Wireless
告知
8845 ディスカッション
Intel BE201 driver broken on linux
saurabh-rawat
ビギナー
51件の閲覧回数
I have an Asus NUC 15 pro with Intel 225H and the wifi card is BE201.
For any linux kernel above 6.12, the driver for BE201 is severely broken.
For small transfers (scp) it causes skbuff structs (skbuff_head_cache and some skbuff_*node*) to spike to 19-21 gb causing the system to stall, OOM to kick in, swap to thrash before coming down after the transfer starts (not when it completes, it's back to normal as soon as the transfer starts).
It is broken on both Ubuntu 26.04 and Fedora 44.
I am not sure how this is not a huge problem for anyone else using these cards.
Do I just have a broken wifi hardware?
If that's the case, why is 6.12 fine?
Tried reporting here:
https://bugzilla.kernel.org/show_bug.cgi?id=221092
https://bugzilla.redhat.com/show_bug.cgi?id=2459104
Any support from Intel is appreciated.
0 件の賞賛
3 返答(返信)
JedG_Intel
モデレーター
35件の閲覧回数
Hello saurabh-rawat,
I understand you're encountering significant memory allocation problems with skbuff structures that cause system instability during file transfers. This is certainly concerning, and I appreciate you taking the time to file detailed bug reports with both kernel.org and Red Hat.
To further troubleshoot the issue, kindly follow the outlined steps below.
1. Install the latest stable Kernel 6.19 from The Linux Kernel Archives
2. Install the latest firmware iwlwifi-sc-a0-fm-c0-c101 from Firmware git tree
You may also find this article helpful: Linux* Support for Intel® Wireless Adapters
If the issue persists, kindly share the additional information below for further investigation.
1. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
2. Do you remember if this issue happened after a new OS update or Wireless driver update?
If you continue experiencing issues after implementing the stable kernel and firmware updates, please don't hesitate to reach out.
Best regards
Jed G.
saurabh-rawat
ビギナー
18件の閲覧回数
1. Not a new card, came with the system.
2.
Works
Almalinux 10.1:
6.12.0-124.52.3.el10_1.x86_64
[    4.311311] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    4.313013] iwlwifi 0000:00:14.3: Detected crf-id 0x2001910, cnv-id 0x80930 wfpm id 0x80005b20
[    4.313017] iwlwifi 0000:00:14.3: PCI dev 7740/00e4, rev=0x461, rfid=0x20112200
[    4.313019] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 7 BE201 320MHz
[    4.344611] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.4.196
[    4.344816] iwlwifi 0000:00:14.3: loaded firmware version 98.d661c37c.0 bz-b0-fm-c0-98.ucode op_mode iwlmld
[    4.836377] iwlwifi 0000:00:14.3: Detected RF FM, rfid=0x20112200
[    4.840863] iwlwifi 0000:00:14.3: loaded PNVM version 752be616
[    4.948500] iwlwifi 0000:00:14.3: base HW address: 38:18:68:67:78:89
[    5.026310] iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 1
[    5.030357] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
Bluefin LTS HWE:
6.17.12-200.fc42.x86_64
[    7.106023] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    7.108170] iwlwifi 0000:00:14.3: Detected crf-id 0x2001910, cnv-id 0x80930 wfpm id 0x80005b20
[    7.108177] iwlwifi 0000:00:14.3: PCI dev 7740/00e4, rev=0x461, rfid=0x20112200
[    7.108179] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 7 BE201 320MHz
[    7.174148] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-bz-b0-fm-c0-102.ucode failed with error -2
[    7.293959] iwlwifi 0000:00:14.3: loaded firmware version 101.6ef20b19.0 bz-b0-fm-c0-101.ucode op_mode iwlmld
[    7.845683] iwlwifi 0000:00:14.3: Detected RF FM, rfid=0x20112200
[    7.951940] iwlwifi 0000:00:14.3: base HW address: 38:18:68:67:78:89
[    8.021351] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
Doesn't Work
Fedora rawhide:
7.1.0-0.rc1.260501g26fd6bff2c050.13.fc45.x86_64
[   19.133850] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[   19.136051] iwlwifi 0000:00:14.3: Detected crf-id 0x2001910, cnv-id 0x80930 wfpm id 0x80005b20
[   19.136060] iwlwifi 0000:00:14.3: PCI dev 7740/00e4, rev=0x461, rfid=0x20112200
[   19.136062] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 7 BE201 320MHz
[   19.596097] iwlwifi 0000:00:14.3: loaded firmware version 102.07fca168.0 bz-b0-fm-c0-c102.ucode op_mode iwlmld
[   21.334817] iwlwifi 0000:00:14.3: Detected RF FM, rfid=0x20112200
[   21.438807] iwlwifi 0000:00:14.3: base HW address: 38:18:68:67:78:89
[   21.512723] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
Fedora 44:
6.19.10-300.fc44.x86_64
[   18.285732] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[   18.288031] iwlwifi 0000:00:14.3: Detected crf-id 0x2001910, cnv-id 0x80930 wfpm id 0x80005b20
[   18.288040] iwlwifi 0000:00:14.3: PCI dev 7740/00e4, rev=0x461, rfid=0x20112200
[   18.288042] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 7 BE201 320MHz
[   18.836490] iwlwifi 0000:00:14.3: loaded firmware version 101.6e695a70.0 bz-b0-fm-c0-c101.ucode op_mode iwlmld
[   22.470498] iwlwifi 0000:00:14.3: Detected RF FM, rfid=0x20112200
[   22.574049] iwlwifi 0000:00:14.3: base HW address: 38:18:68:67:78:89
[   22.650424] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
I only have one linux system, which I need to use. So I can't do arbitrary experiments on it.
I hope with the above details, you are able to reproduce and debug.
JedG_Intel
モデレーター
8件の閲覧回数
Hi saurabh-rawat,
Thank you for sharing all of this information. I will investigate the issue further and get back to you as soon as I have an update or if any additional information is needed.
In the meantime, if you have any questions or concerns, please don't hesitate to let me know.
Best regards
Jed G.
返信
