- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi everyone,
I'm testing the Intel BE2001 Wi-Fi 7 adapter on Windows 11 24H2 (build 26120.5770). The system shows full support for 6GHz in client mode, and the Mobile Hotspot GUI (enabled via ViVeTool) allows selecting the 6GHz band.
However, when I try to activate the hotspot, I get the error:
“Unable to set up mobile hotspot.”
Here’s what I’ve confirmed:
• Adapter: Intel BE2001 Wi-Fi 7 (322MHz)
• Driver: Official Intel driver (netwbe.inf, version 1.1.0.78)
• OS: Windows 11 24H2, GUI shows 6GHz hotspot option
• → Status: Unavailable
• INF file lacks or entries
• Region: Ukraine — 6GHz is legally permitted
So far, everything points to the driver not implementing SoftAP on 6GHz, even though the hardware and OS are ready. I’m wondering:
• Is SoftAP on 6GHz planned for future Intel driver releases?
• Are there any test builds or OEM versions where this is already enabled?
• Can this be manually enabled via INF modification or registry?
Any insights or early driver links would be appreciated. I’m happy to test and provide feedback.
Thanks in advance!
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello Dmitry_Mad,
- What is the brand and model of the system?
- Let me also check, did you manually install this BE2001 on the system as upgrade or is it embedded on the system?
- What are the troubleshooting steps that you tried so far?
- For me to review the hardware and the installed driver, please help generate the SSU logs of the system. Kindly refer to the link below on how to generate the logs:
Michael L.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
This laptop ASUS Vivobook S 5406S, BE201 in original configuration. With help Copilot i tested all need parameters, reg keys, check regional permissions, any driver's version, from asus site support and intel site. In settings present 2.4, 5 and 6 GHz, but i can turn on AP only if select range 2.4.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello Dmitry_Mad,
Thank you for the update.
Based on your reply, let me gather additional details that will help me investigate this issue further.
- Was it working fine before?
- If yes, what was the last change made before the issue started?
- Upon checking SSU, you are using driver version 23.160.0.4. Did you download this driver from Intel website?
- Let me check, have you also tried to download and install the latest wireless driver from the manufacturer of your laptop?
- Can you share some screenshots of the issue?
Michael L.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
1. Initially this feature was not available. I installed the beta version through a pre-assessment program windows. After that, the choice of 5 and 6 GHz appeared
2.
3. SSU check was run with driver downloaded from intel site
4. I tried both the original asus driver, and downloaded from intel site, several different versions.
5. At the moment I can’t provide you with a screenshot, but - I can choose all necessary settings - ok. But as soon as I turn on the access point, I get a message in the same window where and all the settings of the AP - "Unable to set up mobile hotspot" also when selecting 5Ghz. Only by selecting 2.4, with all similar settings, the AP is enabled.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello Dmitry_Mad,
I will do further research on this matter and post the response on this thread once it is available.
Michael L.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello Dmitry_Mad,
Regarding your inquiry, let me share this link:
Do Intel® Wireless Adapters Support Master or AP Mode?
After providing the link, let me also ask. Have you tried to connect to the 6 GHz band before using this wireless controller?
Michael L.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello Dmitry_Mad,
Michael L.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello Dmitry_Mad,
I am sending another follow up to check if you have clarifications from the link that I provided.
Michael L.
