Wireless
9039 Discussions
Intel 9260 stalling issue
jBlai3
I purchased an ac9260 wifi card to update to latest tech, replacing ac8265
installed latest drivers...and have been having issues with wifi stalling and slow surfing, i simply disconnect and reconnect...and all is fine, for a little while, and repeat
decided to reinstall windows, and installed latest drivers, to find same issue of adapter stalling..after short periods
have uninstalled device, with removal of drivers (delete) so it just wont install same drivers...down loaded latest driver and again, the adapter stalls, until i disconnect and reconnect
have wifi setting set to full power/no sleep
whats the deal
win 10 64 latest
intel 9260
lenovo 310
AlHill
Replacing your wireless card in your laptop should only be done by the OEM.
https://www.intel.com/content/www/us/en/support/articles/000005687/network-and-i-o/wireless-networking.html https://www.intel.com/content/www/us/en/support/articles/000005687/network-and-i-o/wireless-networking.html
And, doing so yourself can lead to problems:
https://www.intel.com/content/www/us/en/support/articles/000005846/network-and-i-o/wireless-networking.html Why Doesn't My Laptop Recognize My New Intel® Wireless Adapter?
So, contact Lenovo and seek their help with approved adapters.
Doc
AlHill
Doc
jBlai3
I did not need your approval to install the wifi card,
the mfg would not support anything other than what they sold, so your advice to contact Lenovo would be a waste of time and is useless information, why would you even post anything if that was all you had to point out ..nothing you posted ..was of any help
I dont care about fcc regulations...again...useless info
the ac9260 form factor and card is exact fit for wifi, and should operate completly fine.... the issue will be solved once driver is updated, since we are on first release
so, if your thinking of a reply other than helpful, positive information, dont do it....it would be a waste of data like your reply was
AlHill
jBlai3
Doc,
you already know....you were of no help, and only poked at it to irritate....
why would you be here to only poke at people like that?
I hope you find something better to do, something tells me your very lonley, to want to be here
AlHill
John, you came here looking for support.
I provided documents that explained the issue, which you refused to consider.
I did not write the documents. I am only the messenger.
The proper path for support is to contact Lenovo, which you refuse to do.
You are the one with the attitude problem, and think you know it all. So, why even bother coming here in the first place?
Take the information I provided and use it, or not.
And, drop the attitude - now. If you are looking to argue with someone, do it on another forum.
Doc
jBlai3
Doc,
your reply has not helped in anyway... again, why do you keep going
please go to someone elses support issue and polk at them instead of replying here
thanks in advance
