Wireless
8948 讨论
Intel 5350 WiFi driver
员工
3,652 次查看
I downloaded the latest version 15.3.1 from http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22116&lang=eng&OSVersion=Windows%207%20(64-bit)*&DownloadType=Software%20Applications Download Center but the WiFi driver version is 13.4.0.139
Is this the latest version? I think this version is a bit old but I maybe wrong.
Can someone please confirm?
0 项奖励
1 解答
员工
2,489 次查看
Hello, thank you for your post.
This driver version you mention is actually the correct one, this wireless card is one of the older ones, so newer driver packages will only update until 13.4. at this moment there are no plans on creating newer drivers.
I hope this helps
在原帖中查看解决方案
0 项奖励
2 回复数
员工
2,490 次查看
I hope this helps
0 项奖励
员工
2,489 次查看
0 项奖励
回复
