Wireless
8871 Discussions
Intel 926)AC LAN card driver installation
CPark25
In HP desktop p6-2100kl model,
With 9260AC LAN card and install latest driver Proset 110.
But direct Proset driver installation shows successful message . In case of using automatic driver install assistant tool, finally shows failed and continuously shows message "have update available" and failed loop.
I tried clean installation and but same result.
Wanner_G_Intel
Hello CPark25, Thank you for joining this Intel Community. To better assist you, I would like to know if the problem described on your post is related to a driver installation failure when using the Intel® Driver & Support Assistant (Intel® DSA). If the issue and tool (e.g. HP tool) are different, please let us know. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
CPark25
Thank you for your support.
I solved this issue by installing 64 bit windows 10 from 32bit to my desktop .
I think 9260AC is required to 64 bit environment.
Thank you
