Wireless
9036 Discussions
Intel Drivers Question.
Steve1955
I have successfully updated these drivers many times recently and I'm still getting the same  update messages, weekly.
I have had the same constant issue with Brother Printer Drivers.
I'm running a new computer (Sept 2025), with Windows 11 Home, with automatic updates running.
I'm getting annoyed that this is happening all the time and want to know why it's happening.  I install all updates to the System & Printer.
JedG_Intel
Hi Steve1955,
Thank you for sharing the screenshots, I appreciate you taking the time to provide those details.
Upon review, I can confirm that you are using the Intel® Driver & Support Assistant to update your Wi‑Fi and Bluetooth drivers. Based on the information shown, I did not observe the tool repeatedly recommending the exact same driver versions for installation.
Please note that driver updates are released periodically to address bugs, improve compatibility, and enhance overall system stability. These updates may appear frequently as new versions become available.
I understand that this may feel annoying, especially since the driver updates seem to come up frequently. If you prefer not to receive these update notifications, you can adjust the settings by following the steps below or you can just click on the driver update you don’t want and check the box for “Hide just this update.”
1. Launch Intel® Driver & Support Assistant
2. Go to Settings
3. Locate the Notifications section
4. Set notifications to Never
If you have any questions, please let me know.
Best regards
Jed G.
JedG_Intel
Hello Steve1955,
Greetings from Intel Customer Support.
I understand how inconvenient it must be to receive the same update notifications repeatedly, especially when you've successfully installed the drivers multiple times. Based on your description, this appears to be related to how Windows 11 is managing driver updates rather than an issue with the Intel drivers themselves.
This issue typically occurs when Windows Update doesn't properly recognize that newer or equivalent drivers are already installed, often due to different driver sources (OEM vs. generic) or Windows Update database inconsistencies.
You can consider adjusting your Windows Update settings to prevent automatic driver installations that might conflict with manually installed drivers.
To investigate further, kindly share the additional information below.
1. What is the current Wi-Fi and Bluetooth driver?
  • Open Device Manager → Bluetooth → Right-click your device → Properties → Driver tab
  • Open Device Manager → Network adapters → Right-click your Intel adapter → Properties → Driver tab
2. What is the complete model of your Wireless card?
3. Did the issue started after a specific Windows update or system change?
4. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
5. Is Windows Update trying to install a different driver version than what's currently installed?
Best regards
Jed G.
Steve1955
Hi Jed G. Thanks for trying to help me out here.My System.jpgIntel_Drivers_01.jpgBefore the Drivers Update todayIntel_Drivers_02.jpgAfter Drivers Update today
n_scott_pearson
See topic The Graphics Driver Downgrade Problem - Things Are Looking Up! for more information on the underlying issue.
JedG_Intel
Hi Steve1955,
2. Go to Settings
Best regards
Jed G.
Steve1955
Hi Jed G.
Thanks for your ongoing help with this issue.  I worry about frequent update notifications a bit just in case it's someone trying to gain access through a back door.  I didn't think Intel would do as many updates so often.
But I will do as you have suggested and move forward.
Best Regards
Steve
JedG_Intel
Hi Steve1955,
I completely understand your concern regarding the frequent driver update. Rest assured that updates provided through the Intel Driver & Support Assistant are safe and secure.
I’ve sent you an email to gather additional information and to continue providing support. Please check your inbox at your earliest convenience.
Best regards
Jed G.
Charlie8
Oh my god this is driving me up the wall. Intel Driver & Support Assistant is asking me to manually update about once every couple of weeks.
ARC Graphics, Platform Performance Package, Killer Performance Suite, Wireless Bluetooth Drivers and NPU Drivers. I must've had to run more than 20 manual updates so far this year.
Are updates this frequent really necessary? Why isn't there an auto-update option?
