I have installed the newest drivers for intel wifi 9260 in windows 11 23H2, I mean driver version is 23.150.0.4 but the driver do not contain authentication that I need WPA3-Enterprise CCMP
what I can do to enable this authentication on this card?
Interface name: Wi-Fi
Driver : Intel(R) Wireless-AC 9260 160MHz
Vendor : Intel Corporation
Provider : Intel
Date : 2025-06-12
Version : 23.150.0.4
INF file : oem105.inf
Type : Native Wi-Fi Driver
Radio types supported : 802.11b 802.11g 802.11n 802.11a 802.11ac
FIPS 140-2 mode supported : Yes
802.11w Management Frame Protection supported : Yes
Hosted network supported : No
Authentication and cipher supported in infrastructure mode:
Open None
Open WEP-40bit
Open WEP-104bit
Open WEP
WPA-Enterprise TKIP
WPA-Enterprise CCMP
WPA-Personal TKIP
WPA-Personal CCMP
WPA2-Enterprise TKIP
WPA2-Enterprise CCMP
WPA2-Personal TKIP
WPA2-Personal CCMP
Open Vendor defined
WPA3-Personal CCMP
Vendor defined Vendor defined
WPA3-Enterprise 192 Bits GCMP-256
OWE CCMP
Number of supported bands : 2
2.4 GHz [ 0 MHz - 0 MHz]
5 GHz [ 0 MHz - 0 MHz]
IHV service present : Yes
IHV adapter OUI : [00 00 00], type: [00]
IHV extensibility DLL path: C:\WINDOWS\system32\IntelIHVRouter08.dll
IHV UI extensibility ClSID: {00000000-0000-0000-0000-000000000000}
IHV diagnostics CLSID : {00000000-0000-0000-0000-000000000000}
Wireless Display Supported: Yes (Graphics Driver: Yes, Wi-Fi Driver: Yes)
Hello Tutek,
To assist you effectively with your concern, kindly share the information below.
1. Is this a laptop or desktop system?
2. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
3. Is your network infrastructure (routers, access points) configured to support WPA3-Enterprise?
4. Have you verified that other devices on the same network can connect using WPA3-Enterprise?
Additionally, to have a better understanding of your system configuration and components please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
Best regards
Jed G.
1. This is a laptop Lenovo L590
2. This is original adapter, wifi drivers at the lenovo site are older that drivers on intel drivers page, so I have installed newer files.
3. I have corporate network that only work as WPA3-Enterprise and is needed CCMP algorithm.
3. I have many newer laptops that actually using this wifi network, but the older models like this lenovo L590 struggling connecting to it, I thought that after driver update I will fix this issue but not.
Here are authentications supported on a slightly newer laptop lenovo E15:
Driver : Intel(R) Wi-Fi 6 AX201 160MHz
Provider : Intel
Date : 07.04.2025
Version : 23.130.1.1
INF file : oem70.inf
Radio types supported : 802.11b 802.11g 802.11n 802.11a 802.11ac 802.11ax
FIPS 140 mode supported : Yes
Open None
Open WEP-40bit
Open WEP-104bit
Open WEP
WPA-Enterprise TKIP
WPA-Enterprise CCMP
WPA-Personal TKIP
WPA-Personal CCMP
WPA2-Personal TKIP
WPA2-Personal CCMP
Open Vendor defined
WPA3-Personal CCMP
OWE CCMP
IHV extensibility DLL path: C:\WINDOWS\system32\IntelIHVRouter10.dll
Wireless Display Supported: Yes (Graphics Driver: Yes, Wi-Fi Driver: Yes)as you can see at the bottom, it support WPA3-Enterprise CCMP, connection on this laptop is working.
Intel SSU file attached.
Hello Tutek,
Thank you for sharing all this information. I'll be investigating this matter further and I'll get back to you as soon as possible.
Best regards
Jed G.
Hello Tutek,
I sent you an email to continue the support. Please check your inbox at your earliest convenience.
Best regards
Jed G.
Hello, I have the same problem. How can I fix it?
