Wireless
8593 Discussions
Intel BE201 Constant wi-fi disconnecting
mdonnelly
Hi All,
Im using a Lenovo Yoga Slim7i with the Wifi 7 Intel BE201 Wifi card,
And the card looks like it keeps causing the laptop to disconnect from the wifi multiple times per day whilst the Laptop is in use, all of the basic stuff like reinstalling drivers and turning off power management setting to allow laptop to disable driver to save power ive done all that and no change.
In event viewer we were seeing under system event id 5002, but after reinstalling driver this has stopped.
But daily we are still getting event id 8003 within Microsoft-windows-WLAN-AutoConfig. Which says the WLAN AutoConfig service has successfully disconnected from a wireless network.
Any ideas?
Cheers
RandyT_Intel
Hi @mdonnelly,
  • Please provide the SSU log report and share it here so I can review your system's configuration.
  • Have you recently updated your device's operating system?
  • How far are you from the router/access point?
  • Are the router lights showing normal status (usually solid green/blue)?
  • Has anyone recently changed router settings or the WiFi password?
  • What's your internet service provider?
  • Have you tried "forgetting" and reconnecting to the network?
  • Are you able to connect via ethernet cable?
  • How many devices are typically connected to this network?
  • Are you connecting to 2.4GHz or 5GHz? (Can you see both bands?)
  • Screenshot of the event viewer error message.
Randy T.
mdonnelly
Hi Randy,
I will work on getting this over to you,
This device came with Windows 11 Pro Preinstalled, and was then imaged with a Windows 11 Pro image after we received it.
This is happening on multiple different networks so its not just a sole router issue, its happening wherever the laptop is.
Yes all routers working as fine
No
Multiple, consistently drops off on all
Yes
Yes
Networks vary, some networks 10-20 devices, some networks 2-3.
Home is a 2.4GHz band
This is the initial one I noticed, but after reinstalling the wifi driver this one stopped, driver was reinstalled on the 13th,
And this continues to happen everyday, here is a screenshot from yesterday.
mdonnelly
Here is the attached SSU Report aswell.
Cheers
