Wireless
8875 Discussions
Intel AX-200 network card not working under Linux Mint
sig230
I'm not having any luck getting an Intel Ax-200 Wifi Card to show up on my system.  Here are the basic details;
The system:
[code]
System: Kernel: 5.4.0-73-generic x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Cinnamon 4.8.6
wm: muffin dm: LightDM Distro: Linux Mint 20.1 Ulyssa base: Ubuntu 20.04 focal
Machine: Type: Desktop System: Dell product: OptiPlex 9010 v: 01 serial: <filter> Chassis:
type: 15 serial: <filter>
Mobo: Dell model: 051FJ8 v: A02 serial: <filter> BIOS: Dell v: A30 date: 06/28/2018
Battery: Device-1: hid-34:88:5d:29:90:81-battery model: Bluetooth Mouse M557 serial: N/A
charge: N/A status: Discharging
Device-2: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 50% (should be ignored) status: N/A
CPU: Topology: Quad Core model: Intel Core i7-3770 bits: 64 type: MT MCP arch: Ivy Bridge
rev: 9 L2 cache: 8192 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 54275
Speed: 3692 MHz min/max: 1600/3900 MHz Core speeds (MHz): 1: 3692 2: 3692 3: 3692
4: 3692 5: 3692 6: 3692 7: 3692 8: 3692
Graphics: Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics vendor: Dell
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0162
Display: x11 server: X.Org 1.20.9 driver: modesetting unloaded: fbdev,vesa
resolution: 1600x900~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 20.2.6
compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k5.4.0-73-generic
Network: Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e v: 3.2.6-k
port: f080 bus ID: 00:19.0 chip ID: 8086:1502
IF: eno1 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: f040 bus ID: 01:00.0
chip ID: 8086:2723
Device-3: Realtek type: USB driver: rtl88x2bu bus ID: 1-1.6:6 chip ID: 0bda:b812
IF: wlx4401bb9d497d state: up mac: <filter>
Drives: Local Storage: total: 6.41 TiB used: 873.84 GiB (13.3%)
ID-1: /dev/sda vendor: Hitachi model: HUA723020ALA640 size: 1.82 TiB speed: 6.0 Gb/s
serial: <filter>
ID-2: /dev/sdb type: USB vendor: JMicron Tech model: Generic DISK00 size: 931.51 GiB
serial: <filter>
ID-3: /dev/sdc type: USB vendor: JMicron Tech model: Generic DISK01 size: 489.05 GiB
serial: <filter>
ID-4: /dev/sdd type: USB vendor: JMicron Tech model: Generic DISK02 size: 489.05 GiB
serial: <filter>
ID-5: /dev/sde type: USB vendor: JMicron Tech model: Generic DISK03 size: 465.76 GiB
serial: <filter>
ID-6: /dev/sdf type: USB vendor: Western Digital model: WD Elements 1042
size: 465.76 GiB serial: <filter>
ID-7: /dev/sdg type: USB vendor: Western Digital model: WD Elements 10B8 size: 1.82 TiB
serial: <filter>
RAID: Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 bus ID: 00:1f.2
chip ID: 8086.2822
Partition: ID-1: / size: 1.79 TiB used: 78.40 GiB (4.3%) fs: ext4 dev: /dev/sda5
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0 chip ID: 1d6b:0002
Hub: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
chip ID: 8087:0024
Device-1: 1-1.3:3 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb rev: 2.0 chip ID: 0a12:0001
Device-2: 1-1.4:4 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid rev: 2.0 chip ID: 046d:c534
Device-3: 1-1.5:5 info: Western Digital Elements Portable (WDBU6Y WDBUZG)
type: Mass Storage driver: usb-storage rev: 2.1 chip ID: 1058:10b8
Device-4: 1-1.6:6 info: Realtek type: Network driver: rtl88x2bu rev: 2.1
chip ID: 0bda:b812
Hub: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0 chip ID: 1d6b:0002
Hub: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
chip ID: 8087:0024
Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 chip ID: 1d6b:0002
Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 chip ID: 1d6b:0003
Device-5: 4-3:2 info: Western Digital Elements SE Portable (WDBPCK) type: Mass Storage
driver: usb-storage rev: 3.0 chip ID: 1058:1042
Device-6: 4-4:3 info: JMicron / JMicron USA JMS567 SATA 6Gb/s bridge type: Mass Storage
driver: uas rev: 3.0 chip ID: 152d:0567
Sensors: System Temperatures: cpu: 76.0 C mobo: N/A
Fan Speeds (RPM): N/A
Repos: No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/google-chrome.list
1: deb [arch=amd64] http: //dl.google.com/linux/chrome/deb/ stable main
Active apt repos in: /etc/apt/sources.list.d/microsoft-edge-dev.list
1: deb [arch=amd64] http: //packages.microsoft.com/repos/edge/ stable main
Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
1: deb http: //mirrors.gigenet.com/linuxmint/repo ulyssa main upstream import backport
2: deb http: //archive.ubuntu.com/ubuntu focal main restricted universe multiverse
3: deb http: //archive.ubuntu.com/ubuntu focal-updates main restricted universe multiverse
4: deb http: //archive.ubuntu.com/ubuntu focal-backports main restricted universe multiverse
5: deb http: //security.ubuntu.com/ubuntu/ focal-security main restricted universe multiverse
6: deb http: //archive.canonical.com/ubuntu/ focal partner
Active apt repos in: /etc/apt/sources.list.d/trendtechcn.list
1: deb https: //deb.trendtechcn.com stable main
Info: Processes: 325 Uptime: 2d 1h 38m Memory: 15.53 GiB used: 4.71 GiB (30.4%) Init: systemd
v: 245 runlevel: 5 Compilers: gcc: 9.3.0 alt: 9 Client: Unknown python3.8 client
inxi: 3.0.38
[/code]
The output from lshw -c network:
[code] *-network
description: Network controller
product: Wi-Fi 6 AX200
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: 1a
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list
configuration: driver=iwlwifi latency=0
resources: irq:16 memory:f7c00000-f7c03fff
*-network
description: Ethernet interface
product: 82579LM Gigabit Network Connection (Lewisville)
physical id: 19
bus info: pci@0000:00:19.0
logical name: eno1
version: 04
serial: b8:ca:3a:75:a5:05
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k duplex=full firmware=0.13-4 ip=10.0.0.53 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
resources: irq:28 memory:f7d00000-f7d1ffff memory:f7d39000-f7d39fff ioport:f080(size=32)
*-network
description: Wireless interface
physical id: 1
bus info: usb@1:1.6
logical name: wlx4401bb9d497d
serial: 44:01:bb:9d:49:7d
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=rtl88x2bu ip=10.0.0.56 multicast=yes wireless=IEEE 802.11AC[/code]
From ip -a
[code]1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether b8:ca:3a:75:a5:05 brd ff:ff:ff:ff:ff:ff
inet 10.0.0.53/24 brd 10.0.0.255 scope global dynamic noprefixroute eno1
valid_lft 80089sec preferred_lft 80089sec
inet6 fe80::ed77:dc3f:ad3a:fba2/64 scope link noprefixroute
3: wlx4401bb9d497d: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 44:01:bb:9d:49:7d brd ff:ff:ff:ff:ff:ff
inet 10.0.0.56/24 brd 10.0.0.255 scope global dynamic noprefixroute wlx4401bb9d497d
valid_lft 80094sec preferred_lft 80094sec
inet6 fe80::e3d6:4d1b:3904:5cf2/64 scope link noprefixroute
valid_lft forever preferred_lft forever[/code]
As you can see the device is seen and driver loaded but it is not seen as a network device by ip.
I'm likely doing something silly but so far I'm simply not getting the card recognized.
sig230
Additional information.
I found a thread over at Bugzilla related to the issue I am seeing.  There it is reported that the adapter might only work in a PCIe x1 slot and not in the x4, x8 or x16 PCIe slots.  The system in question is using a Dell model: 051FJ8 mobo and does not have any PCIe x1 slots.
Fortunately I have a whole herd of computers and can try to find one that has an open PCIe x1 slot to see if it works there.
If it works in an x1 slot then hopefully a future update will fix the bug.
Works out of the box in a PCIe x1 slot.  Stupid card.
DeividA_Intel
Hello sig230,
1. The brand and model number of your system. You can also provide the Intel® System Support Utility for the Linux* Operating System for more details: https://downloadcenter.intel.com/download/26735/Intel-System-Support-Utility-for-the-Linux-Operating...
2. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
3. Have you update your drivers and BIOS?
4. Have you updated the o[erating system version/kernel?
5. Run the following commands and send us the outcome:
· modinfo iwlwifi > If there is no output, then the module isn’t installed this is the distribution installation issue.
· lsmod | grep iwlwifi > If the result is empty, the driver hasn't been loaded. Most likely to be a distribution issue.
· To verify, please type: dmesg | grep iwlwifi > If the result is empty, the driver wasn’t initialized and this is a distribution issue. If there is a result populated, proceed with the next step.
· dmesg | grep “no suitable firmware found!” > If the result is not empty, it means you don't have a suitable FW (api mentioned in the dmesg).
· Please visit here: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi for supported FW, or here https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/ for the latest versions.
6. If the above steps don't work, collect the debug data:
Type: dmesg | grep ASSERT
If the output is empty, please follow this wiki: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/debugging to extract dmesg and trace-cmd.
If the output has value, please collect it from the wiki FW dump too.
Deivid A.
sig230
None of your links work so here is my best effort at answering your questions.
The system is one that has been modified many times in the past.  The card is one I added.  Bios, drivers, OS and kernel have been updated.  Currently the Linux kernel is at 5.4.
here is the output from modinfo iwlwifi
jar@rosehill-7:~$ sudo  modinfo iwlwifi
[sudo] password for jar:
filename:       /lib/modules/5.4.0-73-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license:        GPL
author:         Copyright(c) 2003- 2015 Intel Corporation <linuxwifi@intel.com>
description:    Intel(R) Wireless WiFi driver for Linux
firmware:       iwlwifi-100-5.ucode
firmware:       iwlwifi-1000-5.ucode
firmware:       iwlwifi-135-6.ucode
firmware:       iwlwifi-105-6.ucode
firmware:       iwlwifi-2030-6.ucode
firmware:       iwlwifi-2000-6.ucode
firmware:       iwlwifi-5150-2.ucode
firmware:       iwlwifi-5000-5.ucode
firmware:       iwlwifi-6000g2b-6.ucode
firmware:       iwlwifi-6000g2a-6.ucode
firmware:       iwlwifi-6050-5.ucode
firmware:       iwlwifi-6000-6.ucode
firmware:       iwlwifi-7265D-29.ucode
firmware:       iwlwifi-7265-17.ucode
firmware:       iwlwifi-3168-29.ucode
firmware:       iwlwifi-3160-17.ucode
firmware:       iwlwifi-7260-17.ucode
firmware:       iwlwifi-8265-36.ucode
firmware:       iwlwifi-8000C-36.ucode
firmware:       iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware:       iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware:       iwlwifi-ty-a0-gf-a0-50.ucode
firmware:       iwlwifi-so-a0-gf-a0-50.ucode
firmware:       iwlwifi-so-a0-hr-b0-50.ucode
firmware:       iwlwifi-so-a0-jf-b0-50.ucode
firmware:       iwlwifi-cc-a0-50.ucode
firmware:       iwlwifi-QuQnj-b0-jf-b0-50.ucode
firmware:       iwlwifi-QuZ-a0-jf-b0-50.ucode
firmware:       iwlwifi-QuZ-a0-hr-b0-50.ucode
firmware:       iwlwifi-Qu-b0-jf-b0-50.ucode
firmware:       iwlwifi-Qu-c0-hr-b0-50.ucode
firmware:       iwlwifi-QuQnj-a0-hr-a0-50.ucode
firmware:       iwlwifi-QuQnj-b0-hr-b0-50.ucode
firmware:       iwlwifi-QuQnj-f0-hr-a0-50.ucode
firmware:       iwlwifi-Qu-a0-jf-b0-50.ucode
firmware:       iwlwifi-Qu-a0-hr-a0-50.ucode
srcversion:     FFD67B38D4F55BA93301369
alias:          pci:v00008086d00007AF0sv*sd00000A10bc*sc*i*
alias:          pci:v00008086d00007AF0sv*sd00000510bc*sc*i*
alias:          pci:v00008086d00007AF0sv*sd00000310bc*sc*i*
alias:          pci:v00008086d00007AF0sv*sd00000090bc*sc*i*
alias:          pci:v00008086d00007A70sv*sd00000A10bc*sc*i*
alias:          pci:v00008086d00007A70sv*sd00000510bc*sc*i*
alias:          pci:v00008086d00007A70sv*sd00000310bc*sc*i*
alias:          pci:v00008086d00007A70sv*sd00000090bc*sc*i*
alias:          pci:v00008086d00002725sv*sd000000B0bc*sc*i*
alias:          pci:v00008086d00002725sv*sd00000A10bc*sc*i*
alias:          pci:v00008086d00002725sv*sd00000510bc*sc*i*
alias:          pci:v00008086d00002725sv*sd00000310bc*sc*i*
alias:          pci:v00008086d00002725sv*sd00000024bc*sc*i*
alias:          pci:v00008086d00002725sv*sd00000020bc*sc*i*
alias:          pci:v00008086d00002725sv*sd00000090bc*sc*i*
alias:          pci:v00008086d00002723sv*sd00004088bc*sc*i*
alias:          pci:v00008086d00002723sv*sd00004080bc*sc*i*
alias:          pci:v00008086d00002723sv*sd00002080bc*sc*i*
alias:          pci:v00008086d00002723sv*sd00001654bc*sc*i*
alias:          pci:v00008086d00002723sv*sd00001653bc*sc*i*
alias:          pci:v00008086d00002723sv*sd0000008Cbc*sc*i*
alias:          pci:v00008086d00002723sv*sd00000088bc*sc*i*
alias:          pci:v00008086d00002723sv*sd00000084bc*sc*i*
alias:          pci:v00008086d00002723sv*sd00000080bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00004244bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00004070bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00002074bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00001652bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00001651bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000A10bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000244bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd0000007Cbc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000078bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000074bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000070bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000044bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00004244bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00004070bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00002074bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00001652bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00001651bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000244bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd0000007Cbc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000078bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000074bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000070bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000044bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00004244bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00004070bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00002074bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00001652bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00001651bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000310bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000244bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd0000007Cbc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000078bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000074bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000070bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000044bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00004244bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00004070bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00002074bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00001652bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00001651bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00001080bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000A10bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000310bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000244bc*sc*i*
alias:          pci:v00008086d00002720sv*sd0000007Cbc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000078bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000074bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000070bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000044bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000040bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000000bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00004244bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00004070bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00002074bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00001652bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00001651bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000310bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000244bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd0000007Cbc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000078bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000074bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000070bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00004244bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00004070bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00002074bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00001652bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00001651bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000310bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000244bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd0000007Cbc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000078bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000074bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000070bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000030bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd000042A4bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00004234bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd000040A4bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00004034bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00004030bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00002034bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00002030bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00001552bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00001551bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00001210bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00001030bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00001010bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd000002A4bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd000002A0bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00000264bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00000260bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00000238bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00000234bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00000230bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd000000A4bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd000000A0bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00000064bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00000060bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00000038bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00000034bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00000030bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd000042A4bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00004234bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd000040A4bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00004034bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00004030bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00002034bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00002030bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00001552bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00001551bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00001030bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd000002A4bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd000002A0bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000264bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000260bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000238bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000234bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000230bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd000000A4bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd000000A0bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000064bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000060bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000038bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000034bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000030bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd000042A4bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00004234bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd000040A4bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00004034bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00004030bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00002A10bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00002034bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00002030bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00002010bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00001552bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00001551bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00001210bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00001030bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00001010bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000A10bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000710bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000610bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000510bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000410bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000310bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd000002A4bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd000002A0bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000264bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000260bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000238bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000234bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000230bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000210bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd000000A4bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd000000A0bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000064bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000060bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000038bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000034bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000030bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000010bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000000bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd000042A4bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00004234bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd000040A4bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00004034bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00004030bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00002034bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00002030bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00001552bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00001551bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00001030bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd000002A4bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd000002A0bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000264bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000260bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000238bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000234bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000230bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd000000A4bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd000000A0bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000064bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000060bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000038bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000034bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000030bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd000042A4bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00004234bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd000040A4bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00004034bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00004030bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00002034bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00002030bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00001552bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00001551bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00001030bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd000002A4bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd000002A0bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00000264bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00000260bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00000238bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00000234bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00000230bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd000000A4bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd000000A0bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00000064bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00000060bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00000038bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00000034bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd000042A4bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00004234bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd000040A4bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00004034bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00004030bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00002034bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00002030bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00001552bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00001551bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd000002A4bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd000002A0bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000264bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000260bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000238bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000234bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000230bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd000000A4bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd000000A0bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000064bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000060bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000038bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000034bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd000042A4bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00004234bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd000040A4bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00004034bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00004030bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00002034bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00002030bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00001552bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00001551bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00001210bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00001030bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00001010bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd000002A4bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd000002A0bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00000264bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00000260bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00000238bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00000234bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00000230bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd000000A4bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd000000A0bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00000064bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00000060bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00000038bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00000034bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00000030bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd000042A4bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00004234bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd000040A4bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00004034bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00004030bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00002034bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00002030bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00001552bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00001551bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00001210bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00001030bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00001010bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd000002A4bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd000002A0bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00000264bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00000260bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00000238bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00000234bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00000230bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd000000A4bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd000000A0bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00000064bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00000060bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00000038bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00000034bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00000030bc*sc*i*
alias:          pci:v00008086d00002720sv*sd000042A4bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00004234bc*sc*i*
alias:          pci:v00008086d00002720sv*sd000040A4bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00004034bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00004030bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00002034bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00002030bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00001552bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00001551bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00001030bc*sc*i*
alias:          pci:v00008086d00002720sv*sd000002A4bc*sc*i*
alias:          pci:v00008086d00002720sv*sd000002A0bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000264bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000260bc*sc*i*
alias:          pci:v00008086d00002720sv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000238bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000234bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000230bc*sc*i*
alias:          pci:v00008086d00002720sv*sd000000A4bc*sc*i*
alias:          pci:v00008086d00002720sv*sd000000A0bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000064bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000060bc*sc*i*
alias:          pci:v00008086d00002720sv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000038bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000034bc*sc*i*
alias:          pci:v00008086d0000271Csv*sd00000214bc*sc*i*
alias:          pci:v00008086d0000271Bsv*sd00000214bc*sc*i*
alias:          pci:v00008086d0000271Bsv*sd00000210bc*sc*i*
alias:          pci:v00008086d0000271Bsv*sd00000014bc*sc*i*
alias:          pci:v00008086d0000271Bsv*sd00000010bc*sc*i*
alias:          pci:v00008086d00002526sv*sd0000E014bc*sc*i*
alias:          pci:v00008086d00002526sv*sd0000E010bc*sc*i*
alias:          pci:v00008086d00002526sv*sd0000A014bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00008010bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00008014bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00006014bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00006010bc*sc*i*
alias:          pci:v00008086d00002526sv*sd000042A4bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00004234bc*sc*i*
alias:          pci:v00008086d00002526sv*sd000040A4bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00004034bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00004030bc*sc*i*
alias:          pci:v00008086d00002526sv*sd0000401Cbc*sc*i*
alias:          pci:v00008086d00002526sv*sd00004018bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00004010bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00002034bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00002030bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00001610bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00001552bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00001551bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00001550bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00001420bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00001410bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00001210bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00001030bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00001010bc*sc*i*
alias:          pci:v00008086d00002526sv*sd000002A4bc*sc*i*
alias:          pci:v00008086d00002526sv*sd000002A0bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000264bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000260bc*sc*i*
alias:          pci:v00008086d00002526sv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000238bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000234bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000230bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000214bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000210bc*sc*i*
alias:          pci:v00008086d00002526sv*sd000000A4bc*sc*i*
alias:          pci:v00008086d00002526sv*sd000000A0bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000064bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000060bc*sc*i*
alias:          pci:v00008086d00002526sv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000038bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000034bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000030bc*sc*i*
alias:          pci:v00008086d00002526sv*sd0000001Cbc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000018bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000014bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000010bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd000042A4bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00004234bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd000040A4bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00004034bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00004030bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00002034bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00002030bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00001552bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00001551bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd000002A4bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd000002A0bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000264bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000260bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000238bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000234bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000230bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd000000A4bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd000000A0bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000064bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000060bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000038bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000034bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd000042A4bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00004234bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd000040A4bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00004034bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00004030bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00002034bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00002030bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00001552bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00001551bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00001030bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd000002A4bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd000002A0bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000264bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000260bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000238bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000234bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000230bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd000000A4bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd000000A0bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000064bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000060bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000038bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000034bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009074bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000014bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000012bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001012bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00003E01bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00003E02bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001014bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000850bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000950bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000930bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000910bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000810bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008050bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000150bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000050bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd000010D0bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00004010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000000bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000930bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000950bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000850bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000910bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000810bc*sc*i*
alias:          pci:v00008086d000024F6sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000024F5sv*sd00000010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000044bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000004bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008130bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd0000D030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd0000C030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00009030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00008030bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000B0B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D0B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C010bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00001030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000250bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001012bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000012bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd000001F0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd000010B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000010bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009E10bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009400bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009000bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd0000520Abc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005212bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005F10bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005490bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005290bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005590bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005190bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005090bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005420bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000502Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005020bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009410bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009310bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009510bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009200bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009210bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009112bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009110bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000900Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009012bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009010bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005202bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005102bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005002bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005200bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000500Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005000bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00001010bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005400bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005510bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005410bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005412bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005012bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005C10bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005210bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005302bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005310bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005100bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005110bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005010bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00000000bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002150bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002050bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002110bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002010bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00008110bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00008010bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004210bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004310bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004110bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004510bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004410bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004212bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004012bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004010bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00001170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00001070bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008570bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008470bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008272bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008370bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008270bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008062bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008060bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008172bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008072bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008070bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000370bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000472bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000470bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000272bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000270bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000062bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000060bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000172bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000072bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000070bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C420bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C220bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C02Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C020bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C360bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C370bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C560bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C570bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C462bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C460bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C472bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C470bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C262bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C26Abc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C260bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C272bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000CC60bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000CC70bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C270bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C760bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C770bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C162bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C062bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C160bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C06Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C060bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C070bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004420bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004220bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000402Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004020bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005770bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005070bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004360bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004370bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004560bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004570bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A6Cbc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A6Ebc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A70bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000486Ebc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004870bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004462bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000446Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004460bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004472bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004470bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004262bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000426Abc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004260bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004272bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004270bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004162bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004062bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004160bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000406Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004060bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004C70bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004C60bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004070bc*sc*i*
alias:          pci:v00008086d00000892sv*sd00000462bc*sc*i*
alias:          pci:v00008086d00000893sv*sd00000262bc*sc*i*
alias:          pci:v00008086d00000892sv*sd00000062bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000822bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000422bc*sc*i*
alias:          pci:v00008086d00000895sv*sd00000222bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000022bc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd00005260bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004860bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd0000446Abc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004460bc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd0000426Abc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd00004260bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd0000406Abc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004060bc*sc*i*
alias:          pci:v00008086d00000887sv*sd00004462bc*sc*i*
alias:          pci:v00008086d00000888sv*sd00004262bc*sc*i*
alias:          pci:v00008086d00000887sv*sd00004062bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004822bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004422bc*sc*i*
alias:          pci:v00008086d00000891sv*sd00004222bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004022bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005027bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005025bc*sc*i*
alias:          pci:v00008086d00000897sv*sd00005017bc*sc*i*
alias:          pci:v00008086d00000897sv*sd00005015bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005007bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005005bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001027bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001025bc*sc*i*
alias:          pci:v00008086d000008AFsv*sd00001017bc*sc*i*
alias:          pci:v00008086d000008AFsv*sd00001015bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001007bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001005bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001216bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001226bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001206bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001215bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001225bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001205bc*sc*i*
alias:          pci:v00008086d00000886sv*sd00001317bc*sc*i*
alias:          pci:v00008086d00000886sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001327bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001307bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000089sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000089sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005226bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005225bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005221bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005207bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005206bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005205bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005201bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005216bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005215bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005211bc*sc*i*
alias:          pci:v00008086d0000008Bsv*sd00005317bc*sc*i*
alias:          pci:v00008086d0000008Bsv*sd00005315bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005327bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005325bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005307bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005305bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001304bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00004820bc*sc*i*
alias:          pci:v00008086d00000085sv*sd0000C228bc*sc*i*
alias:          pci:v00008086d00000085sv*sd0000C220bc*sc*i*
alias:          pci:v00008086d00000082sv*sd0000C020bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001318bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001328bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001308bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001307bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00004239sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00004239sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00004238sv*sd00001118bc*sc*i*
alias:          pci:v00008086d00004238sv*sd00001111bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001326bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001321bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001307bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001306bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001301bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001128bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001121bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001108bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001101bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001316bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001216bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001311bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001211bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001326bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001321bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001221bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001306bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001206bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001301bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001201bc*sc*i*
alias:          pci:v00008086d0000423Bsv*sd00001011bc*sc*i*
alias:          pci:v00008086d0000423Asv*sd00001021bc*sc*i*
alias:          pci:v00008086d0000423Asv*sd00001001bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001114bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001014bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001111bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001011bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001104bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001004bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001101bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001001bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001124bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001024bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001121bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001021bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001216bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001215bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001314bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001214bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001211bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001226bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001225bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001324bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001224bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001221bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001206bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001205bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001304bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001204bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001201bc*sc*i*
depends:        cfg80211
retpoline:      Y
intree:         Y
vermagic:       5.4.0-73-generic SMP mod_unload modversions
sig_id:         PKCS#7
signer:         Build time autogenerated kernel key
sig_key:        76:5C:D9:9F:5C:00:1C:F9:61:BE:32:67:DA:52:57:FE:F4:C2:E1:6E
sig_hashalgo:   sha512
signature:      BF:E3:8F:C5:F4:10:98:CB:BF:7A:26:A2:B7:F4:98:73:5A:7F:D4:2C:
		6E:EC:23:50:88:53:E5:05:27:C8:28:C4:D9:DA:C3:52:1A:A0:5D:4C:
		83:D7:4B:84:B7:48:F8:80:7B:B4:28:9B:33:B7:79:18:90:55:EB:6D:
		7B:61:C0:23:CF:A4:BA:92:EB:D4:F5:C1:3A:81:E1:7B:A7:6B:E2:DE:
		AA:B0:A7:D1:FB:29:14:7B:54:7B:62:DB:C1:8D:13:6D:FB:E7:37:97:
		18:4C:1A:FC:0D:11:9D:2F:0D:69:B9:C6:52:17:BF:36:5B:EA:24:11:
		BB:1F:FA:53:6A:CF:E8:D2:5D:E1:07:13:44:00:D0:7F:78:2E:5D:DC:
		DB:A9:66:D9:28:CC:52:D3:0E:B0:B3:BA:93:B0:5B:BA:8A:41:D8:99:
		A1:9C:B4:D6:1E:F3:12:4C:23:A0:D6:9C:6A:36:B7:14:3C:33:94:43:
		15:ED:37:28:C8:45:E2:8B:3E:D0:08:71:D6:FD:06:69:B9:F3:8D:73:
		B4:68:BF:3D:99:0F:94:02:B5:8C:AC:3D:AF:62:02:9D:FD:E2:09:1F:
		3B:F2:10:DD:57:FA:B1:B3:1A:8B:AE:44:35:A5:E4:0D:E2:A7:8B:09:
		F9:DB:0F:CB:58:CE:48:30:84:FA:F3:EB:BA:AB:B4:45:75:CE:DA:7D:
		B2:5D:55:9C:DF:98:5D:37:93:15:4E:97:09:DD:BF:7D:2D:64:D2:7D:
		FD:CF:CB:3A:91:26:D6:45:BF:F4:31:A3:1D:EC:BA:1B:C8:FA:AA:F1:
		EF:14:79:D6:97:A7:E9:B4:8D:11:73:E0:18:79:AD:34:7F:50:67:B2:
		DB:8B:35:C2:8C:22:BA:2E:48:6D:3F:98:CF:9A:D5:CF:AF:3B:0B:D6:
		E2:03:1E:AD:D1:68:F0:5B:72:66:F9:AD:CE:EC:F2:71:B8:59:9D:E3:
		1C:4B:48:70:DE:A9:BE:46:C7:40:F5:85:6C:8E:92:FD:86:3F:90:C6:
		75:C0:1E:9B:64:CB:2E:10:4D:03:8E:36:52:40:64:F4:32:35:F5:2D:
		91:EF:F8:C8:19:78:7D:3A:2B:5C:C7:07:A6:2E:A4:16:18:E7:54:AE:
		6A:6D:0D:CD:96:2C:E6:08:F0:03:4A:FE:75:25:AA:82:94:7D:87:4F:
		BB:B2:01:24:61:3D:E4:F7:C2:DD:2A:BE:5A:55:26:56:94:62:6D:AF:
		D5:BA:8B:F7:63:1C:94:18:CE:DC:B8:38:EC:9A:C0:B1:69:07:76:37:
		71:43:50:07:15:8E:D6:2D:39:C0:B5:A1:65:A3:64:59:9F:28:5A:D5:
		CD:3B:C1:2A:4A:9A:74:3E:1E:E2:EE:7A
parm:           swcrypto:using crypto in software (default 0 [hardware]) (int)
parm:           11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm:           amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K 4: 2K (default 0) (int)
parm:           fw_restart:restart firmware in case of error (default true) (bool)
parm:           antenna_coupling:specify antenna coupling in dB (default: 0 dB) (int)
parm:           nvm_file:NVM file name (charp)
parm:           lar_disable:disable LAR functionality (default: N) (bool)
parm:           uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm:           enable_ini:Enable debug INI TLV FW debug infrastructure (default: 0 (bool)
parm:           bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm:           led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm:           power_save:enable WiFi power management (default: disable) (bool)
parm:           power_level:default power save level (range from 1 - 5, default: 1) (int)
parm:           fw_monitor:firmware monitor - to debug FW (default: false - needs lots of memory) (bool)
parm:           disable_11ac:Disable VHT capabilities (default: false) (bool)
parm:           remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm:           disable_11ax:Disable HE capabilities (default: false) (bool)
output from lsmod | grep iwlwifi
jar@rosehill-7:~$ sudo lsmod | grep iwlwifi
iwlwifi               331776  1 iwlmvm
cfg80211              704512  5 wl,iwlmvm,88x2bu,iwlwifi,mac80211
output from dmesg | grep iwlwifi
jar@rosehill-7:~$ sudo dmesg | grep iwlwifi
[   16.426528] iwlwifi 0000:01:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 58.3.35.22
[   16.426531] iwlwifi 0000:01:00.0: Found debug destination: EXTERNAL_DRAM
[   16.426531] iwlwifi 0000:01:00.0: Found debug configuration: 0
[   16.426705] iwlwifi 0000:01:00.0: loaded firmware version 50.3e391d3e.0 op_mode iwlmvm
[   16.981923] iwlwifi 0000:01:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[   16.992499] iwlwifi 0000:01:00.0: Applying debug destination EXTERNAL_DRAM
[   16.992813] iwlwifi 0000:01:00.0: Allocated 0x00400000 bytes for firmware monitor.
[   18.002977] iwlwifi 0000:01:00.0: Collecting data: trigger 15 fired.
[   18.003044] iwlwifi 0000:01:00.0: Start IWL Error Log Dump:
[   18.003046] iwlwifi 0000:01:00.0: Status: 0x00000000, count: 6
[   18.003047] iwlwifi 0000:01:00.0: Loaded firmware version: 50.3e391d3e.0
[   18.003049] iwlwifi 0000:01:00.0: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[   18.003050] iwlwifi 0000:01:00.0: 0x0020A2F0 | trm_hw_status0
[   18.003050] iwlwifi 0000:01:00.0: 0x00000000 | trm_hw_status1
[   18.003051] iwlwifi 0000:01:00.0: 0x004F9608 | branchlink2
[   18.003052] iwlwifi 0000:01:00.0: 0x004E4578 | interruptlink1
[   18.003053] iwlwifi 0000:01:00.0: 0x004E4578 | interruptlink2
[   18.003054] iwlwifi 0000:01:00.0: 0x004F3858 | data1
[   18.003055] iwlwifi 0000:01:00.0: 0x00001000 | data2
[   18.003055] iwlwifi 0000:01:00.0: 0x00000000 | data3
[   18.003056] iwlwifi 0000:01:00.0: 0x00000000 | beacon time
[   18.003057] iwlwifi 0000:01:00.0: 0x0000A4C9 | tsf low
[   18.003058] iwlwifi 0000:01:00.0: 0x00000000 | tsf hi
[   18.003059] iwlwifi 0000:01:00.0: 0x00000000 | time gp1
[   18.003059] iwlwifi 0000:01:00.0: 0x00010483 | time gp2
[   18.003060] iwlwifi 0000:01:00.0: 0x00000001 | uCode revision type
[   18.003061] iwlwifi 0000:01:00.0: 0x00000032 | uCode version major
[   18.003063] iwlwifi 0000:01:00.0: 0x3E391D3E | uCode version minor
[   18.003064] iwlwifi 0000:01:00.0: 0x00000340 | hw version
[   18.003066] iwlwifi 0000:01:00.0: 0x18C89000 | board version
[   18.003067] iwlwifi 0000:01:00.0: 0x8002FF03 | hcmd
[   18.003068] iwlwifi 0000:01:00.0: 0x20028000 | isr0
[   18.003069] iwlwifi 0000:01:00.0: 0x00000000 | isr1
[   18.003070] iwlwifi 0000:01:00.0: 0x08F00002 | isr2
[   18.003071] iwlwifi 0000:01:00.0: 0x00C0000C | isr3
[   18.003072] iwlwifi 0000:01:00.0: 0x00000000 | isr4
[   18.003073] iwlwifi 0000:01:00.0: 0x00000000 | last cmd Id
[   18.003073] iwlwifi 0000:01:00.0: 0x004F3858 | wait_event
[   18.003074] iwlwifi 0000:01:00.0: 0x00000000 | l2p_control
[   18.003075] iwlwifi 0000:01:00.0: 0x00000020 | l2p_duration
[   18.003076] iwlwifi 0000:01:00.0: 0x00000000 | l2p_mhvalid
[   18.003077] iwlwifi 0000:01:00.0: 0x00000000 | l2p_addr_match
[   18.003078] iwlwifi 0000:01:00.0: 0x00000009 | lmpm_pmg_sel
[   18.003078] iwlwifi 0000:01:00.0: 0x00000000 | timestamp
[   18.003079] iwlwifi 0000:01:00.0: 0x0000F81C | flow_handler
[   18.003102] iwlwifi 0000:01:00.0: Start IWL Error Log Dump:
[   18.003103] iwlwifi 0000:01:00.0: Status: 0x00000000, count: 7
[   18.003104] iwlwifi 0000:01:00.0: 0x20100222 | ADVANCED_SYSASSERT
[   18.003105] iwlwifi 0000:01:00.0: 0x00000000 | umac branchlink1
[   18.003106] iwlwifi 0000:01:00.0: 0x80465A16 | umac branchlink2
[   18.003107] iwlwifi 0000:01:00.0: 0xC00870D6 | umac interruptlink1
[   18.003107] iwlwifi 0000:01:00.0: 0x00000000 | umac interruptlink2
[   18.003108] iwlwifi 0000:01:00.0: 0xDEADBEEF | umac data1
[   18.003109] iwlwifi 0000:01:00.0: 0xDEADBEEF | umac data2
[   18.003110] iwlwifi 0000:01:00.0: 0xDEADBEEF | umac data3
[   18.003111] iwlwifi 0000:01:00.0: 0x00000032 | umac major
[   18.003111] iwlwifi 0000:01:00.0: 0x3E391D3E | umac minor
[   18.003112] iwlwifi 0000:01:00.0: 0x00010477 | frame pointer
[   18.003113] iwlwifi 0000:01:00.0: 0xC0886AFC | stack pointer
[   18.003114] iwlwifi 0000:01:00.0: 0x0000FFFF | last host cmd
[   18.003115] iwlwifi 0000:01:00.0: 0x00000000 | isr status reg
[   18.003120] iwlwifi 0000:01:00.0: Fseq Registers:
[   18.003122] iwlwifi 0000:01:00.0: 0x60000000 | FSEQ_ERROR_CODE
[   18.003125] iwlwifi 0000:01:00.0: 0x80290008 | FSEQ_TOP_INIT_VERSION
[   18.003127] iwlwifi 0000:01:00.0: 0x00050008 | FSEQ_CNVIO_INIT_VERSION
[   18.003130] iwlwifi 0000:01:00.0: 0x0000A503 | FSEQ_OTP_VERSION
[   18.003133] iwlwifi 0000:01:00.0: 0x80000003 | FSEQ_TOP_CONTENT_VERSION
[   18.003135] iwlwifi 0000:01:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[   18.003138] iwlwifi 0000:01:00.0: 0x00100530 | FSEQ_CNVI_ID
[   18.003140] iwlwifi 0000:01:00.0: 0x00000532 | FSEQ_CNVR_ID
[   18.003143] iwlwifi 0000:01:00.0: 0x00100530 | CNVI_AUX_MISC_CHIP
[   18.003148] iwlwifi 0000:01:00.0: 0x00000532 | CNVR_AUX_MISC_CHIP
[   18.003152] iwlwifi 0000:01:00.0: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[   18.003157] iwlwifi 0000:01:00.0: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[   18.003173] iwlwifi 0000:01:00.0: SecBoot CPU1 Status: 0x5ecb, CPU2 Status: 0x3
[   18.003175] iwlwifi 0000:01:00.0: Failed to start RT ucode: -110
[   18.003177] iwlwifi 0000:01:00.0: Firmware not running - cannot dump error
[   18.015037] iwlwifi 0000:01:00.0: Failed to run INIT ucode: -110
output from dmesg | grep “no suitable firmware found!”
jar@rosehill-7:~$ sudo dmesg | grep “no suitable firmware found!”
bash: !”: event not found
sig230
n_scott_pearson
Talk to Dell. The issue is likely something to do with the BIOS' support for PCIe initialization and steering. I wouldn't bet on them delivering a fix, however; their track record with this kind of issue is pitiful.
sig230
It's not Dell specific.  It also doesn't work on ASRock and Aorus  AMD motherboards.  Works in the X1 slots but not in the wider ones. In the Bugzilla thread the issues has also been reported with Asus & Gigabit mobos.  I currently have it working in an x1 slot on an AMD B450 Aorus board.
It also appears to be a common issue under quite a few different major Linux flavors and with kernels  from 5.1 through 5.8.
