Wireless
8667 Discussions
Intel 9260 Bluetooth not working
KRedd7
I bought an Intel 9260 wireless card for my laptop as it has Bluetooth 5.0 capabilities.
So as soon as i got it, i opened up my laptop, removed the old card and put the new one in.
Only the WiFi was working out of the box,so I downloaded the latest drivers for both.
Followed the instruction as per the website (Uninstalled existing drivers and software and then installed Bluetooth first followed by the WiFi drivers)
restarted the machine and Bluetooth ain't working.
In fact its not even visible in the device manager after installing the drivers.
Alberto_R_Intel
KRedd7, Thank you for posting in the Intel® Communities Support.
Are you sure the antennas are properly connected?
What is the model of the laptop?
Which Windows version are you using?
In this case what we can try first is to reset the Bluetooth feature:
-Go to the search Windows search bar
-Type services
-Click Yes at the pop-up window to allow this app to make changes
-Locate the Bluetooth Support Service and click on
-Click Restart at the left top corner
We can also try a clean installation of the drivers, not sure if these are the steps you already tried, but just to make sure here is the link:
https://www.intel.com/content/www/us/en/support/articles/000022173/network-and-i-o/wireless-networking.html
We recommend to install the wireless drivers provided by the manufacturer of the laptop, those drivers were customized by them to work with your specific system.
As an option, we can try to install the Intel® generic wireless drivers, version 20.110.0:
https://downloadcenter.intel.com/download/28503/Intel-PROSet-Wireless-Software-and-Drivers-for-Windows-10?product=99445
Alberto R.
Under Contract to Intel Corporation
Alberto_R_Intel
KRedd7, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter? Regards, Alberto R. Intel Customer Support Technician Under Contract to Intel Corporation
Alberto_R_Intel
KRedd7, Is there anything we cal help you with? Regards, Alberto R. Intel Customer Support Technician Under Contract to Intel Corporation
bdile
try blocking this pin in the pic below
Hsain2
I also had same problem then i searched and found out if you cover these 2 connectors with tape or anything it will start to work . it worked for me on my lenovo flex 3 1570 with Intel 9260 thanks .kgw3cl1hkiz2.jpg
RockKicker
Wow. It's 2025 and I had the same problem on my old Samsung Ultra running Windows 10. It had a 7260. Replaced it with the 9260 and the wifi side came right up but the blue tooth side didn't. The blue tooth drivers appeared in the device manager at first but windows couldn't find it to use it. Then the BT driver disappeared. Tried all kinds of stuff to get the BT driver to come up, with no success. But covering those 2 pins worked! Couldn't believe it.
pragun16
Blocking those 2 pins actually work. I'm dual booting my laptop with Ubuntu 20.04 and Windows 10. For me, the bluetooth was working a couple of days ago but stopped all of a sudden without me doing anything at all. I checked in both Ubuntu and Windows and both Operating Systems showed that the bluetooth device wasn't installed. So I highly suspected that the drivers were fine and either it was the hardware issue or some BIOS issue. So I covered those two pins using a black tape and now the bluetooth and wifi both work perfect. I'm not sure what the two pins do but since I upgraded from an Intel 3165NG card, I found out that those 2 pins were not there. Also, I'm not sure why this new card was working perfectly a couple of days ago without blocking the pin and stopped all of a sudden. I'm using a Toshiba Satellite L55-C with Intel 9260NGW card now. Check this link for more proofs that blocking the pins work: https://community.acer.com/en/discussion/549994/intel-9260ngw-bluetooth
