Wireless
8596 Discussions
Intel BE 201 not working on Fedora Linux 42
MC3D_Real
Hello, my Intel BE does not work on Fedora 42
:~$ sudo dmesg | grep iwlwifi
[   12.847736] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[   12.856269] iwlwifi 0000:00:14.3: Detected crf-id 0x2001910, cnv-id 0x1080800 wfpm id 0x80000020
[   12.856278] iwlwifi 0000:00:14.3: PCI dev 7e40/00e4, rev=0x441, rfid=0x20112200
[   12.856280] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 7 BE201 320MHz
[   12.856469] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-ma-b0-fm-c0-89.ucode failed with error -2
[   12.856473] iwlwifi 0000:00:14.3: no suitable firmware found!
[   12.856473] iwlwifi 0000:00:14.3: iwlwifi-ma-b0-fm-c0-89 is required
[   12.856474] iwlwifi 0000:00:14.3: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
I cannot find anywhere iwlwifi-ma-b0-fm-c0-89.ucode
Mike_Intel
Hello MC3D_Real,
  1. What is the brand and model of your system?
  2. Did you install the BE201 on the system manually as an upgrade or is it embedded in the system?
  3. What are the troubleshooting steps that you tried so far?
Michael L.
MC3D_Real
I tried manually finding iwlwifi-ma-b0-fm-c0-89.ucode and "installing" it. But I didn't find it anywhere. Tried different firmwares and renaming them. I did install BE201 as an testing upgrade. The base is a ThinkPad E14 Gen 6. The BE201 is internal with custom external antennas. Is this wifi chip maybe too new? Neither in my laptop or my desktop it worked.
