Wireless
8630 Discussions
Intel AX211 (Wi-Fi) is non functional
tyrell
Laptop: LG Gram Style 14 (2023)
I have tried both Windows and Linux (latest drivers) but the wifi is non functional. It worked when my laptop arrived but then it didn't on one random day upon turning the machine on. I don't remember doing anything related to wifi or anything unusual around that time.
Updating the drivers from Intel's website or LG's website did not help with the issue.
Error on Windows:
This device cannot start. (Code 10)
{Operation Failed}
The requested operation was unsuccessful.
-- or sometimes --
Windows has stopped this device because it has reported problems. (Code 43)
Error on Linux:
[ 15.958383] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6E AX211 160MHz, REV=0x370
[ 17.021358] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[ 17.021419] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 17.021428] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[ 17.021438] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 17.021454] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x7f73, CPU2 Status: 0xb03
[ 17.021464] iwlwifi 0000:00:14.3: WFPM_LMAC1_PD_NOTIFICATION: 0x0
[ 17.021473] iwlwifi 0000:00:14.3: HPM_SECONDARY_DEVICE_STATE: 0x42
[ 17.021482] iwlwifi 0000:00:14.3: WFPM_MAC_OTP_CFG7_ADDR: 0x0
[ 17.021490] iwlwifi 0000:00:14.3: WFPM_MAC_OTP_CFG7_DATA: 0x0
[ 17.021499] iwlwifi 0000:00:14.3: UMAC PC: 0xc0081904
[ 17.021508] iwlwifi 0000:00:14.3: LMAC PC: 0x157fc
[ 17.021511] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 17.022686] iwlwifi 0000:00:14.3: Loaded firmware version: 72.daa05125.0 so-a0-gf-a0-72.ucode
[ 17.022689] iwlwifi 0000:00:14.3: 0x00000000 | ADVANCED_SYSASSERT
[ 17.022691] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status0
[ 17.022692] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 17.022693] iwlwifi 0000:00:14.3: 0x00000000 | branchlink2
[ 17.022694] iwlwifi 0000:00:14.3: 0x00000000 | interruptlink1
[ 17.022695] iwlwifi 0000:00:14.3: 0x00000000 | interruptlink2
[ 17.022696] iwlwifi 0000:00:14.3: 0x00000000 | data1
[ 17.022697] iwlwifi 0000:00:14.3: 0x00000000 | data2
[ 17.022698] iwlwifi 0000:00:14.3: 0x00000000 | data3
[ 17.022699] iwlwifi 0000:00:14.3: 0x00000000 | beacon time
[ 17.022700] iwlwifi 0000:00:14.3: 0x00000000 | tsf low
[ 17.022701] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[ 17.022702] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 17.022703] iwlwifi 0000:00:14.3: 0x00000000 | time gp2
[ 17.022704] iwlwifi 0000:00:14.3: 0x00000000 | uCode revision type
[ 17.022705] iwlwifi 0000:00:14.3: 0x00000000 | uCode version major
[ 17.022706] iwlwifi 0000:00:14.3: 0x00000000 | uCode version minor
[ 17.022707] iwlwifi 0000:00:14.3: 0x00000000 | hw version
[ 17.022708] iwlwifi 0000:00:14.3: 0x00000000 | board version
[ 17.022709] iwlwifi 0000:00:14.3: 0x00000000 | hcmd
[ 17.022710] iwlwifi 0000:00:14.3: 0x00000000 | isr0
[ 17.022710] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 17.022711] iwlwifi 0000:00:14.3: 0x00000000 | isr2
[ 17.022712] iwlwifi 0000:00:14.3: 0x00000000 | isr3
[ 17.022713] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 17.022714] iwlwifi 0000:00:14.3: 0x00000000 | last cmd Id
[ 17.022715] iwlwifi 0000:00:14.3: 0x00000000 | wait_event
[ 17.022716] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[ 17.022716] iwlwifi 0000:00:14.3: 0x00000000 | l2p_duration
[ 17.022717] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[ 17.022718] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[ 17.022719] iwlwifi 0000:00:14.3: 0x00000000 | lmpm_pmg_sel
[ 17.022720] iwlwifi 0000:00:14.3: 0x00000000 | timestamp
[ 17.022721] iwlwifi 0000:00:14.3: 0x00000000 | flow_handler
[ 17.022795] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 17.022796] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: 7
[ 17.022797] iwlwifi 0000:00:14.3: 0x20000066 | NMI_INTERRUPT_HOST
[ 17.022799] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 17.022800] iwlwifi 0000:00:14.3: 0x8045FDF8 | umac branchlink2
[ 17.022801] iwlwifi 0000:00:14.3: 0x804805CE | umac interruptlink1
[ 17.022802] iwlwifi 0000:00:14.3: 0xC008228A | umac interruptlink2
[ 17.022802] iwlwifi 0000:00:14.3: 0x01000000 | umac data1
[ 17.022804] iwlwifi 0000:00:14.3: 0xC008228A | umac data2
[ 17.022804] iwlwifi 0000:00:14.3: 0x00000000 | umac data3
[ 17.022805] iwlwifi 0000:00:14.3: 0x00000048 | umac major
[ 17.022806] iwlwifi 0000:00:14.3: 0xDAA05125 | umac minor
[ 17.022807] iwlwifi 0000:00:14.3: 0x00101E4F | frame pointer
[ 17.022808] iwlwifi 0000:00:14.3: 0xC0887EF4 | stack pointer
[ 17.022809] iwlwifi 0000:00:14.3: 0x00000000 | last host cmd
[ 17.022810] iwlwifi 0000:00:14.3: 0x00000404 | isr status reg
[ 17.022866] iwlwifi 0000:00:14.3: IML/ROM dump:
[ 17.022867] iwlwifi 0000:00:14.3: 0x00000B03 | IML/ROM error/state
[ 17.022876] iwlwifi 0000:00:14.3: 0x00007F73 | IML/ROM data1
[ 17.022885] iwlwifi 0000:00:14.3: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
[ 17.022891] iwlwifi 0000:00:14.3: Fseq Registers:
[ 17.022894] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
[ 17.022897] iwlwifi 0000:00:14.3: 0x003E0003 | FSEQ_TOP_INIT_VERSION
[ 17.022900] iwlwifi 0000:00:14.3: 0x00190002 | FSEQ_CNVIO_INIT_VERSION
[ 17.022903] iwlwifi 0000:00:14.3: 0x0000A652 | FSEQ_OTP_VERSION
[ 17.022906] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 17.022909] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 17.022911] iwlwifi 0000:00:14.3: 0x00080400 | FSEQ_CNVI_ID
[ 17.022914] iwlwifi 0000:00:14.3: 0x00400410 | FSEQ_CNVR_ID
[ 17.022917] iwlwifi 0000:00:14.3: 0x00080400 | CNVI_AUX_MISC_CHIP
[ 17.022925] iwlwifi 0000:00:14.3: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 17.022977] iwlwifi 0000:00:14.3: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 17.023020] iwlwifi 0000:00:14.3: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 17.023022] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[ 17.023024] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 18.217007] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
[ 18.229499] iwlwifi 0000:00:14.3: retry init count 2
All the help is greatly appreciated!
codename_pancakes
Hey there, do you have the latest bios version installed? If your model is 14Z90RS-K.AAW7U1 then the latest bios version is Ver.1.0.0.11
You can check using command prompt by typing: wmic bios get smbiosbiosversion
or
holding down Windows Key + r, then type msinfo32 in the run window. on that first screen you should see Bios/Version.
tyrell
I don't think that is the bios version, it might be the update installer's version.
codename_pancakes
You cannot completely remove power from your wlan because it is soldered to your motherboard. But you can remove the antennae (black and gray wires.) Try putting your laptop directly next to your router and check available networks. That'll let you know if it is an antennae issue.
It does look like the installer version, but your bios date is 26-01-2023 and the date for the installer is a December 2023. I  recommend installing the latest version and try installing their wlan drivers. If you need the link, let me know.
tyrell
I did try installing the latest drivers (from LG's website and Intel's website) multiple times, disabling the network device from Device Manager even, nothing worked out.
Okay, I'll try it without antennas too. Thanks.
codename_pancakes
Just re-seat antennas, you won't see any networks if you don't have them attached.
tyrell
This was kind of expected and without antennas it did not work (same error that the hardware reported errors so stopped). It did not work after re-seat as well.
codename_pancakes
Because it's not working in Linux, I think it's either a hardware or firmware problem.
If updating the bios doesn't fix it, it could be a loose antenna. That was a problem with another Asus laptop I had recently. The wlan card is soldered, but the antennas can be adjusted. I'll try to upload the image from notebookcheck.net
tyrell
I tried removing power from the wlan card board but it still did not work. I will give your method a try and report back.
One detail I left out in the original post is that I took it to the service center few months ago and they wanted to open the chassis and see which part to replace but somehow wifi started working after they closed and booted up Windows. Doing it at home did not work for me.
codename_pancakes
Also, I recommend testing using Ubuntu Non-LTS because it works well with secure boot enabled and will have a newer kernel.
AX211 could just be a problematic card, I'll probably pass on buying an lg style.
tyrell
I tested with Fedora and Arch so it was the latest kernel and I don't think it is a software problem as I can see it.
There were some discussions on the linux kernel bug tracker that this wifi card worked well when plugged into pcie x1 slot rather than x16 slot but apparently I don't have the luxury to try that out or even switch it out for another model.
I met (online) another user of this exact laptop who didn't have the wifi issue so it might be that my particular device is faulty.
codename_pancakes
You have to disable secure boot with Fedora and I'm pretty sure Arch. I have an Acer Nitro 16 that had display brightness issues with it enabled on Fedora, which doesn't support it out the box.
I wonder if both of you are on the same firmware/bios version. Does Linux even detect the card?
tyrell
Nope, Fedora comes with secure boot support OOTB and wifi worked just fine on it when it worked on Windows. Now it doesn't on both. In your case, it might have been an unsigned driver issue.
There have not been any updates for that since I bought it so I guess yes.
Yes, and it worked before. The error for linux even in the errored out state shows the correct model.
Moreover, Intel has official support for AX211 on linux.
tyrell
I suppose giving it back at the service center is my best bet here.
IsaacQ_Intel
Hello tyrell
Thank you for getting back to us. We sincerely apologize for the delay in our response.
We are interested in learning whether you were able to resolve your issue or if you have opted to take your PC to a repair store.
Isaac Q.
IsaacQ_Intel
Hello tyrell,
We hope you are doing fine.
Let us know if you still need assistance. Otherwise we will proceed to close the thread.
Isaac Q.
tyrell
Hello Isaac,
Sorry for not replying earlier, didn't receive a notification for some reason.
No, I couldn't take the laptop to the service centre since the repair person was sick. I was planning on next week but if you could help resolve this without that hassle, I'd very grateful of you.
Thank you.
IsaacQ_Intel
Hello tyrell,
Thank you for responding. I'd like to express my appreciation to @codename_pancakes for your assistance and contributions in addressing this issue. Based on the information gathered during the troubleshooting process, it appears that there may be a hardware issue. Nevertheless, I will do my best to assist within my capabilities.
For this will be necessary that you provide me with the SSU. Please download and scan your system using our tool, Intel® System Support Utility so we can help check your system info first. Once finished downloading, open the tool, click on scan 'Everything', click next, then save the system information to a .txt file. Please provide the .txt file.
This document will be necessary to check your entire system, in order to find possible errors or incompatibilities.
Also, please let me know the following:
1.      Was the wireless card changed or removed? I mean, is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
Isaac Q.
IsaacQ_Intel
Hello tyrell,
Isaac Q.
IsaacQ_Intel
Hello tyrell,
Best regards.
Isaac Q.
