Wireless
9023 Discussions
Intel AX210 not detect 6GHz network on Linux/Android platform
jsun
I am trying to get the Intel AX210 working on NXP iMX8 eval board running Android 12 or 13. Following is my setup:
  • Android 12 with Linux kernel 5.10, use firmware iwlwifi-ty-a0-gf-a0-59.ucode
  • Android 13 with Linux kernel 5.15, use firmware iwlwifi-ty-a0-gf-a0-66.ucode
  • Country Region (regulatory domain) is US
  • TP-Link AXE5400 (Archer AXE75) Tri-Band 6-Stream Wi-Fi 6E Router
On Android 12, the AX210 is able to connect to 2.4GHz/5GHz network, but not able to detect 6GHz network. I can see the 6GHz frequency is enabled in AX210 (via the "iw list" command), but the AX210 can't detect 6GHz network, and can't scan the 6GHz frequency.
I know the 6GHz network on the TP-Link WiFi 6E Router is working fine, because I was able to connect to this 6GHz network using the Mediatek Wi-Fi 6E (RZ616) Wireless LAN Card.
On Android 13, the AX210 driver seems to fail loading the firmware:
[    9.541989][  T178] Intel(R) Wireless WiFi driver for Linux
[    9.547827][  T178] iwlwifi 0001:01:00.0: enabling device (0000 -> 0002)
[    9.554666][  T178] iwlwifi 0001:01:00.0: pci_enable_msi failed - -22
[    9.562933][    T1] init: [libfs_mgr]umount_retry(): unmount(/data) succeeded
[    9.570289][    T1] init: Calling: /system/bin/vdc cryptfs encryptFstab /dev/block/by-name/userdata /data false f2fs
[    9.582154][   T42] iwlwifi 0001:01:00.0: api flags index 2 larger than supported by driver
[    9.592416][   T42] iwlwifi 0001:01:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.63.2.2
[    9.602508][   T42] iwlwifi 0001:01:00.0: loaded firmware version 66.f1c864e0.0 ty-a0-gf-a0-66.ucode op_mode iwlmvm
[    9.621745][  T178] iwlwifi 0001:01:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[    9.636763][  T178] thermal thermal_zone2: failed to read out thermal zone (-61)
[    9.689486][  T197] vold: keystore2 Keystore generateKey returned service specific error: -67
[    9.698174][  T197] vold: Failed to generate rollback-resistant key.  This is expected if keystore doesn't support rollback resistance.  Falling back to non-rollback-resistant key.
[   10.065273][  T178] iwlwifi 0001:01:00.0: Timeout waiting for PNVM load!
[   10.072045][  T178] iwlwifi 0001:01:00.0: Failed to start RT ucode: -110
[   10.078804][  T178] iwlwifi 0001:01:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[   10.088822][  T178] iwlwifi 0001:01:00.0: Start IWL Error Log Dump:
It got the error meessage: "Timeout waiting for PNVM load!", and I did not use the pnvm file.
Could you please advice which version of Linux kernel supports the AX210 on 6GHz network? Also what version of the "iwlwifi-ty" firmware file to use?
Thank you and Best Regards.
DeividA_Intel
Hello jsun,
Thanks for your patience. I want to let you know that the Intel 6E AX210 supports Bluetooth-UART only on the selected M.2 1216 soldered-down SKUs, and its platform support is still pending. I recommend you work with your Intel sales representative if you need more details.
As for the AX210 datasheet, you can apply for the Intel RDC access and obtain the Intel® Wi-Fi 6E AX210 (Typhoon Peak 2) External Product Specification (EPS):
Regarding the Android operating system, the wireless product specification document only lists Windows and Linux, Android is not officially classified as a support operating system for Intel wireless products. The support for Android is limited.
Intel Customer Support may offer best-effort help (e.g. Basic troubleshooting on AX210 installation) for Android. For more assistance or support to develop an Intel wireless product on Android, I recommend you also work with your Intel sales representative.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
jsun
Hi Deivid,
Thank you very much for all your help and great support.
You may close this ticket.
Best Regards.
