Wireless
8654 Discussions
Intel 8265AC wifi card
Heffalump
I`m looking to replace this card with a better one, is there a more powerful up to date version which will fit the same slot.
Also does anyone know if that pin formation has a particular name or designation.
VonM_Intel
Hi, Heffalump.
Thank you for posting in our Community.
When you mention "looking to replace this Wi-Fi card," are you indicating the intention to purchase a new physical card or update its driver version?
Regarding the pin formation, you can find detailed product information by visiting the link provided for the Intel® Dual Band Wireless-AC 8265, specifically under Supplemental Information > Product Brief: View now, and you can see the full product information associated with it.
Looking forward to your response. Have a nice day!
Von M.
Heffalump
I`m looking to replace the actual card. I have the Intel driver updater so that keeps the software up to date.
VonM_Intel
Hi, Heffalump.
Thank you for the update.
I'd like to delve deeper and verify specifics like the precise driver versions, wireless card slots, and any system details. Utilizing the Intel SSU tool will enable us to collect detailed information about your system setup, which could aid in identifying the underlying cause of this issue also, could you please provide your system's wireless card slot?
Furthermore, sharing this article, Regulatory Information Regarding Wireless Hardware Installation or Upgrade. Some countries require the Intel® Wireless Adapters to be certified with the antenna that is intended to be used together in the system, while some countries require the Intel® Wireless Adapter to be certified at the full system level.
Von M.
VonM_Intel
Hi, Heffalump.
I trust you're doing well.
At this rate, it would be best to consult with your computer/device manufacturer and check the best wireless card that supports your system.
I have not heard back from you, we will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
Heffalump
Thanks for the reply I found that an Intel wifi 6 AX200 was a straight replacement and was fully compatible with my new fibre wifi hub
