technical Requirements for WLAN Telecommunications Devices back in May 2019, permitting the usage of spectrums 5150-5250MHz (5GHz channels 36-48) and 5250-5350 (5GHz channels 52-68) for 5GHz Wi-Fi use in Indonesia. And it seems the AX200 still hasn't complied with the new regulatory specifications, thus seem to explain why I can't connect to my 5GHz access point on channel 36.
Here's the link to the authoritative source in Indonesian: https://www.postel.go.id/downloads/42/20200418142416-perdirjen_2019-02_WLAN.pdf
Are there any plans for Intel to include to update its regulatory compliances for Indonesia on all of their Wi-Fi cards to support receiving channels 36-68 on its Wi-Fi cards via firmware or driver update? It would be very appreciated for us Indonesian end-users running Intel wireless cards.
連結已複製
Hello FareyDonch,
- What is the brand and model of your laptop/system?
- Did you upgrade the wireless controller or this is the embedded wireless controller of your system?
- Can you tell us more why do you want to this update?
Michael L.
Hi Mike, thanks for the response.
1. I am using a custom build PC on a Ryzen 5 7600 with an Asrock B650M Pro RS (non-Wi-Fi version), and so;
2. Yes, I installed an aftermarket TP-Link Archer TX3000E PCI-E wireless card (hardware revision 1.0 UN), which uses an Intel AX200 Wi-Fi 6 wireless controller.
3. I've been having problems with my wireless card not connecting to my Wi-Fi 6 router (TP-Link Archer AX10, hardware revision 2.0 US) when the 5GHz SSID is set to channels 36-48, even channel 149. I would like a firmware fix for the AX200 to have support for scanning and connecting those aforementioned 5GHz channels 36-68 in Indonesia, as well as expanding the width to support 80MHz if possible.
Thank you,
FareyDonch
@JedG_Intel Thank you. I hope this can be brought up with the team internally.
I should also add the fact that I've contacted TP-Link themselves and had one of their technicians to help troubleshoot with an Intel ANT debug tool, and temporarily changing the card's regulatory mobile country code (MCC) to US or Australia seems to fix the problem temporarily before it reverts back in two hours. The problem recurred again when reverting the card's MCC region back to Indonesia, which indicates that there's a problem with the region code ID for Intel wireless cards that makes it refuse to connect to access points on channel 36-68.
Running the command iw reg get on iw on Linux Mint seems to confirm this even further.
The global info for Indonesia on iw indicates that it supports 5150-5350 (channels 36-68) on 80MHz, referring to the 2019 RLAN regulation set forth by the Indonesian Ministry of Communications and Informatics (Kominfo). But the wireless card itself (phy0), only supports 5735-5815 (channels 149-161) on 20MHz.
I should also add the fact as well that in the years since, Kominfo and the Indonesian government has recently allowed 5150-5350 up to 160MHz back in 2023, and then recently allowing 6GHz Wi-Fi on 5925-6425 up to 320MHz channel width back in February this year.
With computer stores selling and OEM laptop manufacturers now including Intel AX210 and BE200 wireless cards in Indonesia, I can imagine people will be very confused finding out that their 6GHz-compatible laptop doesn't work with a 6GHz access point in the future.
I hope there could be a regulatory update for these Intel wireless cards in Indonesia that not only adds support for channels 36-68 access points on the 5GHz spectrum, but also expands to recently allocated 6GHz Wi-Fi spectrums.
FareyDonch
Sources:
Hello FareyDonch,
Let me check if you installed the driver from TP-Link and also, have you tried to contact TP-Link support before reaching out to us. Based on my review indicates that the driver requires a specific hardware version. Here are the links to the TP-Link driver and support guidelines:
- https://www.tp-link.com/us/support/download/archer-tx3000e/
- https://www.tp-link.com/us/support/contact-technical-support/
And also, since the you tried the latest generic driver but encountered issues, let me suggest using the TP-Link driver. Please check and follow the settings outlined in our articles "Recommended Settings for 802.11ax Connectivity" and "Guide to Configure Wi-Fi Channels and Channel Widths to Improve Network Connection."
Michael L.
Yes, I have contacted TP-Link beforehand. We used different driver versions, from 23.130.1.1 to 23.80.1.3, as well as the one from the TP-Link website for 22.180 and it still exhibits the same problem, until TP-Link representatives seemingly came into the conclusion that regulatory information on Intel wireless cards for Indonesia seems to be the problem.
I hope this information could be helpful.
FareyDonch
Hello FareyDonch,
I will do further research on this matter and post the response on this thread once it is available.
Michael L.
Hello FareyDonch,
Upon further checking, the AX200 does not support 5GHz channels 36-48 in Indonesia, and this is by design.
While the AX200 itself supports 5GHz channels 36-48 in Indonesia, the PC may not. Therefore, please verify this with the PC manufacturer whether this is an issue or a design choice due to country regulations.
And also, can you please provide the OEM ticket number from your PC—Asrock B650M Pro RS (non-Wi-Fi version)—and TP-Link Archer TX3000E with an Intel AX200 after you tried to contact their technical support.
https://www.asrock.com/support/index.asp
https://www.tp-link.com/my/support/download/archer-tx3000e/
Lastly, let me ask the following details:
- Has the TP-Link Archer AX10 (US version, hardware revision 2.0) 5GHz ever successfully connected using the TP-Link Archer TX3000E with an Intel AX200?
- Can a non-Intel wireless card connect to the TP-Link Archer AX10 5GHz? Have you tried this?
Michael L.
Hello, Mike.
Excuse me, but what do you mean by this? You stated that 5GHz on the aforementioned channels don't work in Indonesia by purpose and then you say AX200 itself supports 5GHz channels 36-48? I'm not sure what you mean by this.
I have not contacted Asrock as I doubt that the Wi-Fi connectivity issues had to do with the motherboard itself. But I have talked with the TP-Link representative on the TX3000E wireless card (TKID250543833, and forum ID 817434, https://community.tp-link.com/en/home/forum/topic/817434?sortDir=ASC&page=1), and I contacted a representative to have them remotely access to my computer and came to the conclusion that AX200 cards not supporting 5GHz channels 36-48 in Indonesia, purposefully by design as stated, is the problem. As I've stated before, AX200 has an outdated regulatory information because ever since 2019, Indonesia has supported 5GHz on 5150-5350MHz or channels 36-68.
Also:
- It does connect to the Archer AX10 router that I have, but only once it's changed to channels 149-161, due to outdated regulatory design on the AX200 card itself.
- Yes, I have a laptop with a Realtek Wi-Fi 5 wireless card and that can connect to my Archer AX10 router, even when being set to channels 36-48
Thank you,
FareyDonch
Hello FareyDonch,
Thank you for the update.
Let me further check this issue again and post the response on this thread once it is available.
Michael L.
Hello FareyDonch,
Thank you for patiently waiting for our update.
I did further checking on this issue and here is my update.
- PC BIOS needs to be checked for AX200. Please check with PC manufacturer for BIOS settings.
- Please refer to the link below, we have a regulatory information guide for customer who are upgrading their wireless controller and as per the link, it explains why you need to coordinate this issue with the manufacturer of your system.
- https://www.intel.com/content/www/us/en/support/articles/000005687/wireless.html
- Lastly, me me also further explain that Intel is a supplier of laptop components and does not manufacture or sell complete laptop systems. Your system manufacturer may have altered the features, incorporated customizations, or made other changes to the software or hardware packaging they provide.
As much as we want to further check and help you. You need to coordinate this issue with TP-link and the manufacturer of your PC.
Thank you for understanding and have a great day.
Michael L.
Hi Mike,
I am running an Asrock B650M Pro RS on BIOS version 3.25. I should note that this is the non-Wi-Fi version of the motherboard, so I added the AX200 later on as it does not come with a wireless card. The settings for WLAN Radio and Bluetooth are enabled on the motherboard, and there seems to be no regulatory DFS information settings in the BIOS as that's on the wireless card-side.
I have also, as previously stated multiple times, coordinated this issue with TP-Link. They determined that there is a problem with the Indonesian country code regulatory info for AX200, which seemingly indicates that it is indeed, outdated. Last time I checked they are currently bringing this up with Intel's engineers on their side, but no details have come out since then.
Sincerely,
FareyDonch.
Hello FareyDonch,
I'll be temporarily handling this thread for now.
Thank you for the efforts you have made thus far. I understand that you have already coordinated with TP-Link regarding this matter. With that in mind, we will conduct a further internal review, and I will follow up with you at the earliest possible opportunity.
Best regards
Jed G.
Hello FareyDonch,
I wanted to let you know that we conducted a thorough investigation into the issue you reported. It appears that the 5.2GHz band was previously unauthorized in Indonesia, but following a regulatory change, the 5.2- 5.3GHz range can now be enabled in the PC BIOS. We recommend checking with your PC manufacturer regarding the BIOS settings for the AX200, as they may have modified features, added customizations, or made other changes to the software or hardware packaging.
We understand you're seeking a resolution, but your motherboard OEM may have customized aspects of your computer, and we apologize for any inconvenience this may cause. I understand this may not be the answer you were hoping for. However, it's best to contact the motherboard OEM for further assistance. Here's the link: https://asrock.com/support/index.asp?Item=TSDProduct
I will be closing this inquiry now. If you require further assistance, please feel free to submit a new question, as this thread will no longer be monitored.
Norman S.
Hey Norman,
I was the original person who reported the issue back in 2023. I could not provide additional information consistently because I do not live in Indonesia and I only visit occasionally for business purposes.
Very sad to say, this problem still exists based on my recent visit to Jakarta. I'm not sure why this has to do with the OEM -- Intel just has to release a new firmware to update the regulatory database, without a need to update BIOS settings. This shouldn't be dependent on the BIOS, but dependent on the firmware.
I can understand why Intel needs to implement Location Aware Regulatory (LAR), but not providing timely firmware updates really leaves us and our users in a stuck position. My company has a fleet of ~100 devices that have to contend with an already congested channel 149-161
Apple fixed this on the M1/M2-series Macs starting from macOS 26 Tahoe. More and more router manufacturers are releasing in Indonesia with channels 36-48 enabled, and this causes anyone with AX200/AX210 to have a serious issue in Indonesia - not even able to connect to networks
It is unfortunate that Intel has yet to patch this issue. In the future there will be more devices with AX200/AX210 cards operating in Indonesia that will be very confused when their devices can't connect to these Wi-Fi 6 and beyond APs running on channels 36-48.
I don't see what Asrock has to do with this. I cannot seem to get in touch with their customer support at all, and I don't think that's the case. Intel should provide us Indonesian customers with timely updates so as to not leave us in the dark. Please update the drivers with new regulatory information, and that's it.
If this is how slow Intel updates its drivers for Indonesia, I think I would rather switch my wireless card with another one.
